Question about Bally Walk In 9 8"" X 19 3"" X 7 6"" high floor panels
Walk in panel instalation
I have a problem aligning the panels the only way some of them lock is with poor alignment.
0 characters
1 Points
How do I change a RH opening fridge door to a LH opening door?
Standard refrigerators usually have hinge mounting holes on both sides with those on the opposite side covered by a plastic trim plug. Removing the plastic plug should reveal tapped holes for installation of the hinges. Be sure the reversed door is properly aligned so you won't have to "tweak" the alignment afterwards.
Oct 28, 2015 | Refrigerators
I have been unable to remove the wter filter. I have tried to turn it 1/4 of an inch clockwise as described in the owners manual but the filter won't budge. any suggestions?
OK maybe try 1/4 inch counterclockwise and pull down. Here is what the service manual quotes.
That is easy for anyone to misread.
Water Filter Removal
The water filter is located in the upper right-hand
corner of the refrigerator. The water filter filters water
for the ice maker and the water dispenser.
1. Turn the water filter 1/2 turn counterclockwise and
pull it down.
2. To install the filter, align the indication mark
(unlock position) and push it up while turning 1/2
turn clockwise until the lock position is aligned.
Do not over tighten.
That would be to the left while facing the filter and opposite for installation. Note where and when to push up. Please let me know if you have any questions and please rate if I am able to help you, Thanks, Sea Breeze
May 08, 2011 | Samsung RS2556 Side by Side Refrigerator
My freezer door will not seal very well and creates large amounts of frost. If I could raise the door I think the problem would be fixed but I can't figure out a way to raise it. Any help would be...
first, take a look if there is some loads that protrudes and touches the frzr door,its one cause sometimes why you cant close it well, if there's nothing, door assembly is misaligned. To correct that, you should align the door,loosen the top hinge screw, with this you can see also if you can make an alignment by pulling it back and forth the retighten the lock screw. In side by side refs mostly they use special spacer,there's a band that they call it camriser. It is located at the bottom hinge and attached. if it is already worn out or the cams flattened already you should replace it, you can buy it on nearest supplier or bring the sample.One of the best remedy is to use flat washer that will fit into the hinge pin,it could raise the elevation of the door then you can align it now by adjusting the top hinge pulling it backward to get the correct alignment of the door.Dont forget to unplug the unit before doing this.
Mar 23, 2010 | LG LRSC-26922 Side by Side Refrigerator
Whirlpool side by side refrigerator filter installation. new filter will not turn.
Hi and welcome to FixYa. I am Kelly.
My reading your question lead me to think that the filter cap is what your havin difficulty with. Push hard and turn. Make sure the locking tabs are aligned. Take the cap back off and look at how it locks internally. Then align the cap with the locking tabs PRESS and turn. I hope I am not over simplifying this but the new filter usually comes with instruction sheets with pictures.
Thanks for using FixYa!
Feb 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water/ice dispenser sticking on
We had a problem with the water/ice dispenser on our 5-year-old LG SxS Refrigerator (LRSC 26930TT). In a panic to stop the water flow, the rubber activator boot was pulled off. The dispenser stopped once the button attached to the back of the boot was removed. Nothing was physically broken (i.e., parts intact) but the challenge was to get things (especially the boot) back in place. The key for me was to use patience: researched Internet for pointers (not too helpful), looked for schematics (even less fruitful) and exhaustively examined the panel on refrigerator (to help reverse engineer). Okay, here’s how I disassembled and reassembled without breaking any tabs or other pieces. Assuming your unit is similar, the panel is on the freezer door on the left side. You can lock the dispenser (using panel button) to preclude undesired water/ice while working. Note: the outer bezel (edge of panel) is secured by screws and should not be messed with. The main panel has tabs on all four sides. I used three screwdrivers (small to average in size) to pry the panel off. Pry the main panel working through the seam between the bezel and panel. Work your way around starting from the lower left or upper left corner. Each side of the panel has 3 or 4 tabs. Methodically work your way around using moderate force to pop the tabs loose. Once the panel is loose, you’ll need to disconnect the electrical connector at the upper left. The plug comes off and reattaches easily…don’t pull on the wires, use the plastic connector itself. Wiggle the panel free. Now you can get to the back of the boot retention bezel…the ultimate goal. Carefully push the bezel’s securing tabs (x3) through the panel and reattach the rubber boot. I used needle nose pliers to carefully pull each rubber nib through their applicable hole on the bezel. Now leave the boot/bezel assembly to the side—it’s the last step to reassembly. Note how the main panel tabs fit into their receiving slots/flanges. Reattach the electrical connector, snaps right on, and maneuver center of panel into recessed area, around ice chute/water nozzle. Slide the right and bottom sides on first—flanges, not slots for tabs—then align remainder of panel. Using moderate force, pop (punch) the remaining tabs back into their respective slots. The main panel will seat over the bezel. Now align and snap boot/bezel back into place. Finis! (No guarantees, but this procedure worked like a charm for me.)
Sep 11, 2009 | LG LRSC-26922 Side by Side Refrigerator
How do you align the left door on the Kitchenaid Architect French door refigerator
Sometimes the problem is not the door hinge alignment but the refrigerator is not sitting level.
You may be able to get the doors aligned with the leveling legs on the unit.
Apr 17, 2009 | KitchenAid Refrigerators
Water Filter not filtering
Mar 04, 2009 | Samsung RS2534 Side by Side Refrigerator
U-Line 2175RS
The sound you are hearing is the open door alarm. Make sure your door is able to close completely. If you have installed panels make sure they are aligned properly on the door and not getting caught up on the cabinets beside the unit.
Feb 03, 2008 | U-Line ?chelon 2175RB-00
FRIDIGIDAIRE FRS26R4CWC I suspect the defrost drain line is plugged
Sounds like the drain is frozen. Break up the ice and remove as much as you can and use hot water to melt the rest. May need to remove the back panel in the freezer so you can get hot water down the drain until it is clear.
Nov 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
If the ice build up is only on the back panel of the freezer then you have a defrost problem. Most likely a defrost thermostat or control board/timer. If frost build up is around the walls of the freezer then warm air is getting into the freezer. Most likely cause of this would be gaps in or torn door gasket or door alignment. In some cases the door was left cracked open. If gasket and door alignment is ok remove the frost and see if it comes back.
Oct 05, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Bally Walk In 9 8"" X 19 3"" X 7 6"" high floor panels Logo
Top Bally Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Bally Refrigerator Expert? Answer questions, earn points and help others
