Question about Tascam 2488 Portastudio Multitrack Recorder System
How do I assign Vocal effects to a track - Tascam 2488 Portastudio Multitrack Recorder System
    Problem Solver:
  • 6 Answers
You assign the effects basically the exact same way you assigned the channels to inputs, except you press and hold the "MICX4" button and press the "Select" key to the channel (or channels) you want to assign the effects to. Once you assign the effects to the channel, you can edit to the effect you want, and edit the values of the effect.
Good Luck!
Posted on Aug 30, 2009
SOURCE:
When I record on track 2 (Adobe Audition) track 1 ALSO gets recorded?
What piece of equipment are you asking about specifically?
Equipment, software, etc.
Feb 08, 2018 | Computers & Internet
I have a Tascam DP-02 8-track all-in-one digital recorder. I've successfully armed and recorded Ch's 1 and 2 to input A and saved the session. When I loaded the session the next day to resume the project,...
i had a look for u on the net only the small yellow ones light up but ill get back to you about the other question as soon as i find a ansew wont be long thanks from chris
Sep 14, 2008 | Tascam DP01 All-In-One Recording Package...
I have a standard DP 02 (non cf) and I want to add vocal tracks to a previously recorded song (tracks 1 and 2) and I don't get any sound from my mic. The mic/line/guitar switch is set to mic/line but the...
you have to make sure the song tracks(1 &2 ) are not armed. then you can assign your vocal to any of the other tracks. after you do this , make sure you arm the track. you should be able to hear your mike.
Apr 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
How can i assign diferent effects to indivdual tracks?
It's tough. For all that TASCAM touts this is not a user friendly system. I find that assigning compression to one track, removes my reverb from every track. It seems only one effect can be used at a time, and that effect effects them all. Tascam sucks. Never again!
May 04, 2010 | Tascam 2488mkii 24 Track Recording...
I need to output guitar and vocal separately. No matter how I hook it up guitar comes thru the vocal channel
Hi there. Use the "pan" pots to assign the guitar to left channel and all other pans to right channel. Also, turn all effects off or down all the way. (Effects return all the way down.
Thanks
Paul
May 03, 2009 | Digi-Tech Digitech Vocalist Live 4...
Guitar effects often disappear after recording
Hi Danny,
You seem to be aware already that the multi-effect acts like a traditional 'insert effect' on a mixer and as such can only be applied to one track/channel at a time (multiple effects / single channel). The problem you're asking about seems to be that the effect is not 'printing' during the recording of your track. Obviously the effect can't 'go away' after recording so it would appear that your guitar effect isn't being recorded (only monitored) when the track is being laid down.
My initial guess here would be that while recording you've been assigning the multi-effect to a channel vs an input. That would explain the effect being audible while monitoring, but the input still being recorded dry even though the effect is heard through the monitors.
So to get this working the way you expect you'd want to insure that you are indeed assigning the multi-effect to input from which your guitar is coming, rather than the track on which it is getting recorded.
Having said that, actually recording dry (like you are doing) and then applying the multi-effect to a new track via a 'bounce' is the way a lot of people (myself included) choose to accomplish this anyway. That way you preserve a dry track and can go back and 'redo' the effect (or choose a different effect instead) later on. It does however introduce another step and use up another virtual track (but the 2488 has 250 of them available which si a big reason the 2488 is so competitive).
Hope this helps.
bd.
Nov 30, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
Using the effects on the 2488 mk 11 for vocals
Use a single effect vice a multi effect and assign it to the channel vice the input and that should get you going. I'm sure you could just set the effect to the input and not the channel but this works for me. If your tracking your instruments/tracks to different channels, and you should be, then assigining the effect to the channel wont hurt you.
Apr 05, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Recorder
if the multitrack doesnt have built in effects you need to but an extrenal vocal effects processor that you can wire up to it. try lexicon products, they offer really good realistic vocal effects rack units.
Dec 26, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
183 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
