Jenn-Air JED8230 Electric Cooktop
Problem for Jenn-Air JED8230 Electric Cooktop
I have a four wire on a 20 Amp service. I need 110 outlet.
By cloudybay on Aug 14, 2009
I am replacing an in sink erator with a newer model same brand. The outlet in a "v" with stright ground type connection. I need to replace the wall outlet to conventional 110 three wire to match the power cord. The current voltage reads 117V. How do I connect the three white and one black to ground? There are two white on one side. One white on opposite side with black to ground. This is on a 20 Amp breaker.
Thank you
Solution #1
posted on Aug 14, 2009
Not Rated)
dltatsjc
Rank: Wiz
Rating: 94%, 14 votes
4 wire recepticals are used for 220 Volt appliances, there should be 2 hot (117V to ground) and one each Grounding and grounded (read neutral) conductors) Breaker or disconnect should be 2 pole for 220 Volt circuit. A 20 Amp 110/117 Volt circuit would have a single pole breaker or disconnect, one "hot" conductor(should be black or colored , not green or white), one neutral conductor (should be white or neutral with white stripe) and an equipment grounding conductor (should be green or bare copper). It sounds to me like your receptical was wired for 220 V using whatever colored wires were handy. Back up to breaker or fuse (disconnect), and shut off circuit. New 117 Volt outlet will be wired with Black to Brass colored screw (short slot on face), One White wire will be used for Neutral conductor (make sure you know which one it is at the breaker panel) and one of the other white wires may (but shouldent be) used for ground (use green marker to identify it at each end),The third white wire should be removed if you can, otherwise cap with wire nut at each end and coil up in back of boxes. At the breaker/ fuse panel, the Black wire is connected to the breaker (It will be your "hot" lead), The white being used for the Neutral is connected to the neutral buss bar with the other Neutrals, and the green goes to the grounding buss bar (should have other green or bare copper wires. Once all is properly connected and secured but without the disposal plugged in, turn on the power and check for leaking smoke (smoke here is a bad thing) The fuse or breaker should protect your wires and help keep that smoke inside the boxes. Check voltages at the new plug, 117 V accross Short and longer slot, 117 from short to ground (round) and 0 or close to it from long (Neutral) to ground. If voltages check, plug in the new appliance and test.
If in doubt about what you have, dont hesitate to contact an electrician, they get paid for their knowledge and experiance and their ability to keep that nasty smoke inside the boxes.
Good Luck.,
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air JED8230 Electric
Questions and Unsolved Problems for Jenn-Air JED8230 Electric
Do you recommend Jenn-Air JED8230 Electric Cooktop?
Answer
Answer
unit has power, fan works, but electic burners do not come on
Answer
my jennair c301 burners need replacing. which glass burner is compatable
Answer
there is a a clicking sound coming from the knob that turns on one of the burners from my Jenn aire... (More)
Answer
I have a Jenn Air Mod# JED 8430BDS cook top. The range indicates power with the red lights but the... (More)
Answer
we have a n approixately 3 years old jenn aire 36" cook top it takes a very long time to heat... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Cooktop Experts
Top Range & Oven Repairmen
in , IL
(972) 859-0929
Honest, Dependable, Affordable, Available &...
Appliance Parts & Repair Service
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
