its sounds like the problem is either the power head wire which when your using it and twisting it left and right, turns it off.. Or it could be in the hose where the connect meets with the unit.
Here's a number to call to further assist you. 1-800-322-2965
Hi - there - I am looking for a instruction manual for a Kerrick wet/dry bagles vacuum cleaner - any...
(More)
Hi - there - I am looking for a instruction manual for a Kerrick wet/dry bagles vacuum cleaner - any suggestions of where I might find one?It is 3 years old - I want to know how to use the wet option
My Bosch vacuum is not connecting to the vacuum bag properly any more. Dirt goes into the cannister...
(More)
My Bosch vacuum is not connecting to the vacuum bag properly any more. Dirt goes into the cannister instead of the bag. I've reseated and installed multiple new bags, but continue to get inconsistent results
My wife has a Miele S548 Vacuum. Now when she pulls out the retractable power chord past a certain...
(More)
My wife has a Miele S548 Vacuum. Now when she pulls out the retractable power chord past a certain point, the vacuum shuts off and the built-in LED display says "700". Can you halp? Alan Metzger Glendale, Arizona USA
I have an S548 Aluminum canister vac that's about 6 years old. Tonight while I was vacuuming,...
(More)
I have an S548 Aluminum canister vac that's about 6 years old. Tonight while I was vacuuming, the LED on top of the powerhead that is normally green turned red and the brush stopped spinning.
I took the brush cover off the bottom, took off the top cover, took off the inner cover. The wiring and connections all seemed to be intact. I took the back cover off the neck of the powerhead (where it connects to the wand) and the two yellow wires in there looked good too.
I suspect the powerhead may need a new motor. Can someone let me know what the red light might mean.
Thank you in advance.
