Loud grinding noise Toshiba 1550
When turning on our copier it makes a loud grinding noise, can you help me with the problem?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
It is one of three problems,
1- the developper is starting to go bad, unfortunately with toshiba it is a common problem the seals go bad in the unit the gears are very hard to turn giving a loud grinding noise, although you can rebuild the unit by changing the seals, it's VERY messy and they don't always work ( after spending all that time cleaning and changing the seals and gears and it didn't work, I just started to change the DV unit.) Test by taking out and turning the gear by hand, if you need a plier to turn it, it's bad.
2-the toner itself is a problem, take out the toner and look at wherre it sits there is a gear that turns the toner to feed it in the machine, if it's dirty and has toner it will make noise, test by taking out toner and close machine, does it make the noise without it?
3- cleaning section where the drum is, this is what turns to feed excess toner into the small pastic container, aggravating but not a mechanical problem. And also check the fuser ( where it gets hot)
I think I've covered everything for that machine.
Good luck
Posted on Nov 30, 2007
What causes a loud grinding noise when I print?
Howell310,
Can you provide the model of the Dell Printer you have that is making a loud grinding noise. I can the search for resolutions to this issue.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 27, 2016 | Dell Office Equipment & Supplies
Xerox grinding noise
the bearing on the motor or the rotating path must have damaged..
replace them
Jun 02, 2008 | Xerox WorkCentre Pro 215 Printer & Copier...
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
Oct 18, 2010 | Xerox Phaser 6360DN Printer
The dryer is making loud noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
er789
Jun 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Canon imagerunner 1310 loud noise
Hello sir; I suggest reinstall drum unit again ,you will find out what's going on.
Apr 28, 2009 | Canon ImageRUNNER 1670F Copier
Hp all-in-one printer, makes a grinding noise when turn on
My 928 printer makes a loud grinding noise when the ink moves accross to the right hand side, also the red coulor is not coming out onto the paper the cartrige is new
Jul 03, 2008 | Office Equipment & Supplies
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Loud groaning noise when copier is turned on.
sounds to me like the laser unit is going bad. common problem on this model.
razors
Nov 28, 2007 | Copystar CS-1510 Copier
334 people viewed this question
k24674
Marvin
Marvin
