Question about Philips Magnavox 27MS343S 27" TV
No picture on magnavox hd tv
We have a magnavox hd tv almost 1 year old connected to direct tv. Last nite my wife thinks she did something but doesn't know what so there is no picture. There is perfect sound and the tv guide from direct tv can be viewed. Any ideas what to try?
  • James brown
    James brown Apr 24, 2016
    How do you put picture back in
    Genius:
  • 1,694 Answers
Contact your Direct TV provider = they will refresh your source box...............................T.
Posted on Nov 30, 2007
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
The tv will not show a picture
take a look at this, also make sure your screen is not cracked by using a flashlight and taking a close look
Dec 04, 2013 | Emerson LC320EM2 32" LCD HD Television
What plugs do I plug an xbox360 into on a magnavox dvd player
Jesus, not even the red white and yellow hookups? Oh, man, sorry, but I would need the model of the DVD player...and how did you hook up the DVD player if it doesn't have the red white and yellow hookups? just curious. Also I would highly recommend getting a new TV outright. If your tv is that old, it doesn't have HD, and that essentially defeats the whole purpose of having a powerhouse like the xbox 360. If you want the dvd player hooked up, give me the model number, but if you want a new tv, give me a budget and I am positive I can direct you to something reasonable.
P.S. (being tech savvy isn't a requirement for the newer tvs. in my honest opinion, You have to be a WIZARD in order to get all the inputs to convert to the correct format so it can be displayed on the older tv, so hanging onto the old tv is actually more trouble than a new one. Just saying.)
Feb 11, 2012 | Microsoft Video Game Consoles & Games
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Vs 6041 - no picture day 2 days after installing direct tv
Is it only the input that has the direct tv connected to it that has no picture, or do you have no picture at all on any inputs? If you are able to watch a dvd on say AV1 or input 1 but have no picture on the other input that has the direct tv box connected to it I would call direct tv and have them look at your box. If you have no picture at all then it is your tv. and it being 10 years old it is almost a natural failure a strange occurrence that being it happen right after you got satellite.
Oct 09, 2008 | Mitsubishi VS-6041 60" Rear Projection...
Magnavox 15" LCD TV
If the LCD only has coax, it will never display a HD picture quality. However, the Comcast HD Box will still display a picture using the coax connection. So, you could watch any HD channel, but the picture quality will not be high definition.
Jan 22, 2008 | Philips Magnavox 27MS343S 27" TV
Vertical colored lines on screen-no picture
It's definitely possible. I'd have it checked by a repair center for something like this.
Jun 09, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Philips Magnavox 27MS343S 27" TV Logo
277 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
