Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Capacitor assistance required.
My son & I have been doing lots of reading and are anxious to try to our fix, but need a little advise. Our WD-52525 has a couple bulged capacitors on its front circuit board which we would like to try replacing, but we are aprehensive about the terminology when we found 4 different capacitors at the vendor with identical specs. The old ones were labeled: "3300mf10v nichicon H0427 105C" next to "C9A38" on the board. We narrowed the search at down to 4, so we purchased a e-service manual & found their reference (more numbers) that did not help us to select the replacement. The 4 different capacitors we found on were all the same specs except for they were under 3 different categories. One said General Purpose, one said Miniature, and two said Low Impedance. If somebody could help us out here, let us know which piece would work we would sure appreciate it.
  • Anonymous May 31, 2008
    I have been reading the description of your experiences with this model. I
    purchased one from a friend for 200.00us broken and thought the capacitors fit the symptoms. I replaced them with higher temp 125 deg mil spec caps from newark electronics ( The caps in my set were not the same brand but had failed in the same way. This made me suspect A design issue rather than defective parts. I replaced the 3300mfdcaps and the 1000mfd caps . I spent A little more for parts made in america and mil spec parts but the entire bill was under 15.00us. I also ordered higher voltage 16v caps. The set does not need to come entirely apart to effect the repairs and it only took a couple of hours and the tv works great.
    I will say that I am an electronics technician with many years of experience though not working on televisions. Good luck to all of you
  • radarbob May 31, 2008
    Part Num.
    Quantity .
    Line Price
    Mfr Part #
    Mfr Name
    In Stock
    Aluminum Electrolytic Capacitor; Capacitor Type:General Purpose; Voltage
    Rating:25VDC; Capacitor Dielectric Material:Aluminum Electrolytic; Operating
    Temperature Range:-55 C to +105 C; Body Diameter:16mm; Capacitance:3300uF RoHS
    Compliant: Yes
    In Stock
    Rating:16VDC; Capacitor Dielectric Material:Aluminum Electrolytic; Operating
    Temperature Range:-55 C to +105 C; Body Diameter:10mm; Capacitance:1000uF RoHS
    Compliant: Yes
    ILLINOIS CAPACITOR,INC.Hear is my order i was mistaken i did purchase 15 deg caps and some were 25 volts hope this helps
    Problem Solver:
  • 16 Answers
Ok people lets not make this so difficult.
you need 3300 mfd/ 10 volt electrolytic capacitors.thes are general purpose capacitors. the 105 t C is temperature big deal 85 c or 105 c is fine. try google search for MCM electronics, or Pacific Coast electronics or anybody that sells electronic parts
Posted on Jun 12, 2008
Hi, I have this same model TV, and I the two capacitors C9A37, and C9A38 are both bulge up, so I am going to replace them. I was just wondering if anyone knows the digikey part number for these capacitors? I can't seem to find them. Thanks in advance for the help.
Posted on Jan 16, 2008
  • 1,153 Answers
(Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002)
Posted on Nov 30, 2007
WD-52525 will not turn on, Flashing Red light.
if that is a dlp tv . not shure just by model. but if it is then they do have a lot of problems with vented filtor capacitors on power supply and other boards. magor work unless you replace chassis. but the very first thing to try is lamp and make shure cooling fans and vents are clean. J.D.W.
Jun 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
How to change a bulb WD 52525
the speaker grill pops off and use a philips screwdriver to remove to door slightly left of center. the lamp is held in with 3 screws, might need a flat head driver to get em moving. this tv is known for bad capacitors on the power board causing false lamp errors, and also other caps going bad too. let me know if you need more assistance. fixing all caps = 300-500 $ estimate
Jun 01, 2010 | Mitsubishi WD-52525 52" Rear Projection...
no you cannot substitute a 680uf 16v 105c in place of a 1000uf
if you want to put a better capacitor in place of the old 1000uf 16v 105c , then use a 1000uf 25v or 35v 105c
the voltage rating will allow the cap to better handle the circuit
Apr 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 Replace Chassis
you can call mitsubishi to check on that part that they fix.
mitsu required to send the chassis for rebuilding because its NLA.
call mitsu for further assistance on this
Jan 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 error code 34
replaced 2 capacitors 3300u/35v. At the power board.
do not tuch the rest of the chassis...............
Nov 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Capacitor help.
Just unsolder the ends of that capacitor and the board will be marked so you can install the replacement capacitor with the correct polarity.
Aug 08, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 too much green and picture is not clear...what can i do to fix it
. Suspect the FMT PCB part # 930B924002. Supect the DM PCB part # 934C116002 if green tint
Aug 04, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,060 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
