Question about Maytag MER5775Q Electric Kitchen Range
Maytag MER5775QCF Had been working well since we bought it. Went to use the oven, it heated up OK to 375, I put dinner in, about 45 minutes later I heard a noise in the kitchen, it almost sounded like the door lock engaged. I went in & saw an code on the display. It was 88, with the first 8 filled in. I tried to clear it by holding the cancel button down, nothing on the key pad is working, it's not beeping. I unplugged the appliance & left it for about 15 minutes, then plugged it back in again, but the same 88 came up. Would appreciate any advice.
  • 185 Answers
SOURCE: Maytag gemini f1-9 error
plug it back in and press the cancel button
Posted on Mar 31, 2008
0 characters
1 Points
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
My oven is taking over 45 minutes to pre heat
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
Jan 06, 2011 | Maytag Kitchen Ranges
Was cooking dinner, and in the middle of dinner, I walked away and heard a popping sound. I checked the oven and it stopped working. My husband turned the breaker off and back on and the stove top works...
It sounds like the bake or broil element went bad and they will make a popping sound. Usually it is visible on the element that it is bad. You may have to measure the element. It should measure 8-30 ohms if good. If there is no visual sign and you are unable to measure elements keep oven off until a repairman comes. Please rate me after reading this.
Dec 13, 2009 | Kitchen Ranges
Stove control panel not working
You do not have a fuse or overload button on a Maytag cook-top. If you heard a pop, it was the touch pad on your control board blowing out.
Oct 22, 2009 | Kitchen Ranges
Oven heats very slowly
If your top burners work ok, regulator should be ok. Majority of times the fail part in the oven is the ignitor...turn oven on and check for a flame after 10 mins. small flame could mean a bad safety valve.
Jun 09, 2009 | Maytag MGR5870 Gas Kitchen Range
Burners Blew
if you will send me your model number off your serial plate on your range will be on front open oven door or lower drawer some where and when you bought it i need to check the service bulletins before i reply but dont rate me till were done
Jan 02, 2008 | KitchenAid KESC300 Electric Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
141 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
