Question about Garmin StreetPilot C330 GPS Receiver
Screen Calibration problem with SteetPilot c330
Recently began experiencing problems with the touchscreen not responding accurately to touch locations near the top of the screen. In many cases this results in not being able to execute buttons or features if they are located near the top of the screen, instead the unit will respond like I touched a control much lower on the screen. It would seem to be a calibration issue, but I cannot find a means of re-calibrating.
  • 10 more comments
  • koosh Mar 07, 2008
    i have the same problem and recalibration did not fix it.
  • Donn2 Mar 15, 2008
    In the opening screen when I tap Where To? it acts as if I tapped View Map. I have to tap about 1/4 inch above Where To to get it to respond properly. Same with letters, have to tap above the letter.
  • Anonymous May 15, 2008
    i have the garmin c330 model . When i touch a letter when typing in an address an other letter appears, I recalibrated it and it didnt fix the problem, Can you help me?
  • uses parenth May 16, 2008
    Touch screen response is inaccurate. Need to touch considerably above letter, number, or option. If desired letter, number, or option is at the top of the screen, it is not poasible to choose it.
  • Anonymous May 18, 2008
    When I touch a letter the next letter appears. It makes it hard to enter any address,
  • vero6 May 24, 2008
    I'm having the same problem, I recalibrated, and cleaned the screen, and that didnt work. Is there another solution?
  • sbedard008 Jun 18, 2008
    I'm having the same problem, I'm recalibrated the screen all the time, keep the screen from finger prints and it keeps loosing it's calibration every couple of days. Is there a way to open this up and fix it from inside ?
    thanks
  • SwimsZoots Jun 20, 2008
    I have a similar calibration problem as the other commenters. However, I cannot reach the calibration screen. From the "off" position, pushing and holding the power button brings up the logo screen and never changes from that.
  • Anonymous Sep 04, 2008
    need to re calibrate
  • mchampneys Oct 13, 2008
    I cleaned the screen, recalibrated and reset the unit, but nothing helped.
  • SwimsZoots Oct 14, 2008
    I eventually contacted Garmin customer service about the problem and had the unit shipped back to them for servicing. It was promptly fixed and sent back to me. One of my better experiences with product service.
  • Anonymous Apr 22, 2009
    I have the same problem too. Mine still have Best Buy extend warranty but they cannot fix the problem. Right now it was the third time back to their service centre. I don't think they can fix either. Anyway don't buy any extend warranty if it is not directly from the manufacturer. Just waste money.................and Gamin ??????????
Turn off the unit. Then hold down the power button for about 1 minute and the calibration screen will eventually come up.
Posted on Oct 13, 2008
Clean the screen, oils from your fingers can cause problems
Posted on Nov 30, 2007
I re-calibrated many times to no avail. Then tried a master reset (press lower right corner of screen) and turn unit on. Continue to press on screen until message comes up that you want to delete all data. Say yes. In addition, pry off faceplate and you will see 4 small screws. I loosened those slightly and that has fixed my problem so far. If you want to preserve your data then might want to try loosening the screws first and see if that works. Good luck!
maddad
Posted on Sep 13, 2009
Try to calibrate the screen with a soft sharp object! try to find the best calibration! And for PNA devices, after calibration you can go to registry, search for "calibration", save coordonates, and then make a .reg file, that load the "calibration" settings into the regs when you start the device!
Posted on Jun 03, 2009
The C330 can be recalibrated by holding down the power button until the calibration screen comes up and then touching the dots on the screen.
Posted on Dec 30, 2007
Touch screen calibration
To calibrate the StreetPilot c-Series touchscreen, follow these steps: Begin with the device turned off and unplugged from a power source Power the device on and continue to hold the power button for 1 minute Release the power button when the screen displays "Press Dot" Accurately touch the dots as they appear The dots will change location A stylus or pencil eraser may be used to accurately touch the dots Touch OK when the "Calibration Complete" appears The touchscreen is now calibrated.
Oct 16, 2013 | Garmin StreetPilot C330 GPS Receiver
Htc prophet touch screen issue
for window phones
1. Press the "Home" key and press "Start." Use the directional pad to highlight "Settings," then press the center or "Enter" button.
2. Use the directional pad to select the System tab. Select "Screen," then press the center or "Enter" button. Select "Align Screen."
3. Using your smartphone's stylus, tap the crosshairs as they appear on your screen. Do this for as many as appear, until the calibration tool finishes. Your screen is now properly calibrated.
for Android phone
4. Press the "Home" button or capacitive area, then press "Menu." Tap "Settings."
5. Tap "Language and keyboard." Tap "Keyboard settings." Tap "Tutorial" and go through the steps that appear on your screen.
6. Once this is finished, turn your phone off and on again. Your keyboard has been adjusted, which activates a re-calibration of the capacitive touchscreen. (Capacitive screens are technically far more accurate that resistive, and so a full calibration tool is not included with Android phones.)
Aug 20, 2012 | imate JAMin Smartphone
Garmin 1300 touchscreen has no response when i press the map button it does not respond, some buttons do respond but most do not, the buttons that do work send me to the incorrect application
It sounds like your nuvi would benefit from a simple screen calibration. You do this as detailed on page 47 of the manual. Since it is a very short procedure - I have transcribed it here for you.
1) Shut off the nuvi.
2) Press and hold the power button for about 30 seconds until the calibration screen appears (White screen with press dot").
Simply touch the dot as it moves on the screen. You might consider using a stylus or other relatively pointed object for the most accurate results.
That's it! If this was helpful, please rate it as such. Thanks & good luck!
Sep 29, 2011 | Garmin nuvi 1300 Car GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Calibration is not right on my garmin 330
If you think the touch screen is not responding properly, press and hold the Power button until the
Calibration screen appears. Follow the on-screen instructions.
Aug 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot C330 - screen problem
This doesn't fix Sitfar's problem, but for those how might find this helpful from Garmin's site: Question:  The touch screen is not responding correctly when I touch it. How can I recalibrate the screen?
Answer: To recalibrate the touch screen:
  1. Turn the unit off.
  2. With the unit off, touch and hold the Power button for 30 - 40 seconds.
  3. Follow the instructions on the screen.
May 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
Try to calibrate the touch screen. Push and hold the power button on until you see a white dot on the screen. This is the calibration mode. Touch the dot and another dot will apppear, now touch this dot again, keep doing this until the unit reboot.
If you touch the 1st dot and nothing happens then the digitizer on the LCD is dead. If the unit is still under warranty, get a RMA and return it to Garmin.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Screen Calibration
I'm a french customer with a Marantz RC5400 wich has a screen LCD broken but the touchscreen is OK
I don't have the fix for your problem but I'm searching for a screen replacement at low cost...
If you always have your Marantz with the touchscreen problem, I'm interested for a deal
Thanks
Dec 06, 2007 | Marantz RC5400 LCD Touchscreen Remote...
Touch screen touchiness
Yes! I have an iWay 500C and all of a sudden, it started having serious calibration issues. I try to press a button on it and it thinks I'm pressing something about 2 inches below where I really am. I can't even get to the option to re-calibrate it when it does this, since the recalibration menu option is near the top of the display! I still have to experiment more, but the last time it did this, I think I had success by powering the unit on, waiting for it to finish getting a "fix" on the location (so the processor in it wasn't so busy), and then drawing a few big circles around the display with my finger. After that, it seemed to "snap into calibration" again.
Jul 27, 2007 | Lowrance Iway 500c GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
1,298 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
