Hello, After many years in the coffee game there are only 3 possible reasons for this, either the water is not heating, this would cause the water to not extract the coffee from the grounds. Or your filter is folding over and the water is running down past the filter....Lastly and the most probable is the spay head is blocked and the water is coming out the over flow if there is one, which is then bypassing the filter. Things to check would be heat, spray head and filter. Hope this helps...Mike
Was this helpful?
Yes
No
Popular Solutions for Krups XP 1500 Espresso Machine
Hi, I just purchased the Krups XP1500 Coffee and Espresso Combi Machine. The coffee side works...
(More)
Hi, I just purchased the Krups XP1500 Coffee and Espresso Combi Machine. The coffee side works great but the espresso side has severe problems. It took 30 minutes (I timed it) for barely enough expresso to fill the bottom of the glass carafe (I wanted to make 2 cups and did NOT pack the grinds too tightly as instructed). Next as a test I ran enough water to make 4 cups of expresso through the machine WITH NO GRINDS AT ALL. 28 minutes later barely a quarter of an inch of water had made it through the machine into the carafe. After this I tried to steam milk ? it was a joke. What?s the story with this machine? I?m sorely disappointed with it?s performance and bought it because I have other Krups products that I like a lot.
I fill the 2-cup thing full to almost the rim, then mash it in using the circle on the end of the...
(More)
I fill the 2-cup thing full to almost the rim, then mash it in using the circle on the end of the scoop thingy. I learned not to smash too hard, as my machine doesn't like that. After it has warmed up, I put the espresso "bowl" thing with the handle onto the machine, locking it in place. I then hit the 1-cup button, and less than 1 shot of espresso comes out before it beeps several times, and the lights flash on and off repeatedly. It seems angry when it does this. I wait a couple minutes, then try again, and finally get a full shot of espresso. What am I doing wrong? I'm just trying to get a double-shot, but it now barely gives me 1. I even replaced the little metal cup thing with a new one, no change. I switched to pre-ground espresso in case it was the grind being too fine, but still not better. Did I buy a bad machine???
My coffee and filter are in place, the water is in, the bottom gets very hot....but no coffee...
(More)
My coffee and filter are in place, the water is in, the bottom gets very hot....but no coffee brews/drips. I need coffee...help!!
