Question about JVC AV-30W475 30" TV
No sound, no picture just clicking
Hi!
I have a JVC AV-29VS24. I have owned it for about 2 years now. I have never had any problems with it until today. With the remote, I tried to turn it on and all it kept making was a clicking sound. The power button which is located at the bottom right of the screen now continuously blinks. There is no sound or picture as well. Can you help?
  • 39 Answers
Horizontal output transistor is faulty .
replace it.
Gopal
Posted on Dec 13, 2007
SOURCE:
Clicking on the power supply board(no picture or sound)
If you hear a buzzing, humming or rapid clicking noises this could be a problem with your ballast.Might be a good idea though to pull out your lamp just ensure its not damaged.You can find these at discount-merchant.com
Apr 01, 2010 | JVC AV-48P575 48" Rear Projection...
AV-2053m
My problem is solved!!! I called my neighborhood TV repair shop. The technician suggested I check the Internal Speaker Switch on the back of the TV. And sure enough, I had accidentally move the switch to the OFF position while carrying it from one room to the other. Ahhhhhhhh!!!!!!!!!!!!! my 13 year old JVC is as good as new!!!!!
Aug 02, 2008 | JVC AV-32260 32" TV
No sound on JVC AV-48P575 48 inch rear projection TV
Try going into the menu and find something called, "center channel input." If it is on, the sound will not work. Turn it off, and the sound should be restored.
Mar 23, 2008 | JVC AV-48P575 48" Rear Projection...
Buzzing/Fizzing noise at the back of TV.
Sounds like arcing from the high voltage transformer. i don't not recommend using it until you have it looked at.
Jan 30, 2008 | Televison & Video
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
JVC i art 32" flat screen
Ur video ic inverter board is dead.
U need a new one.
May 13, 2007 | JVC AV-27530 27" TV
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
News ticker off bottom of screen, how to adjust?
sounds like its stretched out just a bit. Do you feel comfortable with messing around inside where theres 100s of volts??? if you do then in the vert curcuit theres a small control called the vert height control right on the printed curcuit board. adjust it slightly so you can see that full pic but not the black partm of the pic. I WOULD HIGHLY RECOMEND thaT if you have no experience with this then leave it to a pro as afterv all they will charge you a minumum beanch charge to adjust the set for you Im sure as it is a minor thing to do. good Luck
May 02, 2006 | JVC AV-30W475 30" TV
JVC AV-30W475 30" TV Logo
119 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
