what this indicate is that the phone have develop a problem with it flex that connect the panel unit and the screen together.
What the phone need now to be able to carry out it function again is to replace the flex with a better one you can get the flex from any good phone work shop around your local area.
Sound like you may have a bad board or firmware. First thing to try is to go to sonyericsson.com and see if there is a firmware update online. If you can get it to update that may fix your phone. hope this helps
It might sound absurd but the frantic truth is that the LCD screen of your phone is bad which might be as a result of previous shocks and abrasions which it has been subjected to.This is a common feature of the 9700 bold.
The only solution is to replace the LCD screen of your phone,it cots between 40-79 dollars .
It will need repair, those are signs that the LCD needs repair, it can be the screen or even pressure if the LCD isn't fit in completely tight (they loosen eventually) that would happen.
