Question about Pinnacle Systems Studio AV/DV Version 9 Deluxe (202261744) Audio Input
Pinnicle Studio 9.4 Does not want to open
During the instalation gave me this information:
IDriver.exe - Application Error
The intruction at "Ox7c145b89" referenced memory at "Ox00fbb330".
The memory could not be "read".
Things I did to solve the problem:
Then I unstalled it and reintalled
Formated the computer
Initially this software was working without any problem. Actually I took this out after I bought version 10 Stiduo plus.
  • Anonymous Jun 04, 2008
    it doesnat open
  • 2,794 Answers
This can get ugly.
Pinnacle has a program available on their website called wipe it. It will remove all registry entries from Pinnacle software as well.
The steps to remove Pinnacle software is:
1) Unistall
2) Exectute the wipe it programs.
Then you can reinstall the software.
Posted on Jun 09, 2008
Problem Event Name: APPCRASH Application Name: SBUpdate.exe Application Version: 1.0.3.4
What software by Speed Bit do you have? DAP? The Speedbit updater failed to respond. Go to Speedbit and reinstall: http://www.speedbit.com/video-downloader-converter/
Jan 16, 2013 | Dell Studio XPS PC Desktop
Lexmark X4580 (all in one wireless)
HI,
You can try out these two options one by one to fix it up:
A)
1 Unplug the printer.
2. Uninstall the drivers.
3. Reboot the machine.
4. Go to the lexmark site and download the drivers.
5. Install the new drivers.
B)You will get the "CANNOT RETRIEVE APPLICATION LIST" if your pc blocks the communication from the printer. This can be configured in your personal firewall. This can be Windows Firewall (found in Control Panel, Security Center), Symantec Client Firewall or similar. Depending on the configuration of this firewall you might or might not get pop-up messages from the firewall during installation. These pop-ups will allow you to permanently allow for this incoming communication. But your firewall might be set not to let you decide anything which will typically mean that the calls will be blocked out. This will often be the case if you have a company laptop configured by the company IT dept. You might then have to ask an admin to add exceptions the applications used by Lexmark as the configuration might not be open for you to change.
I think this is the complete list of applications:
Job Status Window Interface: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxdijswx.exe
Lexmark Communications System: C:\WINDOWS\SYSTEM32\lxdicoms.exe
Lexmark Connect Time Executable: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxditime.exe
Lexmark Device Monitor: C:\Program Files\Lexmark 3500-4500 Series\lxdiamon.exe
Lexmark Imaging Studio: C:\Program Files\Lexmark 3500-4500 Series\App4R.exe
Printer Communication System: C:\WINDOWS\SYSTEM32\lxdicfg.exe
Printer Status Window Interface: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxdipswx.exe
Goodluck,
Please don't forget to rate the solution.
Apr 17, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Visual studio instalation problem
just take a look to this site:
http://www.codeproject.com/
you will get your answer there easily.enjoy it!
Feb 23, 2009 | Microsoft Visual Studio® 2005 Professional...
I can't open my ebook library
Here are the instructions by solving this problem:
1. Right Click My Computer
2. Click Properties
3. Click System Protection
4. Click Advanced
5. Under Performances Click Sittings
6. Click Data Execution Prevention(DEP)
7. Click Turn on DEP for all Programs and Services except those I select
8. Click add
9. Under File name: type in ebooklibrary.exe click open.
Make sure that while doing this process your Portable device is connected to the computer. otherwise you will get a message telling you that ebooklibrary.exe file not found. it took me a while to figure this out. I hope that this will help.
Jan 10, 2009 | Computers & Internet
Lexmark 2500
Every time I try to run the scanner or open the imaging studio I either get a App4r.exe or Device Monitor application problem error message
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK
Jun 22, 2008 | Lexmark All-in-One Printer with PictBridge
Pc relocator program
Dear Sir/Madam,
CAUSE loadTOCNode(1, 'cause');This issue may occur if one of the following conditions is true: • The user account that you use to install the game does not have administrative rights. • You have programs running in the background that are interfering with the setup. • .NET Framework is not installed on the computer. • The Windows Installer program that helps you set up the game is not installed correctly.
RESOLUTION loadTOCNode(1, 'resolution'); Locate and then close the files loadTOCNode(2, 'resolution');To resolve this issue, locate, and then close Idriver.exe and Msiexec.exe.
To do this in Microsoft Windows XP, follow these steps: 1. Open the Task Manager. To do this, click Start, click Run, type taskmgr, and then click OK. 2. In the Processes tab, in the Image Name column, find idriver.exe and msiexec.exe. 3. Select each instance of both processes, and then click End Process. 4. Click Yes on each Task Manager Warning popup window that you receive. 5. Close the Task Manager.To do this in Windows Vista, follow these steps:
Windows Vista loadTOCNode(3, 'resolution'); 1. Click Start and click Control Panel. 2. Click User Accounts and Family Safety. 3. Under User Accounts, click Add or remove user accounts. 4. Click Create a new account. 5. Type in the account name. 6. Select the account type: Standard or Administrator. 7. Click Create Account. Select the account you just created. 8. Click Create a password. 9. Type in a password for the user account and an option password hint. 10. Click Create password. 11. Log off your current account, log back in using your new account. 12. Start the installation. Perform a clean boot procedure
Jun 04, 2008 | Eisenworld Alohabob PC Relocator Ultra...
Videosafe drivers wont install fail at 80% "1628 failed"
1. Detect if another installation process is running Press Ctrl + Alt + Del and select Task Manager. Go to the Processes tab. Check the running processes for any or some of these names: setup.exe isetup.exe ikernel.exe msiexec.exe idriver.exe IsUninst.exe IsUn16.exe Uninst.exe Uninst16.exe End previously running installation processes Follow these steps for any of the above processes that are found running on the system. 1.Select each process. 2.Select End Process. 2. clean your Temp directory try reinstall it good luck :-)
Jan 12, 2006 | Zio Corporation CameraMate VideoSafe...
Desktop Software Will Not Load!
The problem that you are encountering right now is a windows problem. "idriver.exe" is related to the installshield application on your computer and installshield is used to install application on your computer, so if idriver is not working, installshield will not work also. I suggest try the windows update. It might fix the problem.
Sep 11, 2005 | Palm Tungsten E Handheld
Pinnacle Systems Studio AV/DV Version 9 Deluxe (202261744) Audio Input Logo
83 people viewed this question
Top Pinnacle Televison & Video Experts
David
David
Daniel Dollive
Daniel Dollive
Greg Ulan
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
