Garmin nuvi 255W GPS Receiver Logo
Posted on Aug 14, 2009
My Garmin nuvi 255W will not go off of the garmin screen....any suggestions
Anonymous
Level 1:
  • Contributor 50 Answers
  • Posted on Aug 15, 2009
Anonymous
Contributor
Level 1:
Answers
50
Questions
Helped
19425
Points
97
You can try plugging it into a computer via usb cable and see if that snaps it out of it other wise try doing a hard reset, you will loose all data but its the only option you seem to have. Hold the bottom right corner of the touch screen and power the unit on. wait until you see the confirm delete and select yes.
3answers
How do i update my Nuvi 255W garmin GPS
To update your nuvi, all you need to do is to connect your nuvi to an internet connected computer and the updates will show on the lower left of your computers screen, click on it and it will update it with the latest software version and maps.
You can also go to your nuvis website and search for latest updates. Just click on the map link and a list will pop up under the map link, select update maps if it is maps you want to update. It will ask you to choose your device from a list, after choosing your nuvi 255w then it will show you the latest maps for your gps, but you have to install its plug ins first.
That is how to update your gps.
tip
Nuvi 255W Change Home Phone Number
Garmin Nuvi 255W Change Home Phone Number
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to edit the phone number entry on your Garmin Nuvi 255W for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
tip
Garmin Nuvi 255W Favorites Backup and Restoration Procedure Models: Garmin...
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Would you like to back up a copy of your Garmin Nuvi 200 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Garmin Nuvi 255W Hard Reset Here.
Garmin 255W WebUpdater here.
3helpful
1helpful
Cracked LCD screen for Garmin Nuvi 255w
Hello
Try here www.satnavrepairservice.com
tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Garmin Nuvi 255W Favorites Backup here.
tip
Download Nuvi 255W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 255 or 255W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
2helpful
2answers
Will not turn on
I have a garmin 255W when turning on all itdoes is go to a white screen with black dot thatsay Press dot .It wont turn on how do you fix this
2helpful
System Software missing
go on garmin's website, hook your unit up via usb and install the latest software.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
