Question about Hampton Bay 24002 Ceiling Fan
Wiring a Hampton Bay ceiling fan
I have a Hampton Bay fan, the wiring insrtuctions indicate that I should connect green to ground, white to white and the blue (light) and black to black. This is all understandable, however, I also have a red wire in the ceiling box. It may have something to do with the fact that I have two way switches in the room. On one of the switches I have the on/off toggle as well as a variable speed switch. My question is, what does the red wire connect to?
  • Weak Wire Dec 09, 2007
    Hi Rexter,
    From the wall switch to the fan goes a peach and a red wire. I tested the red wire and it's the hot wire, and this wire also has a splice to feed the light switch to the balcony. The peach wire works like a black wire. I replaced an old hampton bay fan with a new hampton bay one, I wired it the same way as the old one (black and blue from the fan to the peach wire, the white to white and the green to ground). The new fan didn't run at all and now the balcony light doesn't go on also. Help me please!!
    Alex
  • 709 Answers
Hi Rexter,
I would pull the cover off of the Light switch and look at the color of the wire leaving the Variable speed device. I only assume the red wire is from that. I do not like to assume anything. So you must verify that a red wire leaves the Variable speed device. If it does, then i am assuming you dim the lights with this Variable device. The fan has its own built in Variable speed setup. In the case that the red wire belongs to the variable device, wire the Red to Blue(light), and Black to Black Whites to white. Green to Ground. bare wires to ground.
Posted on Nov 30, 2007
    Scholar:
    New Friend:
  • 67 Answers
Usually for lighting. Check with a meter or indicator light to see if the wire receives power when the light switch is turned on. Leave disconnected and insulate with generous amounts of tape or with a twist-on connector if the fan doesn't come with lights. Otherwise, connect to the blue light switch. You can do this more safely by switching off the breaker and using an ohmmeter, but only by opening the switch
We are installed in new fan which is the glendale model what is the purpose of the red wire. Do we connect them with the black and blue wires?
Posted on Jul 06, 2008
I need the wiring schematic for a Hampton Bay 52' ceiling fan with lights, has 2 pull switches and a slide switch.
You should have 5 wires to connect. Green is ground and it may also be a bare copper wire, White is neutral, black and the other are hot, they control the fan and the other controls the light. IF you are hooking them into a conduit box that has white black and ground (which is bare) you hook the grounds together and then hook the whites together and then the other two from the fan connect to the black wire in the box.
Jun 16, 2015 | Hampton Bay Dryers
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
No wiring diagram with fan ( hampton bay three speed fan with light)
white to white, black to black, blue to red, & green to ground.
If you don't have a second hot house wire(red), then put black & blue from fan to house black.
Nov 29, 2010 | Hampton Bay 52 In. Cameron II Plus Ceiling...
I need help wiring my fan. I can't get the fan to work, but I do have the light working. From the ceiling I have a white, black, red and ground wire. How should these wires connect to the White, Black,...
White is your neutral so white goes to white. Blue on the fan is for the light kit you need to wire that to the wire from your switch so it works the lights. Black is the hot wire that is always hot not switched so tie that to the wire that is not on your switch. Green is ground so green to green. white to white / green to green/ black to black/ red to blue/
Nov 06, 2010 | Hampton Bay 24750 Huntington III Ceiling...
I need a wiring diagram of the Hampton Bay fan with light. The fan is black and white and the light has a blue wire. I believe the blue should be tied to the black, am I correct. Thanks
Twist the bare conductors together tightly, matching the black and blue ceiling fan wires to the black power wire, and the white ceiling fan wire to the white power wire, don't forget the green ground !!
Sep 10, 2010 | Hampton Bay 24002 Ceiling Fan
I have four wires from the ceiling fan black white blue orange just 3 wires from the ceiling box white black and ground how do I wire it?
Try hooking up without the oprange , connect the white to white ,.. and the house black to the fan black and blue. The ground will connect to any green or bare wire, and also to the fan mounting bracket
May 18, 2010 | Hampton Bay 24002 Ceiling Fan
I installed a ceiling fan with light, fan works but notthe light.
Are you sure you got the wiring correct?
Ceiling fans usually have 4 wires....a black a white a blue and a green
the black & blue wire from the fan need to be connected to the black wire the white to the white and the green to the ground
Sep 18, 2009 | Hampton Bay 52 In.Carriage House II in...
Ceiling fan wiring
blue would be your earth.
black and white are phase and neutral.
for the wiring in your roof you need to call a local sparky. just ask which is which and connect them appropriately.
Sep 01, 2008 | Hampton Bay 24002 Ceiling Fan
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
1,356 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
