Question about Car Audio & Video
Back up camera
Hi have audiovox ads 10 back up camera system in my camper tv comes on white screen no picture im told its the camera is there a camera to replace this it is black and white als how do u run the cable thu a cealing thats closed in in a motor home thanks
  • 12 Answers
SOURCE: No Picture, sound is all static
CHECK YOUR VIDEO INPUTS. THE HD SIGNAL IS TAKING OVER ALOT OF THE ANALOG SIGNAL.MAYBE A STRONGER ANTENNA OR ADJUSMENTS MIGHT WORK AS WELL.
Posted on May 25, 2006
  • 68 Answers
SOURCE: RCA tv only in black and white?
The route through the circuits in the TV from the various sources all lead to the final video amplifiers for red green and blue. Somewhere along the route is a circuit called a colour switch. This allows colour if the signal is strong enough, otherwise it only allows black and white. This fault suggests a weak video chip which is the one just before the switch circuit. the fault could also be a faulty coupling capacitor to or from this chip, or a low power supply voltage. Check for dry soldered joints around this circiut. Please note if resoldering on new televisions that they may have non leaded solder which requires about 50 degrees centigrade hotter iron.
Posted on Oct 16, 2006
  • 9 Answers
SOURCE: Panasonic TH-42PX60U PLasma - 1/2 screen blacked out
If the screen split is exactly 50/50 top/bottom You are not getting SU or Scan Upper drive.
These are lovely set to work on.
Most likely is SU board itself - Not repairable just to be replaced.
Sorry I work in the UK so I can only guide that the UK part is around £30
SU may have been damaged by failure if the PDP (Plasma Display Panel) but is 9 years only had 2 screens damage the SU board.
There are several setups to do after fitting a PDP. If you don't have the service data - Do not risk it, Reduced life of the Panel and a safety risk.
Posted on Aug 14, 2009
  • 115 Answers
SOURCE: model hln617w. the picture on the screen freezes
Most likely your problem is on the DMD Assy Board P/N BP96-00249A . More presicely there is a few bad electronic components on that board that are bad. That board can be repaired by replacing the bad components (and the other few compoonents that are probly going bad and will soon cause your tv to lockup and lose remote and button functions when it fails so you will need to unplug it to get it on again).
Or the DMD board can be replaced .But it is not a cheap board.
For removal and Installation of the DMD board I would reccomend a tv service person because it is in the heart of the television and there are some adjustements to be made when the new board is installed.
To get the new board you could probably find it by just gooogling the part number.
Component level repair would require some experience in desoldering and soldering SMT,SMD , and or surface mount components.The actual components are about $15.00 total so just repairing your board should cost about $125.00 by a qualified servicer (if you were to remove and install it yourself). This DMD board is used in many models and can a few common problems.
HLM437W HLM4365W HLM5065W HLM507W HLM617W HLN437W HLN4365W HLN467W HLN507W HLN50665W HLN567W HLN617W ( L2 and L5 chassis )
SYMPTOMS:
-Intermittant picture freezing with a negative looking B/W frozen picture.
-Intermittant loss of pic with/without shutdown,abnormal color wheel noise if attempted to start after shutdown.
-lockup of tv control functions . Remote and front keypad do nothing , TV must be unplugged to reset .
-horizantal tearing, distortion , flippnig , solarization , red picture, leading to blank screen and lockup.(tv menu would be affected by all picture defects).
Hope this helps someone..
Posted on Jul 21, 2010
SOURCE: Picture but no sound on my Vizio L37 Flat Screen
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
Posted on Dec 15, 2010
AUDIOVOX fpe3707hr power lights up blue screen but no picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 07, 2017 | Audiovox Televison & Video
My ASTAR 32 inch has no picture or sound for 10 mins on start up. Happens if tv has been turned off for a couple of hours. I get blue screen then snow screen and eventually picture will come up but may be...
This is typical of dried up old capacitors. The problem can be cured by keeping the TV on for days. The moisture in the air will be the cure for the dried up capacitor. It will be good as new if you use more frequently.
Nov 04, 2010 | Televison & Video
Camera has blank white screen + crack from the inside out
The cracked screen is the whole problem Go onto Nikon's web page to get repair information.
Oct 19, 2017 | Nikon COOLPIX L18 Digital Camera
Tv power comes on but no picture th name Audiovox
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 01, 2009 | Audiovox FPE3206 32 in. LCD Television
No picture
Seems like the bulb needs replacing.....
May 28, 2009 | InFocus ScreenPlay 61" Rear Projection...
Black and White on TV
europe uses PAL and not NTSC..change the setting on the TV or DVD player accordingly. Set the TV system to NTSC or the DVD system to PAL
Nov 09, 2007 | Audiovox D1708 Portable DVD Player
No Color on my Audiovox AVT-1498
That model has a history of bad solder connections in various circuits. I would not be surprised if that is the case with the color circuitry. You may get the color to come and go by slapping the sides of the TV or lifting one corner about 1/2 inch and dropping it. If it does, it is a bad connection and possibly fixable. If no change is noted, it could be a bad semiconductor or capacitor, etc., causing the symptoms. For that size set, it would probably be cheaper to replace with a different brand. Toshiba has a nice 14" model IMO.
Feb 11, 2007 | Audiovox AVT1498 TV
Audiovox AVT 1598
The vertical output IC or the vertical circuit is whats at fault. its all solid state and im sorry to tell ya that its not a user replaceable part. This set is probably not worth the repair it would take to get this set working again but please if you like ask a ;ocal repair shop what they thought about this problem.. Good Luck and please dont forget to rate this thread
Nov 11, 2006 | Audiovox AVT1498 TV
T.V. overheating in our conversion van
If you suspect overheating then try removing the back and clean out with a long, wooden handled artists brush. Make sure the children are not about and try it with the back off, but do not touch things inside. You may blow cold air if you see what is overheating. See how long it works OK for. If it works without going off (assuming it was very dusty inside), then replace the back. If it needed a fan to keep it working you may find out what needs replacing.
Oct 22, 2006 | Audiovox AVT1498 TV
Car Audio & Video Logo
116 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
