Plasma TVs have no T'Con board. Only LCD TVs have. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
One of my EDTVs has the same issue, though on a much smaller scale (it doesn't degrade the picture at all; it's only noticeable when the top of the screen is black, and it doesn't go down very far). Online reviews of the TV showed me it does have this problem commonly, so yours may too. It must be something you need to get it serviced for.
I have Sony Dcr -hc15e is not display on the lcd screen any help? The screen shows plain white . help pls But i left it unuse for month and the screen swore up a bit with black ink in the middle when it display plain white any way to replace the screen?
if you have a Sony LCD projection ..Theres good chance optical block needs replacing .This spot will get bigger and will eventually cover most of screen the longer you use it .needs repair.If there is no warranty on this unit..I would estimate repair around 6- 8 hundred dollars ..
It sounds like you have a bad Blue Polarizer in the light path. I'm sorry but that is something you will have to contact a service center for. It's not something you'll be able to do yourself, I'm sorry, but that's the best advice I can give you.
those black holes come usually from a decay in the LCD(from age, like age spots, truly) or something was pressing on the screen..LCD replacement in either case.
I would suggest to try to get this TV fix while still under warranty. Normally the manufacturers give one year.
In regards to the discoloration, there is not much you do but to let the Sony authorized repair center knows about it so they can fix it. Ask them if their work is guarantee as well for how long.
Good Luck.
