Question about HP PSC 1610 All-In-One InkJet Printer
Printer troubleshooting my printer pick paper. if i try to print or copy it says no paper or check
  • Anonymous Feb 22, 2008
    hp 1610 says load paper even when paper is loaded and it want feed the paper so that it can print
  • Anonymous Mar 07, 2008
    out paper even if paper is in
    Novelist:
  • 188 Answers
Hi Nkomo,
Please click on the web link given below and perform the steps provided in the web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00601439&cc=us&lc=en&dlc=en&product=390315
This will fix the issue.
Posted on Mar 21, 2008
SOURCE:
Will not print on regular size copy paper paper gets jam to the right of printer but will print an envelop
hi; try cleaning the paper pick roller and the paper guide and check if it has any foreign objects blocking the paper inside the print hope this help, thanks
Aug 26, 2011 | Lexmark X2600 InkJet Printer
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
Bad print quality
Follow the steps listed below to print the PQ troubleshooting pages. These pages consist of one procedure page and five color test pages.
  1. Print a copy of this Web page and walk over to the printer you are troubleshooting.
  2. Load either 8.5 x 11-inch paper (letter) or A4 in Tray 2 popup_i.gif of your printer.
  3. Press the Menu menu_button.gif button to enter the MENU on the control panel of the printer.
  4. Press the Down arrow down.gif button to highlight DIAGNOSTICS.
  5. Press the Select select.gif button to select DIAGNOSTICS.
  6. Press the Down arrow down.gif button to highlight PQ TROUBLESHOOTING.
  7. Press the Select select.gif button to select PQ TROUBLESHOOTING.
  8. Pick up the PQ troubleshooting pages.
  9. Return to your computer to continue the troubleshooting procedure.
The message PRINTING... PQ TROUBLESHOOTING displays on the control panel until the printer finishes printing the PQ troubleshooting pages. The printer returns to the Ready state after printing the PQ troubleshooting pages.
Feb 17, 2011 | HP LaserJet 3600n Printer
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Not printing
if its in warranty take it back to an epson service site... immediately... or you could buy some ink cartridges... try troubleshooting it and then take it to an epson service site... your pick...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 22, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I have an HP officejet 6310xi that is not feeding the paper through. I can't print or copy anything. I have gone to the HP.com site to try their troubleshooting methods, but nothing is working. I have a...
Not sure if you're saying it's jamming or it's not picking up paper.
If the paper is jamming, this video should help.
If the paper won't pick up, this video should help.
Sep 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Paper mismatch paper size to small choose a large size
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Dec 12, 2008 | HP Photosmart 8250 InkJet Printer
Copystar 1635 copier/printer set up problem
What the problem sounds like is that the machine and print driver are set to diifferent paper types.
One says plain paper and the other bond paper.
Or something like that, the machine says bond and the printer plain paper.
Chech the size setting and paper orinentation.
Most of the time the paper type is wrong. Also check paper color etc etc. Something between the machine and driver is mismtached.
Feb 12, 2008 | Office Equipment & Supplies
Won't pick up paper and won't print
Did you have any recent jams that may have left a bit of paper in the printer?
Apr 24, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
43 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
