Question about Toshiba 32A43 32" TV
High-pitched whine After power on (1 or 2 minute(s)) with the volume at 0, a high-pitched whine begins then fades away and begins again. After about 15 minutes it stops. It seems that the whine also lowers in frequency sometimes
    Genius:
  • Toshiba Master
  • 1,691 Answers
The wining sound is most likely from one of the inductive reactive devices. These can be chokes or tansformers in the scan circuits or the power supply.
There are very high frequencies used in the ultra-sonic range for the switching power supply, and the transition times for the scan amplifiers and high voltage section are in the ultrasonic range. What you are hearing is something that is resonating with the magnetic fields generated by these high frequency devices, and they are making sub harmonic sounds in the audible range.
It is possible that in one of the reactive devices there are some wire turns that are a little loose, or the coil form is not very tight to the core of the device, or one of the near by metal shields is resonating from the magntic field.
There is also the possiblity that the supply voltage to one of the reactive devices is not being properly filtered by a by-pass capacitor and its structure is resonating between the normal power drive and summing with the unfiltered supply to it.
When the set is first turned on it is cold. As it operates its internal temperature will rise. There is expansion and contraction of the various parts. The reactive devices are made with very close tollerance, and their physical characteristics can change enough to allow resonance. If the fault is from a by-pass capacitor, the capacitor may have become thermo sensitive and change its characteristics with temperature.
In the case of a resonating reactive device, sometimes it is possible to fix the problem by re-inforcing the winding to the core if it is accessable. It is not always accessable to do this depending on its design. Then the solution is to change the part. If it is a shield that is resonating, this is usually easier to correct. As for any defective capacitors, these can be easily changed.
It would be best to have a very experienced TV service man look at the situation and spend the time to make a proper evaluation of what the fault actualy is.
I have had this type of problem often. I was always able to find the solution and fix it. Most of the cost of the service was from the time it took to work out the solution more so than the cost of the part, unless it was a major part such as the flyback or the deflection yoke.
Flat panel displays have switching power supplies and are subjected to similiar types of resonation faults with their power supplies.
Jerry G.
Posted on Apr 19, 2008
SOURCE:
Marshall DSL 100 - volume fades away and gradually comes back on
IF this is a vacuum tube unit, these symptoms are that of a tube that the heater is intermittent, that is it cools off due to a break and then liights again.
Open the back and observe the heaters in the tubes. DO NOT be fooled by some that have TWO heaters in them. (use a mirror if necessary) A single one that comes and goes can cause the problem and the voiration can make it come and go. This behavior in a tube is NOT somthing readily spotted in a tube checker. The delay in fading and coming back would be the delay in warm up following a heater going out and cooling.
Feb 14, 2010 | Marshall Amplification Marshall MG250DFX...
Same problem: a high pitch whine after extended driving
Sounds like a dry/failing bearing or power steering pump noise. You first need to try to track down where the noise is originating, and the most likely place is at the front of the engine.
I would start by listening with the hood up while parked with the engine running and the noise present, and seeing if it is coming from there. If so, the most likely cause is something connected to the belt - e.g. AC compressor clutch, tensioner, power steering pump, or generator. Can also be caused by the belt just slipping (warn out belt, tensioner not working properly).
Mar 31, 2017 | 2001 Chevrolet Venture
Monitor making humming noise
First try moving speakers away from monitor a bit. Some speakers magnets actually reduce the life span off monitor. I hope I am wrong but usually a high pitch whine is the High voltage Transformer. Costs more than the monitor. All you can do is continue use till it goes. Speakers usually deteriorate the tube itself. HVT are just one of those parts that go due to use. Hope it gives you more enjoyment before it goes. Good luck and try to have a good day.
Jan 31, 2009 | KDS Visual Sensations 190i 19" CRT Monitor
High pitched whine/whistle on startup - 2003 Toyota Sienna
I have the same problem like yours but what i did is to replace the alternator and now its so quite no more high pitched sound. You may used belt stress fluid but its only last for few seconds then sound comes again. I replaced it with refurbish part alternator.My sienna 2005.
Dec 21, 2008 | 2003 Toyota Sienna
Canon zr100 digital video camcorder won't record or show picture on screen
PLEASE USE MINI DV HEAD CLEANING CASSETTE & TRY , MAY SOLVE YOUR PROBLEM
Oct 20, 2007 | Canon ZR100 Mini DV Digital Camcorder
Possible power supply problem?
Yep i can tell you what it is. The High pitched sound is the power supply soound when its overloaded and thats because the Horizontal output transistors shorted and this happened because of the flyback transformer went bad and /or the horizontal driver coil right off the secondary of the horizontal driver transformer and then the other side of this coil connects to the base of the horizontal output transistor. The part transformer cost about 35 to 45 bucks to the dealer and the transistor cost about 15 bucks. the total repair job cost about 175 to 225.00 after all said and done and some shops even may charge more ad there labopr rates may be higher. Good Luck
May 17, 2006 | RCA F36673ET 36" TV
Toshiba 32A43 32" TV Logo
127 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
