Question about TruTech TT320
Wont play dvd
The unit powers up but it sits in the screen saver mode with the word loading in the corner - that is all it does please help
  • 1 more comment
  • cari77 Nov 30, 2007
    may i ask what plug it up means?
  • Anonymous Dec 05, 2007
    Actually my T600-D loads for about 45 seconds and then posts a wrong disc message in the upper left corner. Have changed discs, no help
    Vic [email protected]
  • Anonymous Dec 30, 2007
    My Trutech is displaying the wrong disc message in the corner after spinning the disc for like 45 secs.
I had the same prob. my solutions was to take it to the garage and use the air compresser on it and blew out as much dust and deb. as I could, and IT WORKS NOW.
Posted on Jan 01, 2008
Had same problem... haven't tryed the "shake it up" plan but it has become a handy door stop.
Posted on Dec 22, 2007
Similar problem powers up and spins away but does not play. So I finally relented and took a screwdriver to it - took the back off and looked to see if anything was cracked or broken. Nothing obvious I plugged it in(Children dont try this unless you are smart with electricity) cranked it up pushed all the buttons multiple times and decided to plug it in to the TV.
All of a sudden it worked "Allah be praised" as they say in Iraq..
Anyway was 1hr into movie it stalled - unplugged it and shook unit cranked it up again and it is working- so far.
Ultimate solution is to deep 6 this sucker and spend dollars on a name brand unit Sony Samsung Philips.
Posted on Dec 19, 2007
Plug it up
Posted on Nov 30, 2007
SOURCE:
There are marks on my LCD 42" TV ,its on the screen itself.It looks like water marks.It started of small marks and it then it getting bigger.
Things You'll Need:
  • Burn-In Reduction Screen Saver DVD
  • DVD Player
  1. Instructions
    • 1 Plug DVD player into your TV and power on. Make sure you plug the right component cables into their corresponding inputs on the back of the TV. This is usually done by simply matching the colors of ends of the cables with the colors of the input holes on the back of the TV.
    • 2 Turn TV to the proper input to display the DVD. Make sure there is not a DVD in the player.
    • 3 Place burn-in reduction screen saver DVD in the player. Allow a few seconds for the DVD to start playing. A pattern of white "video snow" will appear on your screen. The entire screen should be taken up with this patterm.
    • 4 Run the DVD for at least several hours; this will help wear the TVs phosphors evenly. Depending on how long the image has been burned into the screen, the amount of time you should play the DVD varies a lot. A good rule to follow would be to play the DVD at least four times the period the image has been displayed. If you have an image that has been on the screen two hours a day for a whole month, run the screen saver for at least 240 hours
Jan 17, 2011 | Televison & Video
Wont play a disc. It will stay in Loading mode for minutes and then read "No Disc"
Try to play a music on cd instead of playing dvd. It it plays keep playing until playey got hot and drive off moisture on circuit. Let it cool down then try play dvd. If it can play severy dvd in sequence, then your unit is repaired. Keep using it to avoid condensation inside the dvd player.
Nov 15, 2010 | TruTech LMD-5702RT Portable DVD Player
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
No screen saver
depending on your tv there is a function to turn screen off. most tvs come with this feature. on the remote there will be an power key with a red or black button. this is to turn the screen off. if it does not have this function and there is no screen saver setting on the dvd play there is not much you can do for this situation .
Jul 05, 2017 | Panasonic DVD-S97 DVD Player
My sony hd dvd recorder RDR-HXD 760 wont turn on or off, it just sits half way and says welcome, have tried holding on/off button down which does work for a bit the it comes back on by itself and goes back...
I had the same problem, my recorder was past it's warranty though. So I opened the case (4 screws on sides & 3 [silver] screws on rear) then unsecured the HDD (4 screws with rubber grommets and 1 screw with thin metal flange) I then disconnected the data and power cable (as illustrated on HDD) powered the whole unit up and got nothing (obviously) reconnected the HDD and plugged the unit in. It powered up and then turned itself off. I then turned it on using the power button and voila, it worked perfectly! All HDD stored videos were still there too! The unit even held the same time.
May 22, 2008 | Televison & Video
DVD WILL NOT PLAY
i have repaired a couple of these cyberhome dvd players-if you are getting a no disc,it is because of a defective disc table motor or bad flex connector(between lens & circuit board).if your unit is not powering up, you should check the power supply board in the unit(.there are capacitors that go bad) i recomend these checks be made by a tech. rkelecworks.
May 12, 2008 | Cyberhome CH-DVD 300 DVD Player
Upside down dvd inserted
FYI - This might damage the unit, but if you really need to get that DVD out then you can try this at your own risk!
Try unpluging the unit, then plug it back in and press the power button and a split second later press the eject button. This all needs to be done quickly otherwise the unit will try to load the disc.
Or
You can try letting the unit load the DVD. When the unit says "Please eject disc. Playback feature may not be avalible on this disc," press the eject button.
Apr 01, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Dual screen car solution dvd player with games
Considering the DVD player is inside of the unit, and the unit will not play a DVD (I am assuming you put in a DVD) while in DVD mode, the conclusion I would draw would be that the unit is defective and should be returned. To give details to this deduction: DVD Mode has power, just is not producing an image. --Known because it can play games.
Jul 27, 2007 | Dual XDVD180 Portable DVD Player
Discs wont play
what is the model and brand of your dvd player kindly post it on this website and please say how long the set have been refusing disc, and how old is the dvd player will be awaiting.you can contact me through fixya or my email [email protected] see ya
Mar 26, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Wont load or eject
I have the same problem! tuner works just fine. I cant access the dvd mode. i can only access tuner, video input, and rear cam. Ive tried different cds and dvds and it did not help. Also it seems like the ejection mechenism is running continuesly.
Jan 30, 2007 | Jensen VM9410 Car DVD Player
TruTech TT320 Logo
Top TruTech Televison & Video Experts
Steve Allison
Steve Allison
Joaquim Martins
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
