Question about Mitsubishi VS-55601 55" Rear Projection Television
Blue color lamp cannot converge
Can i actually buy this blue lamp myself and installed it on my bog screen projection tv
    Genius:
  • 1,153 Answers
GO TO THE CONVERGENCE MENU (MENU 2 3 5 9) AND CHECK THE ADJUSTMENT SETTINGS FOR CONVERGENCE. IF ALL ITEMS ARE SET AT "127". THE EEPROM SETTINGS ARE AT DEFAULT.
Posted on Nov 30, 2007
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Hi, I have the ws-65907 65", it was working last
No,this problems is not the projection lamp problems.The tv now have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or look like 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like 300-350 for parts and labors.
Oct 26, 2010 | Mitsubishi WS-65907 65" Rear Projection...
I have a 7 year old Sony KP-51W5510 rear projection tv. The right side is all yellow and the left is all blue. In the middle the colors line up but gets worse towards the left and right. My convergence...
No.This problems it not the projection lamp problems.Yes,this problems is the tv convergence board problems,it dead.The tv convergence board the 2 STK covergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the convergence problems.U have tools like a soldering iron,desordering pump,know basic electronic and soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.Or the shop will cost u $300-350 for parts and labors.
Sep 04, 2010 | Sony KP-51WS510 51" Rear Projection...
My jvc tv has a weird color to it and it says replace lamp lite blue is this something i can buy and put in myself?
Yes you can replace Lamp yourself! look on back of TV and write TV model number down. A lamp code can also be found on back of tv or located near Lamp DOOR.Easy replacement!
May 19, 2010 | JVC HD-52G786 52" Rear Projection HDTV
How do I know I need a new projection lamp? My tv
This set does not have a lamp. It has 3 crt tubes that converge to create a color picture. The convergance is off a little causeing this affect. Go into the menu and look for convergence or magic focus. You can download the owners manual from Toshiba website to do this. You will need the remote that came with the set.
Nov 30, 2009 | Toshiba 50H82 50" Rear Projection...
My screen is a yellow green color with a grainy picture. The TV is about 4 years old and has never had the lamp replaced. Will replacing the lamp fix my TV?
Convergence it dead,Know how to solders?Buy a convergence kit,use what in that kit.Tries these websites for the kit,Tv repair World.com,Tv repair kits.
Nov 12, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 27, 2009 | Hitachi 53SBX59B 53" Rear Projection...
There is blue yellow color blur on the screen with cable or dvd
This problem is of "CONVERGENCE". You have to replace the convergence IC's which is better to buy a new one TV, Just contact any expert and replace the convergence IC's and your TV work fine again you need not to buy a new TV.
Thanks for using fixya.
Jul 24, 2009 | Toshiba 42H81 42" Rear Projection...
Bad color
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Oct 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Projection tv
Your TV most likely has one or more possible problems.
  • Screen looks 3D
Sep 23, 2007 | Philips 9P5044C 50 in. Rear Projection...
Televison & Video Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
