Question about Lite On LVW-5045 DVD Recorder
  • AlanY Feb 04, 2008
    I have same problem. Was working ok but suddenly will not recognise any discs including ones from batch previously ok. (Plays DVDs ok)
  • Anonymous Apr 05, 2008
    hi this this dvd player play dvx movies
Common problem probably due to DVD drive gone bad. It can be replaced but not without problems
Posted on Aug 01, 2008
Incorrect disc region code
Look at the region code of the DVD that plays on the vehicle DVD if it is the same of the others that do play it's not a region code issue. If the others are a different region to the DVD that plays or the disc says it is region free. Then you might have a problem with the region code settings on the machine. You can look up the model number of that player to see if you can change the region code.
Otherwise check out the player to see if it needs cleaning or is faulty.
Aug 14, 2016 | Televison & Video
Dvd recorder won't play disc
your recorder will normally give you 5 changes at different regions, and on the last region change that is the one that it stays on, although if you you have never changed the region go to> my computer>right click on your dvd drive>properties and on the hardware tab, your hard drive and dvd drive will show, highlight your dvd drive and click properties and click the dvd regions tab and look at the region to see wot its set at, if you still have 5 changes, it should be set at your region one, if there are no changes left you need to search and download a region free dvd programme to allow any region dvd to be played programme
Jun 10, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
My samsung dvd-hr753 comes up with a message saying ''this disc can neither be played or recorded'' when i put in some pre-recorded dvds... what is causing this? how can i fix it? I thought that the...
use the procedure in the link
You have to enter a code specifc your region.
Using the Remote:
Make sure there is no DVD in it.
Make sure it's in DVD mode.
Turn it off.
Turn it on.
Wait for it to start up (showing DVD mode in the display)
Press Repeat (for a half a second?).
Enter the code for your region
Region 1 use 2,9,3,3,4,9
Region 2 use 5,7,5,3,8,9
Region 3 use 5,6,7,3,2,9
Region 4 use 7,6,8,8,4,9 <----- try this for region free setting
Region 5 use 5,3,8,1,4,9
Region 6 use 2,4,4,6,2,9
When you get to the second to last digit you *may* see your current region.
When you see "9" appear you have entered the code correctly.
Now be quick and eject and close the DVD drive before it vanishes.
Use the buttons on the machine to open/close the drive.
You have to be confident and quick with your button presses; it's very sensitive to pauses etc. If it does not work the first time keep trying.
Good Luck.
Nov 01, 2009 | Televison & Video
What does wrong region mean? the player refuses to read and play certain cd's , it says,"wrong region".
It means The Disk Was Not Created In your country. They do this to make more money. Now if its a dvd player then you may be able to make it region free and play it just give me the model number. But if its a c.d you'll have to use your computer to make a copy of it.
Michael Scott
Jul 21, 2009 | Televison & Video
The lite-on lvw-5115pn
Go to the setup screen;
scroll down to EXIT;
enter the numbers 2960;
a Region Menu screen will appear;
Select "(0)" or Region Free;
then press Setup Screen to exit.
The machine is now Region Free.
Oct 25, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Dvd-p181 - Samsung Region-free
Try this hack as it seems to be another one available for this player and it doesn't include the play and stop buttons.
<DVD> ; press DVD button
<0><0><0><0><0> ; enter 5 times 0
<repeat> ; press repeat button (careful, not <repeat A-B>)
<5 digit code> ; see below, depends on region the player is currently set to
<0 for region free, 1-6 for other region> ; select new region
<open> ; open tray
<open> ; close tray
Now power off/on
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Note: reset player by powering down and simultaneously pressing <power> + <play> until display shows 'reset'.
Aug 17, 2008 | Televison & Video
Not reading pre-recorded dvd's and ocassionally not re-wrtten dvds
Over recent months my recorder has stopped reading pre-recorded disc's and more requently re-writer disc's. I had thought that the region had some how been altered, but not too sure now. Is there a way of checking? Or is there a problem with the laser block. I have stripped the machine down and thoroughly cleaned (but no dust found) and no loose parts. I have reset to manufacture default but this hasn't helped.
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 1 Other User Has The Same Problem Comment by Guest, posted on Dec 19, 2007 DVDR70-051 recorder functions generally becoming more and more erratic. DVD-RW discs I have recorded sometimes say 'disc error' sometimes 'no disc' sometimes start ok but cycles round and round for 5 - 10 mins before stopping, sometimes goes straight into play at last position, won't stop back in menu just goes straight to stndby. Factory reset dosn't help. Wont play pre-recorded discs without going into menu and messing around. It seems to damage or not record RW discs properly a lot of the time. Not even sure if it's resetting to factory settings properly.
Oct 28, 2007 | Philips DVDR70 DVD Recorder
Lite On LVW-5045 DVD Recorder Logo
174 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
