Question about Canon PIXMA MP830 All-In-One InkJet Printer
My MP830 won't print
I had a paper jam that I took care of and then receive a 5100 error message so I shut the machine down and when I turned it back it had stopped printing. I receive a collecting printer status notification and when I select display print queue it shows an error - printing under status. I've unplugged the usb cable, power cord etc. and that didn't work so I need help. I run a homebased business and have to get my work out so if someone can please help me, it would be so appreciated. Thank you.
  • Anonymous Aug 07, 2008
    I have the exact same probblem as the first guy, and I did the exact same thing. NO LUCK! Please help.
  • 4,345 Answers
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 01, 2010
SOURCE:
Canon MP830 will not print Error code 5C10, And 5100 [email protected]
5C10 seems to indicate a paper jam. 5100 indicates either a paper jam or ink tanks not seated properly.
A) Paper jam: There is a rear cover on this model. Many paper jams cannot be seen from the outside. Sometimes even a scrap of paper from a previous jam will disrupt the paper path.
B) Follow your manual for installation of the ink tanks. Remove and replace the ink tanks carefully following the instructions.
C) Should these remedies not fix the problem, you can try resetting the device:
1) Press and hold the <On/Off> button until the display on the machine goes blank. (If this is unsuccessful, unplug the power cord).
2) Wait approx. 10 seconds and power back on. Wait until the printer completes its startup routine before trying another print job.
3) If solution fails, your MP 830 may require repair
Dec 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
6A00 Error code? I reset, checked for jams, etc, but no results? Any clues? It is a MP830 Canon, with a bit of printing time, probably several thousand total documents by now. The error code just came on...
OK this is old but you may look back
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Dec 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MY CANON MP830 WILL DISPLAY A "ERROR 5100" USUALLY BEFORE OR AFTER PRINTING. IF I RESTART IT WILL PRINT ONCE, THEN DISPLAY "ERROR 5100." I CAN'T FIND ANY PAPER JAM IN PRINTER. HOPE YOU CAN HELP. RAY...
Other than:
1) checking that no paper is jammed in the printer (don't forget to check the rear access door for paper jammed internally)
2) holding the <On/Off> button until the display goes blank, then waiting ten seconds before pressing <On/Off> button again (to reset the unit) and
3) checking that the ink cartridges are properly installed,
if the problem persists, your Canon MP830 may require repair.
Dec 20, 2009 | Canon Office Equipment & Supplies
Canon mx330 Error 5100 Error 5100 Printer error has occured. Turn printer off and then on again. If this doesnt clear the error, see the users guide for more detail.
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Nov 04, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Paper jam. caused error print unable 30
"Machine Error 30" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
Even a ripped part of a paper will be able to cause the paper, so it's important to be careful when taking jammed paper out to not rip the paper (do this by carefully pulling the paper among the same way as it would go when printing, not the opposite direction).
However, if that doesn't work, the error is mechanical (but still most likely caused by the jam, either a sensor getting dirty and unable to do it's work, or actually getting broken), and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Mp830 shows paper output slot jam
I cannot receive faxes or print anything.
The message says that "there is no paper in the machine". There us plenty of paper in the machine and I push "OK" and get the same message
Jun 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
CANON FAX JX200
remove the cartridge and see if it goes away, if does then you probably have a defective cartridge are are not inserting it correctly.
Thank You,
Mikey
Apr 04, 2008 | Canon FAX-JX200
PAPER JAM MESSAGE, BUT CAN'T FIND ANY JAMMED PAPER
look at the paper tray,some of your sensor are jammed,try tyo find out where is the sensor on paper try
Feb 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Canon PIXMA MP830 All-In-One InkJet Printer Logo
189 people viewed this question
Clive
Clive
old marine
old marine
Ekse
