Question about Canon imageRUNNER 5570 Copier
Image Runner 400
In Ir 400 touch screen not functioning properly. for example on touch screen you want to press 2 sided button then i have to press in surrounding area of that button.
The touch screen needs calibrated in service mode
It is easy to press buttons you shouldnt when in service mode which can cause an expensive service call. Do you have experience working on Canon copiers?
I can help but do not want to cause serious problems...
Posted on Dec 11, 2007
Canon image runner 2525 E000000 after power outage and low voltage. only function working is counter check
Hi.with the copier turned on do the next secuence
press aditional function
press 2
press 8
when #sssw appear on the screen search with arrows in the touch panel until CLEAR appear on the screen
press ok once
and search with arrows until ENGINE appear on the screen
press ok once
ERRCLR appears on screen . press ok one more time
turn off the machine from main switch for a few seconds
turn on again and make copy test .
if problem persist replace the fixing heater.
please rate this anwaser if it was useful to you
Jun 11, 2018 | Canon Office Equipment & Supplies
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
Cannon image runner 2525 error code E0000002
on the control panel press:
aditional function
aditional function
should appear ins screen "#sssw"
search with the left arrow until "CLEAR" appear on screen
press ok
search with the left arrow until "ENGINE" appear on screen
press ok
the screen displays: ERRCLR press ok again
turn off the machine from the main switch (located on the left side of the machine) for 5 seconds
turn back on the machine and try to make some copies
if problem persist replace fixing film assembly
Apr 28, 2014 | Canon imageRUNNER 2200
Touch screen on minolta bizhub 200 not working all the time
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 07, 2014 | Minolta bizhub 200 Copier
My canon ir 3300 touch screen panal not working.but matchin is start.only power light(green)glowing.
sol1) In service mode copier- function- clear- error. (Service mode can be accessed by pressing additional functions- 2-8-additional functions in quick succession).This should help
OR
Sol 2) Open the display unit of your copier and take it for dry soldering.
Note:- expert help may be required for step 2. don't try yourself.
Oct 30, 2013 | Canon Ir 3300 B/w Copier image Runner...
How to clear RAM using factory settings in CANON IR330 machine?
ir 330 and ir 400,gp 405 r same machine,turn on the copier when its ready to copy press the additional function then press (2 and 8 both r same time) again additional function when this process is completed copier on the screen select that in the screen find the 'function' select then select on clear in clear menu select one by one err and other all function like dc-con and press ok after se;ect one by one..
Sep 02, 2011 | Canon ImageRUNNER 330s Copier
My new TomTom volumn is too low. How do I adjust it?
The menu button has combo list of all functionality to device.
The procedures of manupulating the device functionality includes;
1. a touch screen button indicating menu would display a list with which to reset system functions; an example of adjustable features include brighteness, contrast, color and volume.
2. a device functionalities are acquired on the menu button, though could include sub menu buttons with lists manipulatable.
3. Locate the volume button after pressing menu, submenu, while perusing th e function options until volume is diplayed.
4. A volume display indication for touch screen devices observable as a long stretch bar with manipulation features describable.
5.A volume display on the tom tom gps could be situated on either vertically or horizontally.
6. A volume bar is manipulate by pressing directly on to the device area of the bar observed and attempting to drag an indication arrow from a graded direction. For example, lowering the volume requires pressign and moving the arrow towards the numerical grades of fewer numbers.
Note: your situation of requirign volumn increase is achived by dragging the arrows towards the numerical grades of higer numnbers to make possible more directional audibility.
For technical assistance, refer to the user guide on how to maniplate volume functionities.
Dec 02, 2010 | GPS
Canon imageRUNNER 5570 Copier Logo
603 people viewed this question
old marine
old marine
