Question about Whirlpool MH1150XMQ Microwave Oven
Frigidaire PLMV169CD Micowave Hood Vent fan Hums, but won't run
posted by BOB MC on Nov 30, 2007 Report abuse Wasn't sure how to "REPLY" to the below problem & potential solution: First of all, YES, it is the hood fan that I already replaced with no difference. Next, just making sure you realize it is a Frigidaire, not Whirlpool. See below for my comment asking how to get to that "Big starting capacitor"...
Just (attempted) to fix my exaust fan inside my microwave by replacing it.
No dice.
Same thing still happens.
Can hear a humming sound & can actually get the fan to start ( w/ microwave apart) if I give it a little help spinning.
?Is theresome sort of switch that may be n/g?
If so, where?
?Part #
Thanks!
Bob Mc
Comment by BOB MC, posted on Nov 30, 2007 RE: "I would suggest you check the big starting capacitor on the circuit board and the connections on that cap.
How to get to the capacitor?
& since I have no way of actually "Checking" it other than visually, is there an actual part I can replace?
p.s. It is not a Whirlpool, it is a Frigidaire PLMV169cd Microwave.
Do they happen to have that hidden manual as well?
Thanks Again!
-Bob Mc
Still need a solution for this problem?
Try our Premium Assistance plan Solution #1 posted on Nov 30, 2007
By MicrowaveSvc
Rank: Guru
Rating: 87%, 1118 votes
Do you mean the hood vent fan? (That would be a large assembly a little smnaller than a loaf of bread, I guess)
If it's this one, I would suggest you check the big starting capacitor on the circuit board and the connections on that cap.
Or do you mean the cooling fan inside, which would be small enough to basically fit in your hand?
In either case, I would measure the line voltage to be sure it's in the 110-125VAC range.
If it's grossly outside this range, you may have a problem with other electronics or light bulbs bblowing or being dim or erratic.
One handy thing about Whirlpools is that behind the control panel they have a mini-manual which is very useful in troubleshooting
  • BOB MC Nov 30, 2007
    How can I get to the capacitor?
    -Bob Mc
  • Whirlpool Master
  • 9,173 Answers
The starting capacitor will be on the circuit board. It is a non-polarized capacitor (maybe polystyrene?) so polarity is not an issue in this case.
You need to remove the control panel to see it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
I am beginning to suspect that you have a failing relay on the control cirucit board. It may have gotten carbo deposits on the contacts, reducxing the conductivity. This means less current flow and reduced or non-existent fan action.
After you've checked all this, feel free to contact me about a possible repair. We could have you send us the control panel assembly and the new hood fan so we can analyze and repair it. he second link above takes you to our site.
Posted on Dec 01, 2007
    Scholar:
    New Friend:
  • 67 Answers
If you have an old analog multimeter, you can put it across the motor start capacitor and the needle should deflect to low ohms position then ramp up to the open or infinite ohms position. You can remove it and test it the same way. Also, doing this test should store a dc voltage on the leads which can then be read even with a digital multimeter. I have even used an audio output from a cheap amplifier to determine if audio is transmitted from one lead to another. The capacitor works by shifting the starting current by 90 degrees and the motor acts as you say it does if the cap is bad. Make sure you orient the cap properly with the positive and negative terminals in the proper holes
Posted on Nov 30, 2007
3 Suggested Answers
SOURCE:
MicrowaveSvc
  • 9173 Answers
SOURCE: Frigidaire PLMV169cd Microwave Exaust Fan Hums but wont run
One handy thing about Whirlpools is that behind the control panel they have a mini-manual which is very useful in troubleshooting.
It may be that you have some toruble on your control board, which we repair for customers nationwide.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
MicrowaveSvc
  • 9173 Answers
SOURCE: Frigidaire PLMV169CD Micowave Hood Vent fan Hums but won't run
The starting capacitor will be on the circuit board. You need to remove the control panel to see it.
I am beginning to suspect that you have a failing relay on the control cirucit board. It may have arced and gotten carbon deposits on the contacts, reducing the conductivity. This means less current flow and reduced or non-existent fan action.
After you've checked all this, feel free to contact me about a possible repair. We could have you send us the control panel assembly and the new hood fan so we can analyze and repair it. The second link above takes you to our site.
Vent fan turns on by its self and it will not turn off
(I'd say it's a failed or failing thermostat on the control circuit board or the hood TCO / thermal cutout / thermostat)
And if FixYa would inform us experts when as persons responds to a request for more information, we could reply back quickly.
But since (for some reason) they won't, you'll just have to post a new help request.
But please be sure to include the full model number from the tag on the oven, and exact symptoms - what it's doing or not doing, and when.
Feb 16, 2014 | KitchenAid Microwave Ovens
Steam gets in the door and how can we clean and prevent?
This is usually due to incomplete venting or impaired air flow.
Assuming your hood vent exhaust fan is running properly, be sure your grease filter is clean (or if you use a charcoal type, it must be replaced when dirty) and be sure the exhaust ductwork and outside flapper are all clear.
I recommend that you always run the hood vent exhaust fan whenever you are cooking on the stovetop, too.
You can find links to helpful exploded view diagrams and part ordering help here. You can get new filters there, too.
I recommend that you bookmark that link to your favorites.
Jan 09, 2010 | Amana Radarange Microwave Oven
Why does my range hood microwave oven shut off after 2.00 min and takes 20.00min to turn back on?And why is this our second one that has done the same thing?
I would suspect that the magnetron is overheating and that the magnetron's thermostat is cutting power until it cools down.
It may be overheating because the internal cooling fan is not running when you're cooking.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will soon be destroyed.
It may also be that your filter is clogged, or your exhaust ductwork is clogged.
FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted, so please reply directly to me with your full number from the tag on the unit so I can help you with free do-it-yourself tips or an estimate.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Oct 04, 2009 | Magic Chef Microwave Ovens
Ge spacemaker xl microwavejvm1840
It sounds like two separate problems.
1. It sounds like your magnetron is overheating and then the thermostat trips, cutting the power until it turns off, then it closes to power it back up.
It's essential that the internal cooling fan (I don't mean the hood / vent / exhaust fan) is running to be sure the magnetron stays cool.
2. It also sounds like your vent / hood / exhaust thermostat is sticking or the triac on the circuit board is leaky, causing the vent fan to stay on.
But you may want to check the owner's manual. It is designed to stay on if the temperature of the stove top is above a certain level.
-.htmYou can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
-.htmPlease reply back here if you still need help.
-.htmWe're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Noise problem
Do you mean the hood / vent fan? If so, it may be failing, or there may be an obstruction in it.
Yours may have a fan-like stirrer located above the cover in the ceiling of the microwave. Is that what you mean?
Is it heating and working properly otherwise?
Please reply back so we can help further.
Dec 04, 2007 | Frigidaire GLMB209D Microwave Oven
Frigidaire Microwave plmv169dcd Start Capacitor
The starting capacitor is used to start the hood vent fan motor. It's also called the hood capacitor.
On page 8 of the document you refer to above, on figure O-1, you will find the hood capacitor. It is shown on the control unit (circuit board). I've attached a snapshot of that area below.
Its leads connect to terminals A1 and A3. The hood fan red wire goes to A1, and the yellow wire goes to A3.
That part is not shown in this document as a separate part, so you will have to get it generically from an appliance parts store or electronics supplier, but you will have to order it by value.
You need to look on it and it will say something similar to this:
"7 uF 230V". In this example, that would be a 7 microfarad, 230 volt capacitor.
It's okay to get a capacitor with a little higher voltage rating, but not lower.
The capacitor, if truly bad, may not look bad. It can be quick-checked with an ohmmeter to see if it will charge and discharge (the meter will first indicate low resistance then go high to infinity). This is not a full-blown test, but for this kind of capacitor it may be enough.
You should check the solder connections, also. It's a large part, and sometimes they don't get enough solder on them. The connection may be cracked and just need to be resoldered.
Since a new thread was started, it makes it harder to follow along the saga...
But this problem could be a bad (or jammed or obstructed) hood fan motor, a flaky relay on the control board, a bad cap, or bad wiring.
Microwave hood fan motor starting capacitors usually look something like this, and may be red, blue, green, orange, etc.
Dec 04, 2007 | Whirlpool GH7145XF Microwave Oven
"Starting Capacitor"
I just posted an exhaustive answer to this on another new thread you just started. This makes thread number five on this issue.
See: http://www.fixya.com/support/t283240-frigidaire_microwave_plmv169dcd_start
Dec 04, 2007 | Whirlpool MH1150XMQ Microwave Oven
Starting Capacitor
Found this Frigidaire question posted under Whirlpool but I'll be happy to answer just the same.
The starting capacitor is connected to the line level voltage, as opposed to the high-voltage capacitor evryone warns about.
The starting cap doesn't store enough of a charge to worry about.
The main thing is to be sure the oven is disconnected from the power line. I prefer unplugging it, but some installations make that hard, so you need to turn off the breaker.
Hood fan failure can happen due to many causes:
If a cooktop light bulb blows or is removed or installed while the oven is still connected to the power line, that can damage the circuit board in the area.
The hood fan motor wiring can short.
The starting capacitor can be bad.
There may be dust, hair, debris, etc. in the bearings of the hood fan motor jamming it. The filters are supposed ot help prevent this, but things happen.
Behind the control panel on Whirlpools is a very helpful mini-manual that can help you check and diagnose quite a few problems with these.
On some brands it's located on the control circuit board, in others it's mounted on or in the hood fan assembly.
If you post your brand and model we can probably steere you better on a mini-manual and the capacitor.
Dec 03, 2007 | Whirlpool MH1150XMQ Microwave Oven
Nov 30, 2007 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
278 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
