Question about Pioneer VSX-816-K/S Receiver
NEW WITH LCD TV
HI I AM NEW WITH LCD TV, Y BUY Y NEW TV VIWSONIC 42` LCD , HD 1080, , THEY TELL ME I NEW A RECEIVER FOR GET THE BEST RESOLUTION , AND Y DON`T IF THIS RECEIVER VSX-816 WORK WITH
    Problem Solver:
  • 12 Answers
This pioneer does not support HDMI, so for the best resolution you have to use video the component inputs and output, those are marked as Y (green), Pr (red) and Pb (Blue) and remember, this signals are only for video so you need to hook up the audio too.
Posted on Jul 11, 2008
SOURCE:
3D tv issues with HD channels on Dish Network
check screen resolution of your lcd tv & receiver too
Aug 24, 2012 | Dynex DX-L42-10A 42 in. LCD TV
My TV was FINE for months after I purchased it. Making zero changes to the HD cable box which was always set on 1080i. All of a sudden I get this Invalid format error out of nowhere. Don't tell me
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 22, 2012 | LG 32LG30 32 in. LCD HDTV
The tv i own: Panasonic TX-32LX77 LCD Monitor (TX32LX77) . i want to know if this is HD. if i hook up the tatasky HD box, will i get a full HD output? thnx
The TX-32LX77 is an HD TV but only has 720p (1366 x 768) resolution. Full HD is 1080p. (SD is 480i.)
I wish that I had better news.
(It's possible that you won't notice the resolution difference; small screens don't always need the full 1080 lines of pixels from top to bottom of the screen to give a crisp picture.)
May 23, 2011 | Panasonic Viera TX-32LX77 LCD TV
How does it help to have a Full HD LCD TV?
Hi - welcome to Fixya,
There is no advantage in buying a Full HD (1080p) TV if you are only using it for watching TV. Currently, there are no Full HD television broadcasts and there are no plans to introduce any. All UK HD channels currently broadcast in 720p resolution whether they are on Sky, Freeview, or Freesat. Therefore, any TV that is described as 'HD ready' rather than 'Full HD' will display all HD channels at maximum quality or resolution.
The advantage of Full HD is when using them with Blu-ray DVD players, gaming systems, e.g. Sony Playstation, or for playback of media files from your PC. These systems output at 1080p / Full HD (but only when connected with an HDMi cable) and you would need a full HD TV in order to get the best quality / resolution from these systems. However, you don't need a Full HD TV to connect these devices as they can all display their output on a 720p HD Ready TV.
The main disadvantage of any HDTV (1080 or 720) is when watching standard definition (SD) broadcasts. Full HD TVs have 1080 horizontal display lines, but SD broadcasts only have 540 horizontal lines. When watching SD channels on an HD TV, the other 540 lines, i,e half of the picture, are being created by software within the TV - known as 'Upscaling'. Upscaling requires processing by the TV which takes time and fast motion can seem blurred or blocky/pixellated as a result. Higher end TVs have faster response times (0.5ms or less) which minimises the pixellation so this specification is important when selecting an HD TV for purchase.
Hope this helps.
Regards,
BElectric
Nov 18, 2010 | Samsung Televison & Video
I need an authorisation code to retune a 42 inch LCD full HD 1080 TV Product L42E77AZ TCLELE
The TV will display the signal it is being fed with and adjust itself according to the video signal resolution. The video source tells the TV what the resolution it should display. 720 in 720 out on the screen, 1080 in 1080 on th screen (if TV can do 1080p or 1080i).
What kind of signal you are feeding your TV with.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 02, 2010 | Televison & Video
How to adjust from 480p to higher resolution up to 1080
several things use hdmi cabling, also change resolution (can sometimes be changed on front of direct tv receiver) or may have to go through menu to change to the different resolutions. also turn the native mode OFF! having the native mode on for directv will give sometimes give you odd pictures. also whatever resolution you choose through directv menu's make sure your tv is also set to the same resolution
Apr 04, 2009 | Televison & Video
BLUE RAY 1080 (p) PLAYERS INHANCE VISUAL HD ON 1080 (i) tV
try to see if u have hdmi slots and check the highest resolution it can go.there is a higher resolution called hdcp,with not div x but dvi-d where resolution can go up to 20000
Feb 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Just got the proscan 42LA45H lcd/tv from sears set it up with the 5 cables for the dvd to work for 1080p but the tv is still at 480 what can i do ?
is your dvd player is a blue ray or hd dvd ? if it is you need to go into the setup menu of the dvd and set it for 1080. if it's just an older dvd player it will be at 480
Jan 21, 2009 | Proscan 42LA45H 42 in. LCD TV
Vizio lcd
This model supports the following formats: 1080i, 720p, 720i, 480p, 480i. Most likely it isn't the TV that is not allowing the 1080i resolution but rather your cabling or the inputs that you are using.
Be sure that that you have an HD signal coming into the TV. You may have to upgrade your cable subscription or if you already have the channels sometimes you have to tell your cable box to use 1080. The same goes for DVD players; they often default to only 480 to maximize compatibility.
The other area to check is your cabling. For the best results use HDMI or Component video.
If you have already checked both of these options let me know & I'll try to come up with some other options for you.
Feb 17, 2008 | Vizio GV42L 42 in. LCD Television
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
Pioneer VSX-816-K/S Receiver Logo
118 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
