Sony KV-32S42 32" TV
Problem for Sony KV-32S42 32" TV
Blinking picture
By arinc4 on Nov 30, 2007
After turning on the TV, the picture blinks off and on for awhile until it warms up for a few minutes.
Same Problem
Feb 14, 2009
-   My Sony TV, same model and size, has the same exact problem which started couple months ago ! I thought it was either a TV and/or Cable setup problems, but numerous trial later I still have the same problem !!!-   EPractical
Best Solution
posted on Dec 01, 2007
Helpful)
volts
Rank: Master
Rating: 81%, 13 votes
HI
Hold on a second, if the picture is good when its there then the crt is not bad, what more than likely needs to be done is adjust the Screen Control on the back of the CRT Board up just a tick, I've worked on alot of these tv's and 9 times out of 10 thats the problem, however a qualified tech should do this.
Mark
Was this helpful?
Yes
No
Solution #2
posted on Nov 30, 2007
Helpful)
Terryfic
Rank: Guru  Sony Expert
Rating: 87%, 1710 votes
Common problem on older SONY = BAD CRT ....replace TV.
..........................................T.
Was this helpful?
Yes
No
Popular Solutions for Sony KV-32S42 32" TV
Questions and Unsolved Problems for Sony KV-32S42 32" TV
Do you recommend Sony KV-32S42 32" TV?
Answer
Answer
i have a sony tv it was working fine till last night when turned on the tv picture started to skew... (More)
Answer
Sony Trinitron Model #KV-32S45 Ser#8066618
Answer
I have just moved my satellite receiver and DVD recorder to a new cabinet and upon reconnecting... (More)
Answer
Is this a Digital ready tv? How do i change from cable to antenna/
Answer
recently purchased a kv-32s42 32" at an auction. Tv was working but when we got it home will... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
