Question about Samsung CLP-600N Laser Printer
Smps fan error - Samsung CLP-600N Laser Printer
  • 12 more comments
  • pmav Dec 08, 2007
    most times when i print, i receive an "smps fan error" message on the display. it is very annoying. i found one place telling me to power off the printer for 10 seconds and then power on again. if the problem persists, you must have the printer looked at by a techniician. i have had this printer for 3 months, and it has been doing it from day one.
    help me fix this issue
  • Maggy Onoferychuk Jan 01, 2008
    I have had the same problem since the printer was 7 months old. I'll be taking it in for repairs. I have been turning the printer off and on again as the printer's troubleshooting advice says to do.
  • Anonymous Jan 21, 2008
    same
  • jsitz Feb 05, 2008
    I am having the exact same problem. Have had this printer for about 6 months, and it's been great until now. I have tried turning it off and then back on after 10 seconds, like the troubleshooting guide suggests. But the problem persists. I suppose I will have to to take it in somewhere. Hoping someone will post a solution soon.
  • Maggy Onoferychuk Feb 25, 2008
    Just want to comment on the solution posted today of leaving the printer off for a long period of time. I wish that were the answer; mine has done this from being first turned on after being off for 24 hours. It has also done it when warmed up. I have found it unpredictable.
    This is my second Samsung printer that has come up with a strange error. The first, a C510, kept saying to change the waste toner container. The message would not go away no matter what we did - yes, of course including putting in a new waste toner container even though the one that had been in the printer was nowhere near full. We looked for answers on line but found nothing that worked.
    I am now using a Brother printer...
  • PH2DCI May 08, 2008
    I have the same SMPS error on a Samsung CLP600n. Having spoken with Samsung techs, they told me it was a firmware error and sent me a file fix to apply to the printer via e-mail. Since then I have had no problems.
    Hope this helps Pete
  • Anonymous May 19, 2008
    ok and the solution is?
  • Anonymous Jul 07, 2008
    We have the same problem. Need to put off the printer , wait some time and put him on en restart again. Can we fix this problem our-selves?
  • vschuster Aug 28, 2008
    SMPS Fan Error
  • Anonymous Oct 07, 2008
    I have the exact same issue. The 'turn it off for 10 seconds' solution that is recommended by the Samsung troubleshooter worked a few times, but now the problem will not go away and I get a little red wrench icon on the control panel.I am going to try the lubing solution this evening, since my machine is about two years old and definitely out of warranty...
  • somnium86 Dec 04, 2008
    My client has the 650n w/ the same problem. I've contacted Samsung about it (calling their tech support is worse than having your gums scraped with a butterknife) but there is no firmware "fix" for this printer.
  • rkkuck Jan 14, 2009
    I have the same problem with the 600N. No wonder the thing was almost free at Staples. I'm still on the original low valume print cartridges. Has anybody tried infusing another fan type into the thing?
  • kdcx Mar 16, 2009
    I had the same problem, now a second time. Taking the printer a part and oiling the fan works.
  • darkridedp May 11, 2010
    I don't suppose any of you guys who got the software from Samsung could post it here?
  • 4 Answers
The SMPS Fan Error is caused by slow or no rotation of the SMPS Fan. The firmware solution from Samsung disables monitoring so if the fan stops the printer will keep working. Thankfully, it's not physically hard to fix this issue though and can be done by removing 9 screws and using a little oil.
I've actually posted a step by step guide to fix this here.
Posted on Aug 15, 2008
This may all be true when you all had the issue - I called this evening and Samsung promptly sent me new firmware to solve this - install was straight forward upload of .img file via web interface update firmware screen. Seems to have fixed issue (Fan is still noisy but no error messages)
Firmware version = 2.23 02-01-2007
Posted on Apr 17, 2008
  • 235525 Apr 17, 2008
    Called Samsung
    They sent Firmware 2.23 02-01-2007
    Uploaded via web interface
    Problem solved
How do I fix SMPS Fan error
Posted on May 05, 2009
My client has the 650N. The SMPS fan error was recurring, despite the fan apparently running at speed. I called Samsung and asked if a firmware 'update' existed for this model, after seeing in the forums that there was one for the 600.
After approx an hour on the phone w/ various people, the answer was no.
Meanwhile, my client emailed the Samsung tech at his address listed in the forums...he emailed back with a firmware update file. Go figure. As an IT consultant, I can guarantee I will no longer purchase or recommend Samsung to clients. Anyway, please see here for the 650N firmware file.
http://siliconmethod.net/firmware/CLP650_V138_EXP.img
I don't know this for certain, but I would guess all it does is ignore the fan. Absolutely do not try this on any other model, it could potentially brick your printer. Of course if you have a different model that you don't care about ruining, give it a shot...I would be interested to know the results. It probably just won't load.
Other notes: use IE instead of Firefox to update the firmware (the update is done via the web interface)...I had some problems w/ FF.
The update takes a surprisingly long time to complete...probably 15 minutes. Your printer will state 'programming' or something to that effect...don't touch it until it says 'reset printer'. Turn off for 30 sec or so, then back on via power switch. Go back to web interface and check...it should now say version 1.38, although I don't believe the date changed. This one stayed at 2006. Good luck, and buy a different brand next time.
Posted on Dec 17, 2008
Even if your printer is out of warrenty, Samsung will send you the firmware upgrade. They will e-mail a zipped file with instructions on how to apply.
Call 1-800-726-7864 and ask for Technical Support. The guy that helped me was Atif Qureshi [aqureshi@sea.samsung.com].
Posted on Oct 31, 2008
    Problem Solver:
  • 9 Answers
I sent the e-mail to Samsung two days ago asking for the firmware patch or the number to reach a live person at their Tech Support. So far no acknowledgment or any messages from them. I guess I will throw the thing away and get HP or Brother color laser.
Shame on Samsung to ignore their customers. I will remember this when looking for new hard drive and monitor next time.
Oh, wait ... I plan to get the new TV this Christmas... Sorry Samsung, you are out of luck...
Posted on Oct 30, 2008
Tie rope to printer and use to anchor sea-worthy vessel.
Posted on Jun 30, 2008
Just hold the menu button until the printer starts to adjust registration. Then, it worked for me.
Posted on May 01, 2008
The SMPS error message occures when you remove the fan at the back of the printer ....
Posted on Apr 21, 2008
I found restarting the print server resolved the issue for me.
Posted on Apr 10, 2008
Throw it away.
I replaced the offending fan. It did not good. The error comes on immediately after the printer has been off over night. If "turn it off" is all Samsung can come up with after all this time, then SamSung really doesn't care.
Posted on Mar 18, 2008
Its a known problem needs to be turned off for at least an hour to cool down
Posted on Feb 25, 2008
OK, now just as I posted my problem, I tried something different. After getting the SMPS Fan Error message, I opened and closed both the manual paper feed tray and the main right-side door (where toner cartridges are inserted). Then, I turned off the printer and turned it back on after 10 seconds. Then when I sent a print job, it worked. I don't know if this is a long term fix (doubt it), but it at least worked this time.
Good luck. If anyone comes up with something more scientific, please post!
Posted on Feb 05, 2008
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
Feb 26, 2013 | Intel DG31PR Motherboard
Tip
How to check the SMPS in Desktop Computer while the system is Dead Condition
1.Remove the all power jacks from Motherboard before check the SMPS. 2.after removing the SMPS then follow the below steps
i) Short the Green and Black wires with a small conductor(wire) in 20 pins jack of SMPS ii)Now plug the main wire into SMPS
iii) On the SMPS Now see the SMPS fan whether it is running or not if the fan will be run then the SMPS has no Problem else SMPS will be Problem. 3.Change the New SMPS with same ratting of Watts
on Apr 17, 2010 | Computers & Internet
Seams like fan not working
if the fan is not working first you have to test the smps remove the smps connector from the motherboard and short the green and black pin it he smps fan is working then the smps is fine coneect the smps connector to the motherbord and switch on the computer still not working then remove the four pin connector from the smps and restart your computer if irts working the problem is in your motherboar
Dec 30, 2010 | Dell (6F858) Cooling Fan
My Smps is ok, when i switched on smps fan and processor fan not on
Check Following Instruction:
1. If your SMPS ok, Check 20 pins cable connect properly to the motherboard, or Fan 4 pin connect to the motherboard.
2. And Start your Motherboard. It will OK.
Apr 13, 2010 | Intel Motherboard
When the computer is turned on the cpu fan spins up and then stops, restarts all over again. The +5 and +12V on the drive connectors goes from 0 to proper value when fan is spinning. I have disconnected...
gud..!! it seems u may b a professional handling power supplies, if u r not refer to ur system admin/a professional....
however, itz quite common smps problem..guess the 'pg(violet +5v)', 'sb(if present, grey +5v)' n +3.3(orange) signals r fine..the problem probably lies in 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
replace the smps with a standby n see if rectified..!!
if itz not the smps, then it must b ur main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above 1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector....
Oct 26, 2009 | Antec SP-400 400-Watt Power Supply
CLP-600N: Will not print. Fan error.
Just need to replace the fan, #jc31-00012c
Jul 24, 2009 | Samsung Office Equipment & Supplies
How to replace exhaust fan on Compaq Presario SR1103VM
what kind of pc are u using plz? is the maain case with screws
Apr 02, 2009 | Computers & Internet
Samsung CLP-600N
Jul 26, 2008 | Samsung CLP-600N Laser Printer
Color Printer fan error
Mar 25, 2008 | Samsung CLP-600N Laser Printer
SMPS Fan error
If the printer runs its adjustment cycle and stops just before printing, it is most likely a problem with a driver. Call Samsung's 800 number. You will need to speak to a Level 2 technician who will send you an e-mail with a zip drive and instructions. One tip: You may have to install it several times before it works. I hope this helps you.
JC
Feb 05, 2008 | Samsung CLP-600N Laser Printer
Samsung CLP-600N Laser Printer Logo
3,348 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
