Question about Philips 30PW8420 TV
Tv shuts off and won't turn on
We have a 30" philips hdtv model 3pw8420/37. the first time we had the problem with the tv the tv just shut off by itself and a white horizontal line appeared on the tv. So we sent it to a tv repair shop. they keeped our tv for months. they had repaired the parts and soldered connections but did not tell us what exactly went wrong with our tv. got it back and the tv went out again the same as the first time. sent it back for the second time and this time they said they had replaced the pix tube. It lasted for about 16 hours woke up the next morning to watch tv and it came on and once again the same problem it just shut down. please help do we get rid of the tv or do we send it somewhere else
  • Anonymous Feb 17, 2008
    we have a philips 30pw8420/37 It simply turns off by itself. If we turn it on, we see the green light but it blinks and then turns without seeing a picture or sound
  • Anonymous Apr 07, 2008
    I have the same problem as the 2d person. I turn on the TV, it shuts itself off, and the green light blinks intermittently. If I wait a long while and try to turn the TV on again, it turns on for a few seconds, then repeats the pattern. I have also unplugged it for 2 extended periods to see if it would reset.
  • 88 Answers
Sound like vertical section problem, need to replace back same same # vertical ic& importance thing need to check component around ic like capacitors & resistors.then the vertical section be working fine. good luck!
Posted on Apr 29, 2010
    Sergeant:
    Champion:
  • 318 Answers
The tv first it had a verticle problem. now a set has a power supply problem, they have to check for a light semi conductor values, for diodes and transistors. the electrolitic capacitors after the 95-110volts ht from the power supply be checked and measured, rectifier diodes be checked for leakages. a picture is not aproblem .thanks
Posted on Mar 20, 2009
Philips digital tv won’t turn on.
unplug from electric, wait 30 seconds, plug back in. Check that you have power at the outlet (fuse/breaker shut off?) If it has a power word which plugs into the TV as well as the wall, be SURE it is tightly attached to BOTH. Make sure you aren't blocking the remote control receiver (you can turn most TVs on/off on the TV itself -- look for a power button). Be sure your remote has fresh batteries. Good luck!
Jan 14, 2018 | Philips Televison & Video
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv turns off after about 30 seconds and 3 red lights show
Your lamp is burned out. When powering up the lamp doesn't turn on so the TV shuts down. Replace the lamp and it should fix the problem. This happens with mine about 1 per year and everytime it's the lamp.
Oct 30, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Flashing red light and shutting itself off
try to elevate the projection tv about an inch...
it well most likely work...
it's a ventilation problem.
Feb 09, 2007 | Philips 55PL9223 55" Rear Projection...
Philips 30PW8420 TV Logo
204 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
