Question about XFX GeForce FX 5200, Graphic Card
Resolution will not change
I just got the geforce fx 5200 and got it set up(I think, it shows up in device manager at least), but when I disable the old graphics card and enable the new one, it puts it in what looks like 600x800 resolution, even though it says it will be running in a totally different resolution, no matter what I change the resolution to it will stay the same, but again says its changing. Also when I try to load up guild wars it will open up and run, but I cant see anything, just the desktop, but task manager clearly shows it running. If anyone can help I would really appreciate it. The same thing also happens when I right click on the desktop then goto to settings > advanced then if I click on the tab that says geforce fx 5200 it will open up, but its like it is opening on another screen or something.(I ahve double checked and those options are all turned off) Thanks again
    Problem Solver:
  • 8 Answers
Well, here is a list of things to try;
If your computer has a built in video card try going into the bios to disable it. Most systems its delete key, F2, F10, or other depending on the brand of system.
If you computer has no build in card you need to uninstall the old card from the device manager, not disable it. You should also make sure to download the latest drivers for it from the Nvidia website. You should also uninstall any software or drivers in your Add Remove Programs.
Once you have done these things you may want to put the computer into a clean boot, normally you wouldn't need to do this but it might help in your case. You need to go to Start->Run->msconfig
Once you have started msconfig you will need to do the following, click on startup, then at the bottom choose disable all, next click on services and choose hide microsoft services, (VERY IMPORTANT YOU DO THIS) and choose disable all.
Now reboot install your drivers that you downloaded from Nvidia Then run msconfig again and choose Normal Startup in the gerneral tab.
This should fix your problem. If this doesn't work you have something else going on other than drivers. You should also check to make sure your power supply is powerful enough to handle that card. I'm not sure but I think you need atleast a 200 watt for that card.
Hope this helps.
Posted on Dec 07, 2007
I have a GeFORCE FX 5200 PCI card, and onboard graphics. I had to restore my system, and cannot find the user manual. If it was available online, I'd follow the steps myself, but I'll settle for a quick...
Hi.
You do not necessarily need to disable the built in graphic adapter, the computer can manage two different adapters.
The nVidia should show picture with standard VGA definition (800x600 only) if simply connected to the AGP or PCI slot even if drivers are not installed, and even if built in GPU is not disabled.
If there is no picture, check installation in slot, check that card is not disabled in BIOS, check video cable is well connected, and if nothing works, test the video adapter on different PC, the card may be faulty.
Here the manuals:
Quick Guide to NVIDIA GeForce Desktop Graphics Processors
GeForce FX 5200/5500/5600/5700/5900 Series
GeForce FX 5200/FX 5600/FX 5900 Series
nVidia GeForce FX5200 Gigabyte GV-N52128DS manual - GeForce FX5200 ...
Sep 30, 2010 | Nvidia GeForce FX 5200 Video Card Graphic
I have a problem with my 3d card driver it shows that it is installed but it does not work proprly plz help me and sjust me what can i do?
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
May 22, 2010 | Nvidia GeForce FX 5200 Video Card Graphic
Hy all! I can't change 1024x768 quality. I have a geforce fx 5200 graphic card and the latest driver.It worked with an oldest driver.
One possibility is that the monitor is not recognized/configured properly, limiting the resolution to VGA or SVGA.
May 21, 2010 | XFX GeForce FX 5200, Graphic Card
If i disable geforce fx 5200 in device manager
Change the vga drivers. To be more specific unistall the drivers, reboot and then install the new ones.
Stelios
Feb 20, 2010 | XFX GeForce FX 5200, Graphic Card
Crashing comp with nvidia geforce fx 5200
your agp video is overheating, see if the cooking fan attached in it is working fine.
Oct 27, 2008 | Nvidia Geforce FX 5200 Graphic Card
My Nvidia FX 5200 doesnt play videos
Hi.
First update your gpu drivers.
Second your computer might be booting using your local gpu and not your FX 5200.
Change the setting's in your Bios.
Tell me if you have further problem's.
Oct 03, 2008 | XFX GeForce FX 5200, Graphic Card
Blank screen
where's that legacy card? integrated into the mb? if so you'll need to enter bios settings and change it from internal to pci. or at least check to see that the video setting is correct b4 looking at the OS.
May 12, 2008 | Nvidia GeForce FX 5200 Video Card Graphic
COLOUR
Have you downlaoded the drivers from the makers website for it? Whats exactly wrong with the colour? Is the resolution set right and the colour quality in control panel/display/settings?
Jan 07, 2008 | Nvidia Geforce FX 5200 Graphic Card
Monitor Resolution
have you tried the newest drivers for your card?
Nov 30, 2007 | XFX GeForce FX 5200, Graphic Card
XFX GeForce FX 5200, Graphic Card Logo
75 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
Sulkhan Abesadze
Sulkhan Abesadze
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
