Question about JBL (JBLONTOUR) Computer Speakers
Deffective Speakers???? For sometime my spealers have not worked. I finally sat down to look at he problem and found a simple solution. The speaker was not connected to the power. When I fixed that, it starting with a loud hum. As I continued to diagonse the problem through the control panel, smoke started coming out of the speaker connected to the power. I disconnected it from the computer and the power. I have speaker model # SP08A11, Realtek, AC'97 audio. Any ideas?? I guess I need new speakers. Please respond. Thanks.
    Problem Solver:
  • 7 Answers
No need to buy a new speaker,
Inside the speaker box there is one TRANSFORMAR with 4 or 2 Diods & capasitor will be there that will connected to your Power cord & another line will go to Speaker ,
smoke has came from the transformar,
If you able to replace that your speaker will start work fine
cheers
Posted on Nov 30, 2007
Speakers wont work. The friend who gave me the spealers had them installed on a Gateway. I'm usinf an HP 7360n
make sure you are using analog cable, not digital. analog has headphones male jack on both ends, digital has headphones jack on one, and rca jack on other end
Sep 01, 2011 | Boston Acoustics BA735 Computer Speakers
I need the wires to conect two speakers sony sa-va100r
Which two speakers?
http://www.retrevo.com/support/Sony-SA-VA100-Speaker-Systems-manual/id/22986ci669/t/2/
The speakers themselves appear to use standard spealer wire with bare ends. Just get a roll of lamp cord at the hardware store and cut it to the length you need.
Between the two front speakers they require a standard RCA stereo audio cable.
http://www.searspartsdirect.com/partsdirect/part-model/Sony-Parts/Audio-equipment-Parts/Model-SAVA500/0996/0311400/50017803/00001
If you're needing the flat cable the link above is a breakdown of the various components. Perhaps you could contact them and describe which 'wire' you need.
Some other possibilities...
1-777-117-11 CORD (WITH CONNECTOR)(15P)
http://www.encompassparts.com/products/?1-691-777-11
http://www.partstore.com/Part/Sony/Sony/175134713/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=SAVA100
Feb 01, 2011 | Sony SA-VA100 System
4 out of my 5 jbl 125 sat home speakers have very very low sound, the speakers don't look blown
Before you blame the speaker one simple test needs to be made, if you have not done so already.
If one remaning speaker has full volume output, swap one of the 'defective" speakers to that same channel the "good" speaker was attached to, and see if the output drops.
Nov 22, 2010 | JBL SCS125A System
Speaker connection out no sound
GREEN - "line out" --> speakers with their own amplifier to boost the sound-level
BLUE - "line in" --> connect to "L/R audio output" from a cassette player
RED - "microphone input" --> microphone
Jul 22, 2010 | Acer Aopen MS698 Computer Speakers
Internal speakers just stopped working. External spealers work via headphone jack.
once you connected with the external speakers the internal speaker will never work
Feb 24, 2010 | Gateway T-6330U Notebook
Audio distorsi,PA new.solotion?
Do you mean ordia distortion? upgrade your sound card, or get new speakers. I had speakers and they sounded horrible. I upgraded my motherboard and my speakers and what huge difference it made.
Aug 15, 2009 | ASUS P4P800-X Pentium Motherboard
Need to hook up to a 4000 watt amp
Why would you hook up 4000 watt amp to a speaker that has only 1000 watts. Try a 800 watt amp instead unless you just dont want the spealers.
Apr 13, 2009 | Theater Research TR-9500 Car Subwoofer Box...
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
I bought a kenwood kaf1010, powers up fine all buttons and l.e.d.s fine, believe it has input from cd player to volume control as my elec tester picks some thing up. but nothing to the speakers. took cd...
Suggest connecting headsets. If audio is present then you can assume the problem is in the final stage of the power amplification. Also you can check the record out using another amplifier to confirm preamp is OK.
If all speakers are not workinhg check the power supply that feeds the power amplifier for spealers.
Hope this helps.
kenwood-kaf-1010-144842-efqr1tkyxkjjaeu2rzas4dg3-2-0.jpg Hope this helps?
May 17, 2017 | Audio Players & Recorders
LEDs don't light
??????????????? only on fixya would we get a complaint that speakers that are supposed to make sound work great but some lights on them dont work.... ugh.. ok with most of the spealers that have l.e.d.s typically have a seperate connection for the lights. The red wire goes to a switched 12 volt power source, the black goes to chassis ground... if they have power and ground but dont light up then they are junk...
Sep 08, 2007 | Blitz BZX462 Coaxial Car Speaker
JBL (JBLONTOUR) Computer Speakers Logo
467 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
