When I turn my camera on, the screen reads, Internal Memory is Full. I can't do anything except look at photos on my memory card and record .02 seconds with the camera
This means that the internal memory of the camera is full. Apart from the external memory slot, camera's have this what you call internal memory. It is built-in to the unit itself.
What you want to do is to set the default storage to the external memory instead of the internal once.
On the Menu, navigate to image store and then choose AUTO.
Auto (default)—the camera uses the card if one is in the camera. If not, the camera uses internal memory. Internal Memory—the camera uses internal memory, even if a card is installed.
Also, you would want to set the camera resolution to a lower value to. The higher the pixel rate, the bigger space it eats up in your memory storage.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Kodak EasyShare C533 Digital
When I turn the camera on (with new batteries), it flashes green for a second or two, then flashes...
(More)
When I turn the camera on (with new batteries), it flashes green for a second or two, then flashes red and will not turn on. What is the issue? Thank you.
Camera won't show any pictures on the screen but will show from sd card taken from another camera....
(More)
Camera won't show any pictures on the screen but will show from sd card taken from another camera. It will flash and you can hear it click but no picture.
