Question about Black & Decker (DDCM200)
Locating filter cones
Where I can get the filter cones? Need a replacement.
  • GW Mom Mar 13, 2008
    I too am having problems finding the replacement cones. One of my baskets had a cut in it shortly after purchasing. I returned to store but they were out of the coffeemakers. I have looked EVERYWHERE for these cones or even disposable cones and can't find them.
  • kIMELLE Feb 05, 2009
    # 2 paper will work but not #2 permanent what gives?
You can call 1-800-738-0245 to purchase replacement filter cones. They are part number DDCM200-02. However, sadly in this disposable world we live in, it makes little sense to do this. The filters cost almost $8.00 each, and shipping is about $12.00. You can buy a whole new machine for about the same price.
Posted on Jun 22, 2009
Have 2011 kia forte. it makes this strange grinding noise when you first turn on the heat
You may have squirrels storing food for the winter in your car. Try locating the in-cabin air filter(usually located behind the glove box on most cars) and remove the access panel and filter. The fan is most likely below the filter check to see if there are pine cones, peanuts, or apples in there. Remove debris and replace.
Nov 09, 2014 | 2011 Kia Forte
Driving down the road it dies thinking its the fuel relay.have cleaned fuel tank changed fuel filter twice. when it shuts down stop and let things cool down it fires up and runs again. problems with...
There is a small cone shaped fuel filter located just before the fuel pump. It is inside the rubber hose that attaches to the pump. This is an often overlooked/unknown filter as there is another large one located on the firewall. Most folks change that one without cleaning the cone shaped one. Good luck!
Daihatsu Rocky Parts Northwest
Jul 30, 2011 | 1990 Daihatsu Rocky
I need to know where my maf and tps are located on my 4.6 liter ford f150
what year?
If you have the round cone style filter the MAF sensor will be in the filter housing on the engine side. You should see a wire harness going into the filter housing. The filter housing will need to be disassembled to get at or replace the MAF sensor.
The throttle position sensor will be mounted on the throttle body on the opposite side of there wht throttle cable is attached. It should have a three wire connector attached to it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jun 28, 2011 | Ford F-150 Cars & Trucks
I have signature classics 12 cup coffee maker with timer model# xq626-wt svc code 2764 i can not find a filter for it
http://www.fantes.com/coffee-filters.html According to this link and others, we need to use a #4 filter. I placed my old #2 cone filter in this machine (I just bought it tonight) and it is short about one inch...so the next step up would be a #4. The bottem of the basket that comes out, would lead one to believe it is a cone shape cone. You can also opt for a perminent gold cone filter. But, use the paper one first to be sure of the size. I am getting #4 tomorrow and test this machine out. It has mixed reviews on line. Coffee Maker is the brand name and I only see it sold at Home Depot from my on line searches. Good luck....blkqueentech at yahoo dot com
Nov 13, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
The red light by the on and off switch turned on . what does that mean
usually it indicates a low suction issue. Wether the hose is clogged, or either one or all 4 filters need to be changed. Usually the cone and the circular filter above the plastic cone should be replaced.
Good luck,
Mark
Nov 07, 2010 | Filter Queen Majestic Canister Vacuum
Red light is on my filter queen
The red light on the filter Queen is on to tell you to empty the canister and change the filter. It is a heat sensor that makes it come on and if it is full it gets hot. Also when you take the motor piece off of the bucket under the nylon cone shaped guard that protects the motor there is a secondary filter in there that needs to be changed from time to time and they are supplied with the cones inside the package of rep[lacement cones there should be a spare or maybe two. It is a round thin filter about 3.5 inches across and it just fits in very easily and there is a plastic ring that holds it in place. So pop out the ring and remove the old one and then replace it with the new one put the ring in to hold it...it just snaps into place.replace the nylon guard and put in a new filter cone. Put the machine back together and away you go the light should turn off and you are good to go. Thanks for your time and please try to remember to click on the yes box if this was any help to you at all.
Oct 10, 2010 | Filter Queen Majestic Canister Vacuum
Can't find the filter
Power off the mains, plug off. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip.
And rate me plz……………………….
Apr 01, 2009 | Washing Machines
No suction
Check the main filter cone - if it has a rip in it, then there won't be any suction in it, also clean it gently with a paint brush to get all of the dust out and check the back of the upright after the bin is taken out as sometimes there is dirt clogged at the back. Check the front of the sole plate i.e. where the roller brush is and check the dust channel behind this as it can get clogged. Due to the nature of this vacuum with the hose being located at the front of the floor head dirt can be trapped but most of all its the paper pleated cone filter that needs a good brushing. Hope that helps.
Feb 25, 2009 | Dirt Devil Featherlight Bagless Upright...
Filter queen majestic
Has the cone filter been replaced?
Do you know how to check the grey filter which is inside the cover where the cone filter goes into/
Jun 09, 2008 | Filter Queen Majestic Canister Vacuum
Black & Decker (DDCM200) Logo
197 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
jason
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
