Question about Canon P23-DH Calculator
Cannot set the date on my Canon P23-DH V calcualtor
I'm trying to set the date as per the instruction booklet that came with the calculator. But it won't keep the date, it resets it when I try and get out of that function. It keeps the time, but not the date.
Any ideas??
  • 2 more comments
  • jkr56 Dec 13, 2007
    I'm trying to read the instructions for setting the date and the time on my Canon P23-DH V calculator and they are not very good instructions. I am a layman when it comes to this kind of stuff and need specific step by step instructions. Can you help me please?
  • tatp9 Dec 17, 2007
    I try to set the date, but it wont keep it. It keep reset to the original date? Pls help.
  • Anonymous Mar 23, 2008
    I turned the machine on. I pressed the clock/date once and got the preset date. I pressed and held M+= and the "0" of the preset "01" started flashing on and off . I continued to hold M+= while I entered the current date and.... nothing happened.
  • Anonymous May 23, 2009
    Even after getting it to flash and setting it to current date it doesn't hold the date. pressing M+= does nothing pressing the red button (CE/C) sets it back to the default factory date. (09/04/2004)
Ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
Posted on Feb 05, 2008
I do not have a manual, but reading what everyone else did I figured it out.
Turn on calculator; push the calendar/time button once; press and hold the M+= button until the first number flashes; set the date and the cursor will go back to the first number flashing; now press the M+= button once and none of the numbers should be flashing. The date is now set.
Press the Calendar/Time button again and you will now see the time; press and hold the M+= button until the first number is flashing; set the time w/ hours and minutes and the cursor will go back to the first number; to change AM and PM press the button below the M+= button w/ the #diamond on it; then press the M+= button and the seconds will begin. The time is now set.
Hit CE/C to back out and then go back in, again, to see if it set correctly.
Posted on Oct 02, 2009
  • Frank Sep 13, 2013
    This is how the manual should read. Thanks A Lot
Just had the same problem...This what you do...press clock/date key (2nd key from left) will take you to the date mode. Hold 3 secs than press the M+= button on the far right (3rd key down from the top) until 1st digit flashes proceed to put in correct date. Than hit caculator button far left (last button-red) Than repeat to set the mode to time and repeat proceedure. Don't forget to set am/pm button. It is just below clock and date button far right ( 4th key down)....Good Luck and hope this helps. Dawn
Posted on Dec 13, 2007
None of the above solutions seem to explain how to switch the time setting between AM and PM. I finally found out (the hard way...by hitting every key!) you must hit the key that has the number symbol (#) and the diamond symbol on it. That will switch between AM and PM. On my calculator, this key is located just 1 key below the M+= key.
Posted on Sep 14, 2009
    New Friend:
I was having this same issue. The standard instructions wouldn't update the date. It would automatically go back to the default date.
RESET the calculator! There a little pinhole on the bottom of the calculator, press a pen or paperclip to reset.
After the reset the normal instructions for setting date and time worked.
Posted on May 18, 2017
Once you are done setting the time/date press the M+= again, this should set the time/date and stop if from flashing
Posted on Mar 18, 2008
  • Xochitl Andrade Aug 31, 2013
    I have set the date and time and pressed M=+ again but it goes back to the first digit flashing
  • joel1_17
    joel1_17 Feb 23, 2014
    Has anyone figured out how to set the date on one of these things yet? Is it just a bug that can't be worked out?
Sorry, 1013ths solution does not work. I can enter the date set mode and enter the correct date, however there is no "calculator button far left (last button-red) on my canon p23 DH.
Posted on Jan 29, 2008
  • Jose Gonzalez
    Jose Gonzalez Jul 14, 2015
    Thank you, awesome info, I got it!
SOURCE:
Ht set clock on canon P23 calculator
Follow the instructions at the beginning of the manual.
Mar 04, 2012 | Canon P23-DH Calculator
I need the instructions for a canon P23-DH V calculator
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Apr 16, 2010 | Canon P23-DH Calculator
Have a P23-DH V Canon Calculator. Am trying to
Press and hold the ClockDate Set button for three seconds until the display shows the date with the first digit blinking. Enter a two-digit month, a two-digit date, and a four-digit year, followed by the ClockDate Set button.
Press and release the ClockDate Set button. Press and hold it for three seconds until the display shows the time with the first digit blinking. Enter a four-digit time, press AM/PM as appropriate, then press the ClockDate Set button. Press CE/C to finish and return to calculation mode.
You can download a copy of the manual from the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Mar 30, 2010 | Canon P23-DHV Calculator
How do I set the date on the Canon P23-DH V calculator? I have lost the manual and just cannot remember how to do it.
You can download the manual from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Feb 02, 2010 | Canon P23-DHV Calculator
How do you set the date & time on a canon P23-dh?
You can download a manual from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Oct 03, 2009 | Canon P23-DH Calculator
Setting the date and time
download the user manual (P23-DH III) from here:
http://rapidshare.com/files/181603396/P23DHIII.PDF.html
Jan 08, 2009 | Canon P23-DHIII Calculator
Can't set date
Download the user manual (P23-DH III) from here:
Nov 15, 2008 | Canon P23-DH Calculator
Canon P23-DH
I don't think the P23-DH has a calendar/clock mode. I have found the instructions for setting date and time for the P23-DH V. If your calculator does not have [Calendar/Clock], [Time Set], and [AM/PM] keys, you cannot set the date and time.
To set date:
1. Press the [Calendar/Clock] key once
2. Press and hold the [Time Set] key for three seconds
3. Enter the date in MMDDYYYY format
4. Press the [Time Set] key
5. Press the [C/CE] key
To set time:
1. Press the [Calendar/Clock] key twice
3. Enter the date in HHMM format, press [AM/PM] key if necessary
Aug 27, 2008 | Canon P23-DH Calculator
Rather than try to describe the process (through this slot and over that), I'll suggest you follow the illustrated instructions in the manual you can download from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Jul 07, 2008 | Canon P23-DH Calculator
Canon P23-DH Calculator Logo
7,009 people viewed this question
Clive
Clive
old marine
old marine
Ekse
