Automatic channel changer timer thingy
Hi, my father is paralyzed and when he had Dishnetwork there was an option to program the dvr to switch channels at certain times - not record them, just switches over. We recently switched to Fios and that option isn't there. Is there any remote or device that I can purchase that will just set the dvr or tv to switch channels? Setting it to record the shows is not an option. He can't use the remote, I need something I can program so that the channels are just set to change at certain times like Dish had.
Thanks for your help.
jdrrwoods
  • 82 Answers
SOURCE: Sony SLV-798 HF VCR
on alot of vcrs if you already have a set time for one channel to record at a later time if you dant set the earliest first it wont let you change it but im not sure if you already have one set ahead of time or not
Posted on Feb 09, 2008
Coldcut
  • 1554 Answers
SOURCE: Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Posted on Apr 25, 2008
dinomb
  • 16 Answers
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
Posted on May 11, 2008
  • 8 Answers
SOURCE: SAT/CBL button changes my RCA TV to channel 02
http://157.254.235.130/public/RCR860.pdf
http://157.254.235.130/public/RCR860_code_list.pdf
These are the Manual and The Codes List!!
Enjoy!!
Posted on May 29, 2008
  • 10865 Answers
SOURCE: cant program our slvainia t.v with satelite dish remote
Your problem is common because there are so many products on the market these days.
That said, you can purchase one truly universal remote that will absolutely control all of your devices. Go to any TV/electronics store, even a radio shack and take a look at these. Don't be surprised by their price tags, as they are usually in the $100. range.
Posted on Jun 06, 2009
Cm7000pal dvr stuck in wizard on continue in searching for channels seams to load on hdd then goes to continue
I have 3 of these 7000pals and 2 have done a similar thing, one of them did it twice. After the Loading Channel Master screen hangs for a time, they would restart. Then the same cycle would keep repeating. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed that twice it happened on the hour just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
The steps below fixed all three instances of this failure.
To unlock the Channel Master CM7000PAL DVR:
1. Unplug the recorder from the wall outlet and DISCONNECT THE ANTENNA. Now plug it back into the wall power outlet.(This will keep the recorder from freezing and rebooting)
2. let it go thru it's normal bootup, tv guide search, etc.
3. When you are able to, hit MENU and then go up to TIMERS. Delete all of the record timers. Unplug it, reconnect the antenna, and plug it back in.
4. After a now a proper bootup, re-program you timers and you will be good to go.
5. And the best thing is, all of your pre-recorded shows will still be there on the hard drive.
I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Jan 22, 2014 | Channel Master CM7000PAL HD DVR
Dish changing channel to new recording while watching *pre-recorded* program
rjvdw,
Try unplugging the receiver for 10 seconds then plugging it back in, and see if the problem is resolved. The receiver should only switch if you are watching live TV instead of a recording.
If the problem persists, and you are for sure not on Live TV, the receiver may need to be replaced. If it continues you can send me an email at thomas.faust@dishnetwork.com, and I can assist you further!
Tommy Faust
DISH Internet Response Team
Jan 23, 2012 | DISH Network 54 1 Ir Vip 622 722 Dvr...
Hi,well um my dish remote controller is like disactivated or something because it wont change channels,I don't know if its the remote controller or the batterys or the dish box thingy,please help.
Hi my nameis Mike Houston of DISH Network and I see there is an issue with the remotecontrol not changing channels. The first thing you will need to do is changethe batteries and I will send a link that helps with the steps for readdressingthe remote, if you have any questions or concerns please e-mail me at michael.houston@dishnetwork.com.http://www.dishnetwork.com/SupportSection/remote-control
Aug 01, 2011 | DISH Network 322 DTV Receiver
How do I record two channels at once on a DMR-EX773EB DVD Recorder
I cannot find on online manual for this model. If dual channel recording an actual specification for the model? If it really should be able to record two channels at once then it may be similar to the DishNetwork DVR. It has one input but internally splits and creates two different outputs for two different channels.
Check to see if there is a mode setting for single/dual. You will need to set it to "dual". The Dishnetwork DVR has what it calls TV1 and TV2. You can record to TV1 but cannot watch a different channel on TV1 while it is recording. You CAN however watch and record a different channel on TV2 while TV1 is recording. (and vice versa). You can also record two shows while watching other recorded shows.
I'm guessing that you may need to look for some recording options to be able to record two channels at once.
Mar 21, 2011 | Panasonic Televison & Video
I cannot program my dvr because the timer will only show ch.3 what if i want to record ch.72 with th timer?
Go to "setup" mode on the DVR, and do a "scan for available TV channels", to add more channels,
or explicitly "add" channel #72 as an available channel.
Mar 17, 2011 | Computers & Internet
I have just purchased an avex universal urc-r6 remote and i cannot seem to find the way to program it for my vip 722 dvr receiver.
Hi tesmathwi572 my name is Mike Houston of DISH Network andI was going over your post and with our DISH remotes that go with the receiverwill give full functionality to change the channels as well as the DVR andaccess the Menu. Buy getting another remote from a store may not program to thereceiver to change the channels, if I can check your account information suchas account number or phone number so I can see about getting the remote thatgoes with that system. I will leave you my e-mail so you can contact medirectly. michael.houston@dishnetwork.com
Feb 23, 2011 | DISH Network ViP722 DTV Receiver /...
Dual transmitter DVR has stopped recording on TV2. Programs are set to record, the guide shows that they are being recorded. They are listed in the to record list, but they are not in the list of...
Hi, my name is Cheri Torres and I am with DISH Network Customer Service. I have never heard of receiver only recording on one tuner but not on the other but I would like to see if we can find a solution for you. The first step to try in order to resolve your issue is make sure that you do not have any timers conflicting with each other. If you do have two different timers that are set to record at the same time it can cause the DVR to record one show and not the other. Another trouble shooting step to try is a hard reset by unplugging your receiver for ten seconds then plugging the cord back in. After you have allowed your DISH receiver to reset try your DVR recording functions again. If both of these options are not correcting the problem please feel free to email me at Cheri.Torres@Dishnetwork.com so that I can ask you a few more questions about your issue and get this resolved for you as soon as possible. Thanks and have a great day! :)
Feb 02, 2011 | DISH Network ViP722 DTV Receiver /...
When I try to record back to back programs on different channels the timers won't work. It tells me there is a conflict with the timers and tells me to change priority or whatever. I can set a manual...
Hi this is Luke.
DVR Priority settings are used to prioritize timers should there be a conflict between timers. The top of the list is the highest priority and takes precedence. The bottom of the list is the lowest priority. A lower priority timer will not fire if there is a higher priority timer at the same time. Timers that conflict with each other will display Attention 532. The message may display when switching from Single User Mode to Dual User Mode because the receiver recalculates timers for conflicts.
  1. Press DVR three times on the remote (twice for a 942 receiver). The skip timer icon (red x) designates a conflicting timer.
  2. Select Timers.
  3. Select Set Priority.
  4. Select the timer to change.
  5. Use the Up and Down arrow buttons on the remote or the Move Up and Move Down options on the screen to move the timer priority one at a time. Use the Move to Top and Move to Last options on the screen to make the timer top or last priority.
  6. Select Done.
Selecting Automatically resolve by priority will allow the receiver to set the priority level of the timer. The last timer created will have the lowest priority level and will not be recorded if both tuners are being used for other higher priority level timers.
Selecting Change the priority of this timer will allow the customer to set the priority level of the timer. With the new event highlighted in the Daily Schedule screen (the event will display with the skip icon), press Select. Select Restore and then Yes. The new timer will now have a higher priority level than the conflicting timers.
You may also want to resolve the conflict by:
  1. Press Menu on the remote.
  2. Select Daily Schedule.
  3. Select Timers.
  4. Arrow over and select the timer that needs to be edited.
  5. Select Edit.
  6. Make the desired changes then select done.
Let me know if this help.
Jan 21, 2011 | DISH Network DVR 510 DTV Receiver /...
I have bose v30, dishnetwork 612 dvr. When
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues.
What is happening is that when video resolution changes (like from regular programming to commercials) the video information is poorly sent down the HDMI line. Component cabling from your DVR will eliminate this problem.
I hope that helps.
Feb 06, 2010 | Bose 36037 Remote Control
Olevia channel setup
buy a universal remote and program it. they have them at bestbuy or any electronic store.
Feb 16, 2008 | Olevia LT26HVX 26 in. LCD Television
Televison & Video Logo
245 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
