Question about Magellan RoadMate 700 GPS Receiver
Hitting The Locate Button Shows Incorrect Current Location
History: When I hit the locate button the unit was showing me my previous destination. It looked like it was locked up.
Action:I took DanEz007 advice that I saw from similar posts and Reset Data Saver GPS. I also reset the Data Saver. Upon power up and hitting the locate button I'm now getting a reading listing that I am in California. I live in Michigan. I opened the unit up and all of the cables look secure. The antenna itself looked like it had a small amount of powdery white substance around it that I simply blew off. Any idea where to go from here? Thanks...
  • 2 more comments
  • Funcha Dec 05, 2007
    So your expert solution to my problem is to basically contact the manufacturer?
    The unit is about three years old according to my brother-in-law who gave it to me. I'll have to ask him where he bought it from in order to follow your instruction.
    His advice was to replace the antenna. I decided to look on the web for help instead of simply ordering the $25.00 replacement part. This is how I came to join FixYa...
    Additional Advice Requested...
  • Funcha Dec 06, 2007
    The signal strength is staying Black - acquiring position. There is also a satellite icon rotating on the right hand side. Note: My locate position is now changing to a new city every time I power it up and depress the button.
    OK, So we go from don't try and fix this yourself and contact the seller to a high tech status screen...
    Not sure what the TeleType GPS program is but I turned the unit on and went through the menus until I found the GPS Status screens.
    My Key Strokes:
    Options
    Configurations
    Diagnostics
    GPS Status
    There are two pages under this heading. The first lists channels 1 thru 12 and I do see the toggling of data under the heading Freq & Position. On the second page there are a number of columns displayed but none that with the heading: GPGSV or GPGSA...and there is no updating of data on this screen.
    So sorry I could not follow your troubleshooting procedure because I can't find the correct part of the program that lists: Tools or Satellite
    Thank You
  • 752 Answers
Does your unit indicate any level of signal strength? It's a color code as indicated on page 8 of the manual:
http://www.magellangps.com/assets/manuals/magellan_roadmate_series_en.pdf
Black -acquiring position. Blue -WAAS signal (best signal), Green -Strong Signal, Yellow -Average Signal, Red -No Signal.
If it's not getting any signal it could be a defective antenna.
Posted on Dec 05, 2007
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
I think your prob is not simple if anybody tell u do this or tat don't do it because i have a same prob but my fault is try myself and it becomes more disable and father beaten me
so acc to my opinion go to the expert and where u buy this he normaled your problem don't worry i do the same thing
and u again enjoy
WARNING:
DO NOT OPEN YOURSELF
IF U HAVE TRUST ON ME MY ID IS
[email protected]
  • shivam raj
    shivam raj Dec 06, 2007
    . Activate the TeleType GPS program
    2. Select Tools>GPS Status>Status.
    3. Look closely at the GPS output that is displayed in the View Status
    menu. Data should be flowing even when the GPS receiver has not locked
    in the position.
    The data string that begins:
    GPGSV... is "bad data" because the receiver has not locked
    into the satellites.
    Whereas:
    GPGSA... is "good data" indicating that the receiver has
    locked into the satellites. Remember - "A-Okay"
    4. Once the data is flowing, go outside away from buildings, select
    the Satellites tab (Tools>GPS Status>Satellites), and watch
    the satellite signal strength
  • shivam raj
    f not then go through this
    and mean best must seeeeeeeeeeeee
    http://www.teletype.com/pages/support/fa...
SOURCE:
When I open my google it shows sites that I have visited how can I remove them?
Try clearing your browsing history. Open up your Settings on your iPad, click Safari, then Clear History. This will wipe out your iPads previous knowledge of any sites you've visited.
To prevent them from listing moving forward, you can use private browsing. If you're using iOS 7, you can access it by opening Safari, hitting the + button near the bottom of the page, and hitting Private in the left hand corner. It'll ask you if you want to keep or close your currently open tabs after that.
Hope this helps!
Aug 25, 2014 | Apple iPad 32 GB WiFi Tablet PC
My 510 history is locked up, can't figer how to get it unlocked.
Not sure if it will work for you ! But I would plug it in to your PC with UBS cord let set over night it may come back .You may then have to push the reset
hope it work's for you
Aug 21, 2014 | Rand Mcnally Intelliroute TND 510 Truck...
Putting numbers in the memory and editing
To store numbers in memory do the following
(Make sure the phone is in standby and not in TALK mode)
2.) Press the memory button on the handset or base.
3.) Press the desired memory location button (0 through 9 number keys) or
use the CID-VOL (- or + ) buttons on the handset or CID/rev or CID/skip)
buttons on the base to scroll to desired memory location. If the memory
location is occupied, the stored name and number displays. If the
memory location is unoccupied, EMPTY shows in the display.
4.) Press the memory button again. The display shows ENTER NAME.
5.) Use the base or cordless handset touch-tone pad to enter a name (up to
15 characters).
6.) Press the memory button again to save your selection. The display
shows ENTER TEL NUMBR.
7. Enter the area code followed by the
telephone number (up to 24 digits, including pauses) and press the
memory button again to save your selection. The unit beeps to confirm.
8. To enter another name and number in a different memory location,
return to step 1 and repeat the process.
Manual available HERE
Jun 17, 2011 | Uniden Cordless Phone
Gps won,t move from last location
When you put in a new location how are you entering it? If you are using the "Where to?" menu then you will need to click on the "Map" button instead of GO when you find the point you are looking for, may it be an address or a Point of Interest. This will show the location on the map. If you want that to be your current location you must have the GPS turned off. Then on some units you will Have the option to set as your current location.
I hope this was some help.
Cheers
Jul 14, 2010 | Garmin StreetPilot C330 GPS Receiver
It takes forever to get into my yahoo mail, then when I do it shows my emails for a quick second then dissapears!
The first thing you may try is to access your Yahoo! Mail in a different computer, to see if the same problem will occur.
If your Yahoo Mail work correctly on different computer, then the problem has something to do with your computer. Most likely, it's the internet browser. If the problem is within your computer, you may try to clear the cookies, cache, internet files, and/or browsing history of your browser. Here's how:
* For Internet Explorer:
1. Run Internet Explorer and click on 'Tools' menu.
2. Go to Internet Options and locate the Browsing History section.
3. Click the 'Delete' button and delete the Temporary Internet Files, Cookies and History.
4. Close the Internet Explorer and re-open it.
5. Access your e-mail.
* For Mozilla Firefox:
1. Run Firefox and hit 'Tools' menu.
2. Go to 'Clear Recent History' and click the drop-down arrow for 'Time range to clear'.
3. Select 'Everything' and then click the line beside details.
4. Check browsing & download history, form & search history, cookies, cache.
5. Click "Clear Now" button.
6. Close and re-open Firefox.
7. Access your e-mail.
* For Safari:
1. Open the Safari.
2. Click the Safari menu (right beside the Apple icon) and select "Empty Cache".
3. When asked "Are you sure you want to empty the cache?", click "Empty".
4. Click the Safari menu (right beside the Apple icon) then go to "Preferences".
5. From the security dialog box, click "Bookmarks".
6. Click on "Show Cookies" button and then hit "Remove All" button.
7. Select "Done".
8. Access your email.
Thank you and good luck!
Jun 13, 2010 | Yahoo Mail
How to change home address
using your touch screen, go to tools> my data> set home location> you can use your current position or you can enter it. then it will be save as a home address
Sep 27, 2009 | Garmin nuvi 265 Car GPS Receiver
Vw sat nav problem
There may be a setting somewhere to define your 'home' position. It will probably default to this location as standard until you find the setting and reset it to your own postcode/home address
Jul 07, 2009 | Car Audio & Video
Jaguar Xtype navi routing not working
I had the same problem. What you need to do is clear the waypoint locations from the system. To do this hit the "nav" button, get to destination menu and locate the waypoint icon and touch. Delete all waypoint locations shows up at the bottom. Touch button, which will delete all waypoint locations and it will work again. Just to be safe, I cleared all of my stored locations including previous destinations
Jun 25, 2009 | 2003 Jaguar S-Type
Show default location how do i change it to my current location
You have to enter the new destination.It will keep last destination as current location.
Apr 26, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
ICN 330
You program another trip.
May 24, 2008 | Navman iCN 330 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
108 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
