Question about Sony Playstation 3 (PS3) Console
Unsure of problem
I bought a intercooler fan for my ps3 hoping that was my problem but i dont think it was...it turns on sometimes it;ll stay on for 20 mins max..but at other times it'll turn off instantly ...and its been a few times where it flashes a orange light instead of green or red...what can i do?
    Scholar:
    New Friend:
  • 67 Answers
Check to see if the problem is overheating by storing it in a plastic bag in a refrigerator for 1/2 hour then power it up immediately. Don't let it stay out without power or let it dry as moisture will condense on it. If it stays on longer after cooling something is causing overheating., if not the problem is probably an intermittant short. If you can open it up and spray the components individually with freeze spray, this may isolate the problem. Sometimes pc boards warp under temperature changes and cause intermittant problems, sometimes it's a semiconductor.
Posted on Nov 30, 2007
Hi, i"m having a hard
The best place to look is online for one. Search trusted sites like Amazon, Newegg, Tigerdirect, and FrozenCP. I don't know if you can find these in stores anymore due to the Slim being out and it being the main one with any support left. I have included a link to get you started.
Best of luck
http://www.amazon.com/Intercooler-Cooling-Fan-Sony-Playstation-PSP/dp/B003DS6LPE/ref=sr_1_5?ie=UTF8&qid=1306766706&sr=8-5
May 30, 2011 | Sony Playstation 3 (PS3) Console
Hello, i started up my 60gb playstation last night and it ran fora few minutes then turned itself off. Turned it back on and it would stay on for a few seconds and turn off,repeatedly. Did it this morning...
Hello, I think You should have a cooling fan that can cool it from heat. Because the cause of that problem is that the prossesor is over heated and it cant contiune. So you have to take out of power for sometime (1 hour or more) then try it again. If you need me call on me back.
Mar 25, 2011 | Sony Playstation 3 (PS3) Console
Can i use a intercooler if my fanis no workin properly in my ps3
It is not recommended to simply rely on the intercooler fans. Since they are not cotrolled by the main board they do not adjust for correct operation. The intercooler fans are the to get fresh cooler air around your system and to help remove some of the heat generated.
Mar 21, 2011 | Video Game Consoles & Games
My playstation 3 always bug when i try to use it . its the older version and i think the fan is broken inside because it is over eating fast and each time i try to play to a game it freeze and i cant even...
sounds like you do have an issue with the fan. You can get an external fan from like gamestop or another store such as that. It would be called an intracooler, or intercooler. You have to make sure its for the model you have tho this would help some of the issue. Otherwise you can search in craigslist or something of these sorts. I dont reccomend opening your PS3 however you can find in craigslist under the videogame area people who fix your systems. It may take 20-40 dollars or something like that, but its worth it. They usually guarentee their work for a month or more too.. Good luck.
Mar 03, 2011 | Sony Playstation 3 (PS3) Console
I bought a NYKO intercooling fan and the plug from the xbox 360 elite will not go into the fan receptacle is there a specific intercooler for the elite?
Microsoft has two different power connections for the Xbox 360. I do not recommend the use of the Intercooler. Believe it or not, it actually prevents air from circulating and increases the temperature of the 360!
For cooling I always recommend the fan modification. I have written a free guide showing you how to do this, no soldering skills required!
Here is the guide.
Hope this helps! Let me know if you have any questions.
Dec 29, 2009 | Nyko Intercooler for Xbox 360
Ps3 overheat
Your PS3 might have a broken fan. If you are using an external fan that attaches to the PS3 than stop, fans like the Nyko Intercooler and Pelican cause more problems with ventillation and may cause the PS3 to overheat. If heat is an issue make sure the system has plenty of room to breath and point a small fan at the console. If thiat doesn't work call Sony customer sopport.
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont stay on
Overheating get a fan
from http://www.buy.com/prod/playstation-3-fusion-cooling-fan-intercooler-system/q/loc/108/204972579.html
its 20$ but it works like a charm
or you could give it to sony to fix it might not be overheating before buying the fan check to make sure
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
Game freeze
PS3 is one of the most amazing gaming device but like other. competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up..
Jan 24, 2009 | Sony Playstation 3 (PS3) Console
No sound or picture
hi i think it's the heat transfer compound (fan) in the system which is wearing away causing it to over heat and shut down as a safety percaution.
Oct 04, 2008 | Sony Playstation 3 (PS3) Console
Ps3 overheating
hey man go to walmart or either a game store and buy a fan its called an intercooler that is exactly what had happened to me and that fixed it and it should for you they are about 40 dollors or so at least for me
Apr 17, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
