Motherboards
Problem for ASUS Motherboards
Generic problem for all ASUS Motherboards
Hi all i have a asusp4p800 motherboard tha...
By jddavis2 on Aug 15, 2009
hi all i have a asusp4p800 motherboard that was on and working till i shut it off to add more mem,and new video card,now when it boots up it wil stop at the asus bios screen unless i unplug the hard drive power or data cable then it will go to another screen and this is what it says..american megattrends..asus p4p800 acpi bios revision 1014..cpu intel,pentium 4 cpu 2.60 ghz..speed 2.60 ghz..press del to run setup..press <f8> for bbs popup...ddr frequency 266 mhz,dual chANNel,linear mode...checking nv ram..2048 mb ok..usb devices:1 mouse ..auto detecting sec master,atapi cd rom..sec master:pioneer dvd-rw dvr-112d 1.21..auto detecting usb mass storage devices..00 usb mass storage devices found and configured..new cpu installed!please enter setup to configure your system..no hard disk drive detected!..press <f1> to run setup...press <f2>to load default values and continue...nonthing on the keyboard will work and i did not install a new cpu,it takes it about a minute to switch screens if i take the memory out it will beep continuosly..any ideas..harddrive maybe?..thanx
Solution #1
posted on Aug 15, 2009
Not Rated)
info2u
Rank: Wiz
Rating: 82%, 97 votes
I would try resetting the CMOS jumper on your motherboard, usually done by moving the jumber from the 1-2 position to the 2-3 position or completely off. (Check your motherboard specs for detail) Wait about 2-3 minutes then reset to 1-2 position. I would also check to make sure the memory and video cards are securely seated.
After this, your system should go throught a POST test and allow you to enter your BIOS setup to make sure everything is being detected.
Good Luck
C2Solutions
Was this helpful?
Yes
No
Solution #2
Not Rated)
jitendraverm
Rank: Apprentice
Rating: 0%, 0 votes
hallo friend
you should remove hdd ID cabals and after that hard disk jumper chak first jumper Hdd master and sacud jumper cd-rom jumper slave
so please chake hear
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
compaq presario mother board, what should I replace it with
Answer
does intel 850e motherboard support usb 2 0
Answer
I have a promax x chip and i want to fit it to my 2008 citroen c5 1.6 diesel. I am not sure of the... (More)
Answer
Problem with AGP, in the specs, 2x / 4x AGP, but in the bios I can only choose 1x / 2x.
Answer
Hi, i would buy NBA 2k10 for PC I checked my laptop specs and it passes the system requirement but i... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For ASUS Motherboards:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14925
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
