Question about Fujitsu Fujistu ST1200 Notebook
Verdical Line I have a Fujitsu laptop computer.There is a black verdical line in the middle of the monitor,that splits the screen in two. I don't know where it came from.It doesn't look like a monitor problem, but instead likesomeone pressed a function and it appeared there. This line is therefrom the time on turn on the computer.
  • ladystardust Dec 15, 2007
    Two vertical lines, one turquoise and one yellow, appeared on their own, offset from the center of the screen on my Fujitsu laptop.
    They are not affected by touching the screen and they span the entirety of the screen, including start menu, etc.
    I have not dropped or roughed up the machine...I thought that may have been the case when the first line (turquoise) appeared, but I haven't moved the computer since and the yellow line recently appeared nonetheless.
    Problem Solver:
  • 10 Answers
Vertical lines mean you need to replace the screen. did you drop the machine?
Posted on Nov 30, 2007
SOURCE:
Fujitsu siemens scenicview b19-3
hi you must disable the main screen in properties section of the display panel then when you start up the computer the screen will not activate until windows has loaded and found and installed the screen drivers after that all should be good to go if you need any further help don't hesitate to contact me :)
Feb 07, 2013 | Fujitsu Siemens Premium Line P19-1 19" LCD...
My Fujitsu siemens esprimo mobile M9400 laptop screen was fade (white color). When I connect to extra monitor via monitor output, computer is working well. How can I solve this problem?
Dear User,
Good day, maybe you need to press the function key of your laptop plus(+) the split monitor key in your keyboard it is usually placed in F5 key.
Apr 16, 2011 | Fujitsu Siemens Computers & Internet
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor...
Monitor ia having a problem with Voltage filtration... Replace the electrolitic capacitors at secondary side of power board, There are 2 voltages, 12 V and 5V...each of them has few electrolitic capacitors in line, replace them, watch the polarity and all works...Cause of eletrolitic capacitors on secondary side may be the one little capacitor in the primary side, becarefull there is some high voltage out there
Dec 11, 2010 | Fujitsu Siemens Siemens Premium Line P17-1...
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor does...
Try connecting each monitor to a different desktop/laptop computer, to rule-out the possibility that the video-card on your own computer is the cause of the problem.
Sep 29, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
A black line heavy in the middle at the top right corner of the monitor
check whether Line present during self test, and in Bios screen
If Line present it is Hardware failure, Monitor needs to be repalced
If Line no Present,. Perform Factory Restore
Jan 12, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
After only 1 month of use I started getting 2 blue verdical lines in the center of the screen. after a few days, a red on appeared. i tried to connenct it to another computer, change cable, switch to...
you can call Samsung customer support and they will replace or repair it for you. you just need to provide them the serial number of the Monitor which is at the back of it
Aug 29, 2009 | Samsung 2333SW 23" Widescreen DVI LCD...
E510 camera
most likely a hardware fault you can get a free repair estimate from
http://www.advancecamera.com/repair/
Dec 01, 2007 | Fuji FinePix E510 Digital Camera
Black Line in middle of screen
Are you able to test this monitor on another pc? This will allow us to eliminate or identify as problem with the graphics card. With the monitor itself, these lines could indicate screen damage - has the screen been dropped or accidentally hit with a pen etc.. ?
Aug 21, 2007 | Dell E171FP 17" Flat Panel LCD Monitor
Fujitsu Fujistu ST1200 Notebook Logo
191 people viewed this question
Top Fujitsu Computers & Internet Experts
Ekse
Alun Cox
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
