Question about Nokia 6670 Cellular Phone
Mobile problem 1100 buzzer problem
  • 4,102 Answers
Is the phone making a buzzing sound if the sound is loud enough to hear without getting to the phone then the problem is the speaker needs replacing this is a common faul with nokias let me know if this is the problem
Posted on Dec 01, 2007
SOURCE:
I have undone the casing but not sure what wire to cut scared in case I do more damage lol
and the mobility scooter is ?
Regards
Rob
www.gewizrepairs.co.uk
Apr 01, 2015 | Health & Beauty
Stop buzzer
hi , they' re a standard buzzer....maplins sell them....
Regards
Rob
May 20, 2014 | Pride GoGo Elite Traveller 12amp Mobility...
Security code 1100
Hi if you forget the security code of your Nokia 1100 mobile .Then try default code like 0000 or 1234 to reset your mobile if it didn't help you to reset your mobile .Then visit Unlocking4free.com here they generate master reset code for your Nokia 1100 mobile at free of cost .After resetting your set new security code.
May 17, 2013 | Nokia 1100 1101 1108 1110 1112 1200 1208...
Nokia 1100 mobile security code i put personal password but now i forgot that pass word wat can i do
If you forget the security code means get the master reset code for that one, master unlock code is a code that completely resets your phone, removing any security locks , get the code from this site http://www.unlock-free.com/nokia-master/ , it has the best services for the master reset code for your Nokia 1100 model mobile.....I hope that it may helpful to you....
Dec 20, 2011 | Nokia 1100
Ringer buzzer not supported
I think there's no such error message on this phone,if the buzzer or ringer does not work,it can be fix by this steps.
* Remove the front cover of the phone
* unscrew 6 screw using T6 precision screw driver or anything that can release the screw up
* lift up the entire module(mainboard and the frame)
* upon separating the module,you see a circular object attach on the back housing,that is the buzzer we are looking for,check if it's clean and the pin are well align and proportion.
* on the mainboard,clean the buzzer interface where the buzzer pin is connected,you can use a cotton and any rust solution.
* now assemble the phone and try if it's ringing now.
Otherwise,you need to buy a spare buzzer,can buy on any mobile shop if they sale the parts,or else let them fix the problem to make sure it is.
Thank you for visiting FixYa...
Aug 16, 2011 | Nokia 2626 Mobile Phone
1100 nokia no ringtone pls help me
There are times when the phone dropped on the ground,the buzzer mechanism sometimes dislocated,and when damage by water,corrosion gets along the buzzer interface.
To be able to fix this problem,you can DIY
* remove back cover and the battery.
* remove front cover
* unscrew 6 screws on all edges using T6 precision screw driver or any tool that may release the screws.
* lift up the entire module (lcd frame and the mainboard)
* you can see a small round circle on upper part attach on the back cover.seems to be the buzzer or speaker.
* clean and re-align the pins of the speaker or buzzer,make sure that the metal pins and the board interface are well clean.
* assemble the phone and be guided from what pattern on dis-assembly.
If still does not work,might need a buzzer replacement or fixing the board components,you can ask assistance to any mobile service shop near you.
Hope that this method helps you. Thank you for visiting FixYa.
Jul 10, 2011 | Nokia Lands Phones
My phone doesn't ring it only vibrates
change buzzer or check if not connect to the buzzer pad.
Sep 23, 2009 | Nokia 1100
Ringtone to nokia 1100
i don't know but some mobile shops send them with very low prise try to go to a mobile shop they can work this out
Mar 24, 2009 | Nokia 1100
Nokia 100 not ringing
please try to check this connections if are ok
Aug 19, 2007 | Nokia 1100
Nokia 6670 Cellular Phone Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
