Question about Bosch Axxis WTA4400 Dryers
Bosch classixx condenser drier
Container light on when its empty and drier stopping
  • 2 more comments
  • unclesate Dec 02, 2007
    I have exactly the same problem - and on the same day!
    Container light is on, but container is empty.
    Filter is also empty, as is lintguard...
    puzzled...
  • Anonymous Aug 21, 2008
    I have exactly the same -- Quentin
  • Anonymous Apr 09, 2009
    Thank you very much,
    touch wood it'll last....this solution has worked; as we had the same problem on our Bosch Classixx Condenser
  • Anonymous Apr 25, 2009
    I had the same problem, and followed these instructions and it worked! Thanks to Mr Speedy!
    I would just say that the "plastic box" referred to, seems to be metal on mine, but as it was the only thing that looked remotely like a float sawitch I took the plunge and fingers crossed, we're all good!
  • 3 Answers
The problem is with the lower water tank float switch, it is stuck. Take off the right hand side panel (as you are facing the machine) at the bottom you will see a spring mechanism for the belt tension. Beside this there are 2 electrical connectors. Take them off and spray with wd40 or similar. Whilst off give the plastic box they fit 2 a light tap with a hammer to free the float switch. Reconnect and try. If this fails you can over-ride by leaving the left hand of the two plugs off. This will get your machine working but you will not have an indication as to when the water container needs emptying so you will need to remember.
Posted on Feb 14, 2009
  • RoSG Jul 17, 2011
    Tried this and nearly burnt something out when switched back on (smoke coming out of machine). Dont think it's a float switch in this pition on the Classixx 6, it's a small metal cylinder next to the spring mechanism and presumably the float switch would be connected to the tank (this just has electrical connections on it). Anyway, tried advice from elsewhere and it worked: unscrew back cover and there is a small red reset botton in the middle of the machine. Job done!
I had the same problem, after running for 1-2 minutes the empty container light would come on and the dryer would not heat. Listening carefully I could hear a gurgling noise. After trying Mr Speedy's suggestion I unclipped and checked the end of the drain hose (there is a white right angled connector that directs the water into the tank - it can be seen in the back left of the machine just under the top cover). I pulled the connector off the hose and it was blocked by a small piece of plastic and a collection of fluff that had built up behind it. After removing the blockage and replacing everything the machine works perfectly! Huzzah! Thanks Mr Speedy for your suggestion, it allowed me to fix my problem.
ps you'll need a star-tipped screwdriver to remove the screws securing the top and side panels
Posted on Oct 02, 2009
I have a bosch classixx tumble drier, condensing type. When I try turning it on, select levei of dry. Then press the start button I get a bleep, then the 'drying light', 'iron dry light' & 'anti-crease/end...
Sounds as though you need to unplug then empty the water from the water container & the lint box, then definitely open the bottom flap & by rinsing & drying the condenser box gently to avoid damage use an old tooth brush, once all these are complete plug back in & try again, as it will not reset until all these are empty & clear, hope this helps.....
Jan 24, 2018 | Washing Machines
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
Mar 30, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Our Bosch Classixx Condenser Tumble Dryer works but there is no heat. I have cleaned the Condenser Unit and the filter and emptied the water, but still no heat. Please advise. Thanks Craig
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
Feb 26, 2010 | Bosch Axxis WTA4400 Dryers
Zanussi tc470 condenser drier Red light is staying on even after the water container is emptied. switch appears to be faulty
excess water seems to be lodged in the drier and was drained out.There is a drain at the rear of the machine. I am concidering connecting a pipe here and draining permently to the outside.
Dec 28, 2009 | Dryers
Bosch Condenser Dryer Classixx
I found this on justanswer.com, I am going to try it this weekend and I will post an update.
"Ok if you remove the left hand side panel then located at the back is the drain pump
remove the hose on it which goes up to the bottle and blow up it to make sure its clear.
If thats fine then remove the pump and clear any fluff thats in there and make sure the impeller is ok and turning fine.
Then refit and try again hopefully this should sort it out.
let me know if you need anymore info."
Dec 22, 2009 | Bosch Axxis WTL 6003 Electric Dryer
Bosch classixx condenser dryer won't turn on
try replacing the thermistate fuse link
Dec 04, 2009 | Bosch Axxis WTA4400 Dryers
Bosch classixx tumble dryer container full light keeps coming on which is stopping the cycle but container is empty
This is happening me too. Have you had any suggestions how to solve this problem???
Nov 16, 2009 | Bosch Dryers
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch WVF 2402 Washer Drier Steam Problem
Hello All
Problem solved by clearing out the condensate container which on inspection was full of dried up fluff and dead tissues! This is not a ****that is mentioned in the manual and access to the bin is pretty tricky so I suspect there are lots of machines out there with the same problem waiting to happen.
Access was gained by taking the top of the machine off, removing the dryer motor and then scraping out the muck using a wire coathanger and a vacuum cleaner.
Many thanks
Andy Wray
Mar 08, 2008 | Bosch Classixx WVF 2402 Front Load...
Bosch Axxis WTA4400 Dryers Logo
2,074 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
