Question about Garmin Quest GPS Receiver
Quest problem i was traveling this afternoon, and the unit screen changed to 'blank', and all I see on the screen no is "LOADER", and below it Loading... Same text as one has when you get a software update. None of the buttons work and I cannot switch the unit off, or reset it.
  • gomrbean Feb 12, 2008
    On returning to my car the Quest showed a blank screen on start up. The power source was checked and other accessories are working. There is nothng on the screen when turned on after being detached from the power unit.
    gomrbean
Holding the zoom in and pressing the power will reset the unit
Posted on Apr 04, 2008
SOURCE:
Quest unit not accepting map info
u need a firmware update i think
Mar 21, 2008 | Garmin Quest GPS Receiver
Display went blank to the calibration screen while traveling
Try using a stylus if you have one or a pen (tip retracted) on the screen. Meaning something finer and thinner then your finger. Don't know why but this works on my unit when the recaibration screen comes up.
Nov 27, 2013 | Garmin nuvi 255W GPS Receiver
Sonim XP3.20 Quest Blank Screen
I have also encountered this problem. It must be due to overloading of the fones ram resulting in freezing
Feb 22, 2010 | Cell Phones
Blank white screen
Try right clicking the shortcut and choose "Run as Administrator". If that doesn't work, post back.
Jun 03, 2009 | Got Game Atlantis Quest for Windows
I have a Hyundai Image Quest L70S, the screen goes blank
hello, mine lcd it is extinguished continually. I have tried to open it and seems us or a problem on a condenser dell' inverter. Someone you would know dirmi where to find the outline in order to understand like repairing it?
Jan 08, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
STREET ADDRESSS SCREEN BLANK
Try removing the memory card, then performing the problematic functions, then shut off the unit. Wait 5 minutes, insert memory card, turn on unit and perform functions again, see if it works.
Sep 08, 2008 | Fine Digital FineDrive 400 GPS Receiver
Screen froze up
"If your Quest locks up....on rare occasions, your Quest may freeze or lock up. In this case, reset the Quest by pressing the unit's Power key and the IN key at the same time. This will turn off your Quest. The unit will operate normally when you turn it on again."
Aug 02, 2008 | Garmin Quest GPS Receiver
Garmin Quest
Hello, I currently own a Garmin quest myself, and some time ago I had some strange problems myself, I am a electronics technician, and I do have a work around for you. I will explain the problems and a cure for you to try, none of the work arounds depend on any parts to be removed.
1. NO RECEIVING SATELLITE TELEMETRY. I beleieve this could be due to a number of reasons, but more so at sometime corrupted telemetry was the problem to fix this,
a turn GPS on when booted (initialised)
b. depress menu
select settings
select Time Setup
when in Time Setup depress MENU
Select SET DATE
Depress OK button
Depress OK button again on the numberic keypad that appears on the screen (DONE)
what this seems to do is resets the internal date/time clock and the unit starts to work again.
the Second workaround is this but takes hours to perform.
Simply turn the Guest on and allow the battery to fully discharge, usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil
Quest .No maps coming up on screen
I already suscribed,and ,no , its not fixed.The person I was assigned had less of a clue than I did.What do I actually get for my $19.99 that I sent on paypal????
Mar 16, 2008 | Garmin Quest GPS Receiver
Garmin Quest GPS Receiver Logo
105 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
