Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD860 Once again my Hotpoint has taken to displaying F13 - obviously something to do with the drying cycle, as although it's going through the motions it doesn't heat up at all.  It's out of warranty so Hotpoint want a £90 call out fee up front (which they will refund if the fault is the same as last time).  Of the seven previous call outs most were drying related and I've had a number of new thermistors, even a new drying fan fitted.  I've also experienced the smoke as a result of the drying chamber getting clogged up.  All in all this machine has been a disaster and I will never buy another Hotpoint again.  Is there anything I can do to resolve this myself as I really don't want to donate another £90 to Hotpoint?
  • 8 more comments
  • Anonymous Jan 06, 2008
    Got a WD860 also and exactly the same problems but Hotpoint wont refund the call out even tho its shot to pieces again (3rd time). Same parts same problem always within 12 months and sod all responsibility. Quite frankly not fit for purpose and if I could afford to take it to tip I would. As it is I will source the parts myself (approx £35) and change them myself. Motto...... Dont buy cheap cause you get cheap!
    Replace fanblade( 1604817) T/Stat (1605160) two off and fan motor (1604800). Sounds extreme but costs about £36 and easy to fit.
    Hotpoint wont refund callout charge even tho mine had same fault 3 times all within 12 months of each other. Their engineer basically said the parts dont last and arent fit for purpose really. Motto... Spend more in the first place. Lesson learnt here anyway.
  • Anonymous Feb 10, 2008
    same machine error code f13 what does this mean ?
  • Anonymous Jun 16, 2008
    Dame error F13
  • Skeeto Jul 30, 2008
    Its weird how this F13 error comes up just as it falls out of warranty ! I have had my washer now for just over the 12month warranty period and just now i have had the F13 error come up. Looking in to this on a lot of forums i have found that its just after the 12month warranty. Surely Hotpoint must know about this and should fix them free of charge cause its a design fault !
    Any ideas on how to get this done on the cheap ?
  • Brum45 Oct 09, 2008
    The fault warning F-13 indicates that the dryer is not drying.
    I have same problem, the problem is that the heater fan is held on to the motor shaft with a brass Collete, the motor shaft is steel and therefore the brass collete will expand more than the motor shaft, so the fan starts to move and and friction dose the damage.
    The thermostat that protects the heater from catching fire is a one shot device and therefore needs replacing too.
  • Anonymous Oct 17, 2008
    I had exactly the same problem as you describe.
    I was able to fix this myself, it took about 2 hours, because it was unfamiliar and annoyingly fiddley! I bought the parts - two thermostats for £10 from a 'local' repair shop. From what I’ve read the rule seems to be replace both thermostats to be safe. These components look rather like cylindrical bits of plastic wearing tin hats but one is twice the size of the other, the larger being about 2 cm in diameter, and they DON'T look identical. The part numbers (for my WD860) are: HPT 1605 160 and HPT 1604 802.
    1. You’ll need to use a combination of finesse and brut force to get the lid off of the machine. It is secured by two screws at the rear but has troublesome plastic hooks inside, half way down either side, that stop the lid from riding up at the front. The process is to remove the screws and then pull back and up to ‘unhook’ the internal brittle plastic hooks. I found this scary and difficult, cracking sounds were off putting and I did break to tips of the plastic hooks a little but they still seem to work ok. Be careful and wiggle it gently from side to side is the only advice I can offer.
    2. Once inside it gets a bit easier. You should be able to see a metal snail-shaped object bolted to the top of the drum with various electrical connections – this is the dryer and within it are the two thermostats. What you’ve got to do is remove/unplug all the electrical connections from the top dryer, of course, make a diagram first as you’ll need to put them all back after. You then need to unbolt/unscrew the top half of the dryer and remove this from the machine – this is another fiddley bit and I was lucky again here to have a very small ratchet socket set which made the hard to get to bolts/screws accessible. Note: some of the screws are the Torx type (imagine a more complex Phillips’s type screw). You’ll need to have a Torx type screw driver head that’ll fit the small socket tool to undo these.
    3. Once the top of the dryer unit is off, you just need to remove the thermostats – one is fixed in by screws on the outside of the dryer top and the other is fixed in by screws on the inside. Screw in the replacement thermostats, then clean off the fluff and burnt fluff from both halves of the dryer and you’re there – put the machine back together.
    I did this over a year ago and haven't had trouble since. Mine went just out of warranty too - what a surprise!
    Hope this helps….
    Cheers,
    Lee.
  • 1royp
    1royp Dec 18, 2008
    I have same problem with my machine though not showing F12 fault code. Kept on tripping out main RCD. Disconnected live to dryer element and machine works OK now, just no dryer. Will look at fixing after chrismas, but as for buying a Bosch don't waste your money. You'll only get better quality by buying a Miele, but that will cost you!!!!!!!
  • clio_693 Jan 10, 2009
    i have the same problem, i have had the wd860 for just over 2years and it has been repaired about 15 times! 12 times it has been the dryer problem, i only had it fixed a month ago and it has done it again, the engineer said that it is a common fault, the dryer fan works loose and falls off causing the fluff that gets stuck in the fan compartment to catch fire and because the cooling fan has stopped working it then blows the eliment because it over heats. he joked last time and said see you again soon, lets hope it lasts over christmas, and it did just.
  • newol Jan 23, 2009
    This machine is utter garbage - more F13 than the US Air Force, noisier than night-bombing raids and the filters keep clogging up leaving the clothes dirtier than when they went in. This may be the least fit-for-purpose product ever built!
  • 29 Answers
I thought that when you purchase an electrical item you are covered under the 'SALES OF GOODS ACT'., for at least five years.
If an item is continually breaking down, does that mean it has an inherant fault?
Posted on Jan 21, 2008
    New Friend:
For the error F13 for Hotpoint washing machine dishwasher, I read about the solution of using thermostat as "Oct 17 2008" comment suggested. I must say that I only replaced the thermostat HPT1605160 as I was told this is the one more likely to fail and I did and now it works fine. Only I have to add that the fan shaft was rubbing the shell so I had to adjust it as it was a bit de-ajusted. It took me two hours of work and 5 pounds. Thanks for the advice. Jaime
Posted on Apr 26, 2010
My washing machine WD 860 has 'stuck' with the error code F12.
IT STILL HAS SOME WATER IN IT BUT EVEN AFTER POWERING DOWNE ALL NIGHT I CAN'T OPEN THE DOOR TO REMOVE MY CLOTHES.
what does error code F12 mean? any idea how to by pass it open the door?
Posted on Oct 31, 2008
Hi my hotpoint washing machine flashing f11 which according to book means hotfill blocked how can this be when its cold fill only
also all lghts flashingcant set a programme or empty water can u help thanks
Posted on Feb 20, 2008
Thanks to all for your various comments. I've fitted a new thermostat today. Initially all seemed well - the drying chamber heated up and hot air got into the drum. However, it almost seemed to get too hot and after I'd switched the machine off - to check everything was ok - and switched back on again, it wouldn't heat up. So, I'm now wondering if I've reconnected the various wires correctly (or not), or if it wasn't the thermostat after all. Whilst I'm obviously not remotely technically minded, all I can say re the various connections is I thought I'd put everything back as it should be - I was confident about this given that it only involved disconnecting and reconnecting a small number of wires, and I did this in such a fashion that I didn't have to force wires into positions they previously hadn't been in. Any advice?
Posted on Jan 15, 2008
TAKE IT TO THE LOCAL TIP AND BUY A BOSCH!
Posted on Dec 19, 2007
    Champion:
  • 249 Answers
Well it can only two things, element or stats,easy to do.
Posted on Nov 30, 2007
SOURCE:
F13 ERROR
F13. NTC (Dryer Temp) Open / Short
Check wiring continuity to Control Board.
Replace NTC.
Or, replace Control Board
NTC is the temperature sensor
Jun 22, 2014 | Ariston Technologies Washing Machines
F:13 COMES UP ON THE DISPLAY WHEN THE CYCLE FINISHES. YOU HAVE TO TURN OFF THE MACHINE WHEN IT F:13 IS DISPLAYED AND IT TAKES A WHILE FOR THE DISPLAY TO COME BACK IN THE MACHINE AGAIN.
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
Thanks for using FixYa!!
Jan 09, 2011 | Washing Machines
WASHER GETS F13 CODE AT MID CYCLE
must be a washer dryer f13 means dryer htr faultcheck dryer htr and safty stat not open circuit
Nov 11, 2009 | Washing Machines
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint ultima WD860 machine has stopped mid cycle displaying f-04 I have taken the panel off the back and cleared out the tube from the drum by removinng the clip but this has not worked. On thurning the...
f04 is a pressure switc problem.
take the lid off and check the clear plastic hose is attached to the bottom of the pressure switch, a round part with wiresand the other end to the sumps breather tube.if it is and there are no holes or splits in the tube it may need replacing.
Feb 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Utima WD860
The error code F13 is indicating dryer thermistor open or short circuit.
This is located in the top of m/c, and it looks something like a thermostat wired in series with the element, if there is more than one, then it is advisable to replace both..
Plz rate my solution.
Thanks.
Jan 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Fault f13
Hi. F13 indicates dryer fan motor or thermistor problem
If you can't hear the fan motor running on the dry cycle then it is probably faulty.
Hope this helps.
Please feedback.
Thanks
Nov 13, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD72 - error message heating or Heater
Do u want to resolve the f-13 fault code ON HOTPOINT WD860 Ultima
Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 pounds sterling from Hotpoint or other spares stores. hotpoint-wd72-error-message-heating-or-04t3bj0jgktmuqmnt3s3ejb0-2-0.jpg hotpoint-wd72-error-message-heating-or-04t3bj0jgktmuqmnt3s3ejb0-2-2.jpg hotpoint-wd72-error-message-heating-or-04t3bj0jgktmuqmnt3s3ejb0-2-7.jpg
Nov 01, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WD860 problem
washer wf860 showing f07 error. why
Mar 04, 2008 | Hotpoint Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
3,024 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
