Question about MSI K9VGM-V Motherboard
DEFECTIVE MOTHERBOARD? My LG monitor is blank when i turned on my computer. I transferred it to the on-board video card and it's the same. itried it on another computer and it worked. what seems to be the problem. I hope you could help me. TY reyesdick
Got same problem no bips :S everything seems to work but no connection 2 monitor help???
Posted on Mar 05, 2008
  • 1,601 Answers
When you changed the graphics card,did you check the bios for the right video source?
Posted on Dec 01, 2007
0 characters
3 Points
945GCT-M3 motherboard powers up no video on screen
well if you did not remove the video card from the machine then it is still pumping out video on that cards connection. bios will recognize the only working video out but if you have a card in it it will choose the video card over the on board video. So reconnect the old monitor to the old video card and see if it will work. if it does then remove the video card after shutting down and reboot the monitor connected to the on board video. The new configuration should be recognized, then shut down and place the new monitor in the on board video port. now the monitor may need to be told to look at the correct port either digital or rgb.
Jan 16, 2012 | EliteGroup Motherboards
How do i disable the video on board in p4 motherboard
It depends on the BIOS manufacturer but usually you need to enter in to the BIOS settings to change the video settings.
Oct 28, 2011 | ASUS P5GL-MX Motherboard
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
I have an 17" aopen
You've said that there is no start up with your hdd even you hdd is defective your CPU will turn on and have display in your monitor try to turn your computer on then push the button delete or a f1 button it depends on your bios that you have using. If your PC tun and display the bios it means your motherboard is good. Then in the bios set up put it in the main section you will see if your HDD is detected by your PC if not then you HDD is defective o have a lose contact on its connectors.
If you don't have a display try to check if your CPU have a video card. Turn off your PC then pull out VGA connector that are connected to your computer then pull out the Video card in your motherboard which connected to a PCI slot then tun on your pc using the on board VGA connector which is located at the back of your CPU which is beside the parallel port and on the lower of the mouse and key board connectors. If the problem is still there try to clean your Memory cards which is located inside your CPU unit and located at the left side your motherboard and beside your processor. Clean it with a pencil eraser. Then put it again in your motherboard. If problem is still there. Try to check your power supply may it dropping voltage where the did not full fill the requirements of your computer. Hope this will help.
Jul 18, 2011 | Motherboards
Upgraded power supply, upgraded to AMD 965 Quad core, Mother board stops at error C5, monitor blank during this. C5 error says reset video controller. HOW?
try this: 1. turn off the computer 2. disconnect the VGA connector (the cable from the monitor) 3. remove the video card from the motherboard 4. the motherboard has the on board video controller, connect your VGA monitor to that slot. 5. turn on the computer, I hope by now your monitor is ok ;-)
Feb 03, 2011 | Jetway Motherboards
I attach my monitor and turn the machine on and I get a black screen. When I pull the monitor cable out of from the monitor connection on the motherboard I get a color display on the monitor. What is...
When you disconnect the monitor cable, the display you see is from the monitor itself. It's telling you that the monitor has power and is working, but that you don't have the cable connected to your computer. So the trouble is in your computer, which isn't sending anything to the monitor.
Your computer may not be starting up when you turn on the power. This is pretty common, and may be due to a bad power supply or system board. Or something may be wrong on one of the devices connected to the motherboard (one of the drives or a card plugged in to an expansion slot). You'll need to figure out what is keeping the computer from starting. The easiest way is to unplug all devices from the motherboard except for the power supply and try starting the computer. If the computer starts up you'll know that one of those parts you disconnected is at fault.
Another possibility is that the video card (integrated video on the motherboard in most computers, or a separate card) isn't working. The computer may be starting up and getting in to Windows, but you just never get any video to the monitor. If you are hearing all the sounds of a normal startup (disk drive activity and then finally whatever startup sound your Windows makes), then you need a new video card. If the board has integrated video you just need to install a new plug-in video card of whatever type fits the available slot on the board.
Good luck and thanks for using Fixya!
Dec 14, 2010 | FIC VL35G Motherboard
Installing the video card driver can make use of its features of higher resolution support for your LCD monitor.
And also install the driver of your LCD monitor. This enable to use higher resolution that could provide with your computer video card as I have mentioned above.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 05, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I just bought my 875WP1-E and hooked the monitor up to the onboard video port and when I power up the computer the monitor just says "no signal." What's up?
This is due to your system is not switched ON or not properly configured. Follow the below steps will resolve your problem.
1st Step: Have you hear any beep sounds? If yes insert the memory modules properly.
2nd Step: check whether the keyboard lights are flashing while switch on the system. if no, check the SMPS or SMPS connections.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Feb 20, 2010 | Intel Server Board S875WP1-E Motherboard
hmm...try check your Video Card...maybe the problem is in video card try using eraser use it!!
or something wrong in the board try buying a new one ^_^
Sep 03, 2008 | ASUS P4VP-MX Motherboard
MSI K9VGM-V Motherboard Logo
140 people viewed this question
Top MSI Motherboards Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a MSI Motherboard Expert? Answer questions, earn points and help others
