1998 Ford Mustang Logo
Anonymous Posted on Aug 14, 2009
The plug is different then the wires ,
The plug is from a linclon , , but it fits , but the colors are different and the wires on the mustang are different colors , they are all red , with different color stripes (yellow, white , green) , thats why i need to know , the order of the mustang wires , every 98 mustang gt has the same wires , proubly 97 too , and maybe 99.. look on the drivers side coil , where the wires plug in , and let me know , or take a picture of it , its not a cobra , just a gt 4.6 2v
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Aug 17, 2009
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
9648
Points
48
Should be the same if your talking about the coil on plug.
On a 2002 mustang gt what color wires goto eack coil 4.6 engine
heres a Schematic for you each coil has a different color for signal side from ecm . but all share power supply source. Ecm sends Negative pulses to individual coils to create spark. good luck
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_9ddabbbc483e2add
First can i replace an ignition control mod u le from my 92 mustang with one from a 93 contour
nope doesnt work that way on EFI engine setups
this link may help http://www.ebay.com/bhp/ford-ecu
see compatabiltiy list ..for the right one ....only mustangs
http://www.ebay.com/itm/1986-2001-Mustang-Engine-Computer-ECM-ECU-Repair-Return-A9L-A9P-/221564555045?fits=Make%3AFord#vi-ilComp
has to be the same ECU controller by model years / same engine mustang
if you try the contour ECU without the wires connected you might cause more faults
1998 ford mustang radio color code wiring
The 2 extra wires are for the Boom Box .
2answers
Changing the factory stereo need the color coded wiring diagram
you can buy,well we can,adaptor plugs to connect to the h/unit and to the wiring loom plug.normally its yellow=constant power 12v +,red=ignition feed 12v+,[some are other way round]black=earth,blue=power antennae,grey/greyblack,RF speaker,white/whiteblack,LH speaker,Purple/purple black,RR speaker andgreen/green black LR,,orange =illumination dash lights.Those are our standard colour codings,we get in New Zealand.
Can I install an aftermarket regular cd player in 1994 cobra
I would advise you to go to crutchfield.com. they have a very large data base and it should tell you what sterios will fit. also they make direct plug in adapters for most cars
1998 mustang gt coil wire diagram
If the colours on the new plug are different,no problem. Just make sure the same amount and colour go back to the original holes/terminals.
If you still need help, you should let us know which engine you have.Also if it is a 2V or 4V.
Need wiring diagram for speakers?
hi there go look at the colours at the rear of the speekers that the factory fitted they should be the same on the rear of the radio that they fitted to. regards John
2answers
Mustang airbags
Very well could But, I would check the Wiring Harness Connection, They could have Changed Between Years. The Air Bag itself will fit Though.
3helpful
2003 ford mustang speaker wire color code
Without knowing which system you have (460 or 1000) I can only suggest going to this web site for more info:
http://www.flemworld.com/Mach460/Mach.html
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
