Question about Acer TravelMate 290 Notebook
No sound acer travel mate 290
I can not get any sound . the volume does not work . and when i go cofiguration pannel you can not do any thing with volume or adjust
the screen
  • melchor Dec 15, 2007
    there's no sound coming out from my speaker
    Problem Solver:
  • 15 Answers
Hi! have you try to system restore? or update windows?
Posted on Dec 13, 2007
  • norman medalle
    norman medalle Dec 13, 2007
    please give me what operating system you are using right now?
SOURCE:
The volume in control pannel is disabled
Go to your system devices on your control panel and enable the sound board. When you click properties, it will show you that it is disable. Just "enable" it there.
Sep 27, 2012 | Acer Veriton 7600G PC Desktop
Hi, I can not use a microphone in my Acer Travel mate 290, It has already reinstalled the XP home edition. I have tried to use a microphone through the mini jack and with USB, and in either case doesn't...
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
don
Feb 18, 2011 | Acer TravelMate 290 Notebook
I have a ACER Travel 290 series. My problem is..everytime i turn the power on, the monitor screen won't work and i can hear the exhaust fan inside working but suddenly after a few seconds the fan stops...
if the initial display BIOS dont open with specifications of pc and after a minuts pc turn off ???
maybe proccesor is burn please consult technicals for check your hardware.
techbelkin
Dec 13, 2010 | Acer TravelMate 290 Notebook
Acer Travel mate 7730 os xp laptop shuts down
make sure processor fan is working fine. you may hear the sound of fan on the left side of the laptop. and make sure its not getting heat soon. If the fan is not working you need to replace the fan. If if gets heat soon that means you have to put processor cooling paste.IF the fan is working fine and the processor heat is normal, then you need to re-fix the RAM. Then it will work fine..ok
Jan 26, 2010 | Acer Aspire 3100 Notebook
Make sure your scsi disk is turned on refer to manualwhen installing windows xp pro, acer travel mate 290. then states use another partition but comes with the same message one of your disk is damaged...
yes indeed nowadays laptops are designed for windows vista and better versions as these are equipped with SATA harddisks. to install windows xp in these systems u need to change SATA settings in bios which can be done by 1->pressing F2/DEL key during the starting acer empower people screen which v get once v switch on the laptop 2->in the BIOS screen go to MAIN tab by pressing right arrow 3->scroll down till u get SATA mode->press enter .two options ll be available 1.AHCI 2.IDE 4->select IDE and press enter. 5-> go to exit tab and select save and exit 6-> now try installing xp pro!!
Jan 11, 2010 | Acer TravelMate 290 Notebook
Acer travel mate after fewminutes enter inhibernation mode what is the problem?
change the hibernation mode in powermanagement option in control pannel
Samson ved
Dec 04, 2008 | Acer Computers & Internet
Acer travel mate 2355NXC laptop --sound driver/software
http://www.acersupport.com/notebook/html/tm230_dl.html
Try the above site contains all drivers for 230 series sound etc
Download and install them
Aug 22, 2008 | Intel Mackie UAD1 Powered PCI Plugin for...
Set up password
go to the control panel and go on to password then choose which password you want and put that in all problem solved
Jan 05, 2008 | Acer TravelMate 290LCi Notebook
Sound problem
- make sure sound is not muted - make all volumes are up to at least 50% fader level - try known working speakers or headphone on the headphone jack
Aug 29, 2007 | Acer TravelMate 2300 Notebook
Acer TravelMate 290 Notebook Logo
105 people viewed this question
Ekse
Alun Cox
