Question about Frigidaire FGF316 Gas Kitchen Range
Frigidaire fgf316wgsh we have an intermittent problem with the oven, "sometimes " it overheats by as much as 200 degrees. It also "sometimes" has a very high flame in the oven.
    Scholar:
  • 146 Answers
Is it natural gas or propane? They usually come as natural gas. If it is propane has it ever been converted? If not convert it.
Posted on Dec 21, 2007
The oven heats up but stops a 200 degress
Good Afternoon Ben,
I see that you are having trouble with your dual fuel range, model# PLCF489AC, heating up past 200 degrees. It sounds like it could possibly be something to do with your control board or your oven thermostat. I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your range, if it still will not heat up past 200 degrees, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 18, 2014 | Frigidaire PLCF489AC Dual Fuel (Electric...
My Frigidaire oven will not turn off! When I baked at 475 degrees, and pushed "Clear", the oven would not turn off. The next time I used the oven I was able to turn off but it went back on! This is he
You've shown in the video that this is an intermittant problem. These are among the most difficult to isolate because the failure is unpredictable.
This is really not something that you can deal with or fix on your own, as there are really no "user serviceable parts" inside for you to replace in this oven. You would need service manuals, test equipment, etc. to locate and replace the offending part (if it were a fuse or similar, once it blew it would fail predictably and be easy to find - this is not the case for your problem - assuming you have shut off this oven successfully in the past the way you demonstrated in the video and it sometimes does not shut off).
You will likely need to call for professional service. They are equipped with the tools and knowledge to get your oven working properly again. Good luck!
Mar 14, 2013 | Ovens
While baking oven starts broiling with no input from controller. f2 is displayed on screen
Hello there:
F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Sep 27, 2010 | GE JKP15 Electric Single Oven
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
The oven makes a loud rattling sound when it reaches a certain heat (tends to be about 200 degrees) and then rattles intermittently until turned off. If you slam the door it does sometimes shut for a...
From what you describe is happening, I would say that it is the fan that is causing the noise, not neccesserily the oven fan, because there is an external cooling fan as well, and these are the only moving parts that could cause a noise.
Hope this helps.
Feb 02, 2010 | Candy FP855 Electric Single Oven
Ge oven turns off by itself, and sometimes gives
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
Frigidaire gas wall oven clock unit sometimes says F1 and beeps.
F-1 is USUALLY a touch pad error, it thiniks something is stuck. The sensor error code is F-3.
Mar 17, 2009 | Frigidaire 24" Built-In Single Gas Wall...
GE JKS06 won't heat up past 200
Hi.
Could be that main oven stat is faulty, and also there is a possibility that the thermal overheat stat is coming in sometimes caused by poor ventilation.
Also there is sometimes a secondary element fitted to cookers which is not always obvious.
More investigation is needed.
Nov 19, 2008 | GE JKS06BFBB Electric Single Oven
Frigidaire electri-clean oven overheats greatly. no temperature control
Frigidaire electri- clean oven heats to 500 degrees no matter what the temperature control is set to.  What is happening ?
May 29, 2008 | Frigidaire Kitchen Ranges
Frigidaire FGF316 Gas Kitchen Range Logo
314 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
