Question about Canon PowerShot S3 IS Digital Camera
Pictures and video not clear
The pictures and video are "in focus" but the pictures aren't clear. It's like the colors are distorted or you can see the megapixels. That's the best way I can describe it. I'm not sure if I dropped it and messed something up or I have a bad setting. I use the "auto" function. Any help is appreciated.
    Sergeant:
    Novelist:
  • 143 Answers
The first thing I would do is - as Paul suggested, clean the lense using a fine-threaded cloth and a light cleansing solution.
But it sounds to me as though your Image Quality is set to "Normal" in the camera's FUNCTION menu. This is part of the same menu where you change the resolution of your camera's pictures.
Your options are as follows:
  • Normal
  • Fine
  • Superfine
While having the mode selection wheel in "Auto" mode, press "FUNC." near the upper-right corner of the view screen. (The button with the trash-can icon.) You'll be met with a menu where all but the last two options on the left side of the screen are greyed out. The option you'll find yourself already on is the video resolution.
Press down on the directional pad once. You should see the resolution that your camera is currently set to. (I believe the default was "L" which is 2816x2112. Move the cursor left and right to select the image resolution you desire.
Once you have moved the cursor to the correct resolution, press the "SET" button under the directional pad. You will now be met with the image quality menu.
From right to left: Normal, Fine and then Superfine. Select "Superfine". This will enhance the overall quality of the image. (These settings are retained PER RESOLUTION SETTING in the camera's memory.) Press "SET" once more and exit the options menu by pressing "FUNC." again.
Making sure to use the two-step button properly, take another picture and see what you get with it.
Certain things can affect the camera's operation and quality as well. For instance, if you bring the camera out of the cold after it sits in it for a while, you have to let the camera adjust itself to room temperature first. Otherwise you will get blurry images because of condensation build-up on the lens. (The same effect as when you get a can of cold soda out of the fridge in the summer. You see all that condensation build up on the sides of the can due to the differences in temperature in the air and the surface of the can condensing the moisture from the air.) Is the environment you're in possibly filled with moisture from heating systems?
Let us know if you are able to fix your issue here. Please wait to rate us until we actually arrive at an end result. (Unless the solution given fixes your problem. Feel free to rate "Fixya" if that's the case.)
Hope this helps you.
Cyryl
Posted on Dec 08, 2007
  • Cory Kielion
    Cory Kielion Dec 08, 2007
    P.S.
    Forgot to mention that you can adjust the image quality settings in most any mode you select on your mode selection wheel. I use "P" (Program) mode myself for most applications. Remember that your settings are retained within the modes that you set them in.
    Cyryl
Have you checked the lens to see if it clean?
Maybe you have the ISO setting on HI or 1600 which would cause a grainy/fuzzy image.
Posted on Nov 30, 2007
SOURCE:
My camera does not take pictures when on af focus. what should i do?
The first thing you should do is test another lens on your camera. If the other lens doesn't focus then there is a problem with your camera body. "If the other lens DOES focus, then it's a problem with your lens. In both cases your camera or lens will need to be repaired
Sep 16, 2014 | Canon Eos Rebel T1i 500d Dslr Camera Body...
The picture on our Sony TV Model KP-43HT20 recently became distorted, concaving at top and bottom. If I use reset the Flash Focus, the picture will return to full screen side for awhile but the colors do...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergene board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 15, 2011 | Sony KP-43HT20 43" Rear Projection...
Middle of the top of the picture in distorted and out of focus. color is displaying only purple at the top
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,require replacing to fix the tv convergence board,to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 04, 2010 | JVC AV-56WP74 56" Rear Projection...
Screen looks distorted when on, what should i do?
Tried push the FOCUS buton on the remote or tried convergence aligment,R,G,B colors lines don't lines up,picture have colors shadows or 3D pictures?The tv have a convergence pronlems,it dead.The tv convergence board is dead.Try website like Tvrepairworld.com to buy a whole convergence board for the replacement.The AKAI/SAMSUNG tvs are using the same convergence board.
Sep 22, 2010 | Samsung PCL6215R 62" Rear Projection...
Distorted picture.
Is the menu text clear on the screen, when it's focused correctly. Or is that also distorted.
If the menu text is OK then the picture signal is dodgy. could be due to a bad earth lead on the video cable.
Is it distorted on all signal inputs
Oct 30, 2009 | Panasonic PT-LB20U Multimedia Projector
Sony 46 inch proj tv picture is bowed in the middle and color is
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Picture is out of focus. Tried Magic focus - didn't work. Saw color grid; appears blue is out of whack.
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Oct 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Screen Out of Focus with Wavy Lines - Perfect Focus Will Not Corr
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Mar 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Blury Pictures
My Logitech Quickcam for notebooks Deluxe webcam was blurry.
I spent 3 hours surfing the net looking for the answer, only to find a load of vague and technical responses about OS's and other ****. I fiddled about with the focus ring around the lens on my cam, which wouldn't move, so i figured i had an inferior version that had some sort of in-built auto-focus.
Eventually i lost my rag with the poor quality of information i was finding on this issue.
I went downstairs, got my pliers out of my tool bag, and wrenched the lens ring.
It moved.
Camera focused.
Job done.
Voila, no techy **** required.
Feb 16, 2008 | Logitech Webcam
Canon PowerShot S3 IS Digital Camera Logo
108 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
