Question about Audiovox PPC 4100 Pocket PC
Aidiovox PPC 4100
My phone shut off because I suspect my battery needs replacement. It lost all the data. I did a restore from the SD card but no data reappears.
0 characters
1 Points
Sd file recovery
I'd recommend that you download this sd card recovery software called asoftech data recovery, download from link below
Dec 20, 2012 | HP IPAQ PDAs
Can not connect with pc
INSTALL correct software in your computer and then go to connectivity click transfer data option and press yes and check it
Jul 19, 2010 | Audiovox PPC 4100 Pocket PC
Starting problem
Hi, Firstly do one thing take a backup of the existing Data. This can be done from Start=>programs=>Xbackup=> choose the desired data i.e. All data or Contacts & appointments. (I forcefully recommend to take Contacts & Appointments) It will take 5 to 10 Min. Remove the Menory Card.After this takes palce, with help of your Stylus press the Reset Button (found at the down end of ur PPC next to the Handsfree Jack.) The Phone will restart with the Factory Settings & will take time. Now after the PPC completely boots check the performance. after scan your memory card with the help of a Personal computer antivirus software & only then restore the data in the similar fashion from the Xbackup utility=>restore.
Note : After restoring the data if the same problem occurs then please again reset the phone & donot Restore your data as it may be corrupt.
Jul 11, 2009 | i-mate JAM Pocket PC
Memory card not recognized
The micro SD card you need is made by Handango "Games for Windows Mobile Standard". Got mine at Best Buy
Feb 08, 2009 | Sprint Vision PPC-6700 Smartphone
Ipaq 4100 problem syncronizing with outlook on new laptop
you are now using outlook 2003 , probably cache , this means all the email is on your laptop. when you sync it will sync all the email (thousands). initialise your ppc (back to factory default). set up the sync via usb cable. then sync via bluetooth . then you are fully sync. now setup an auto backup of your email data (daily). if after some time , you have sync problem again , initialise the ppc, restore from backup and you are back to sync (last full backup). try this , you will never need to do it all again.
David Ng
Sep 23, 2008 | HP iPAQ H4150 Pocket PC
Cant store data
You need to connect an SD card reader to your computer and pull the card from the PPC-6700, copy the contents to a directory on your hard drive and then remove that card from the reader, insert the new card and copy the content of the directory you just copied the old card to the new card. That is all you need to do.
Please do not hesitate to contact me for more information or for other questions.
Please remember to rate this solution.
Sep 17, 2008 | Audiovox PPC 6700
Audiovox ppc 4100
hi there, i think i can help you. email me at I will send you instructions and a file that will permanently unlock you phone 100% guarantee
Mar 29, 2008 | Audiovox PPC 4100 Pocket PC
MN1 bootloader
First try turning on your phone without the memory card. I suspect you have an SD flash upgrade files in the SD card that's forcing the phone to reflash every time it turn on.
If it is still failed, you could try doing a hard reset? But be carefull, you'll need to back up all your data first, cause it will delete all files and data in the phone.
Dec 03, 2007 | O2 Xda Atom
Restoring data saved on a Flash Card
The battery backup can be replaced by sliding the side IR cover down and pulling the plastic side tab which holds a button battery of size 2032. You can get a 10 pack of these batteries for $1 of you look on the website which sell cheap LED lights.
Here are some links and the FAQ about backs and such:
Sep 12, 2005 | HP Jornada 200LX Palmtop
EM-500 music transfer
Seeing that you are using a EM500 with only 16mb of RAM, you might want to get a SD/MMC Card. With that being said, let's do this, shall we? Connect your PPC to your desktop using ActiveSync, then press on the TAB "Explore" then "My Pocket PC". You are interest in the "My Documents" folder, that is where you will place your .WMA, MP3, OGG files. Just copy the music file from your desktop that you want on your PPC, and then paste it to the "My Documents" folder of your PPC. Now if you have a storage card (MMC/SD), you will have to create a folder on the storage card and name it to "My Documents". So you will then have 2 My Documents folders, one on storage card, and 1 on the PPC. If you want the Music file on the storage card to save space on your PPC, then do the following. Connect the PPC to your desktop using activesync, then press on the TAB "Explore" then "My Pocket PC". You then need to click on the "Storage Card" folder, there you will see your "My Documents" folder you created. Just copy the music file from your desktop that you want on your PPC, then paste it to that folder. To speed things up, you can also use a MMC/SD Reader. you can then copy and paste directly on the memory card, without going thru ActiveSync. Goodluck, and have fun!
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
Audiovox PPC 4100 Pocket PC Logo
19 people viewed this question
Top Audiovox PDAs Experts
Martin Murray
Starnley Johnwells
Starnley Johnwells
Are you an Audiovox PDA Expert? Answer questions, earn points and help others
