Question about Apple iPod nano
FROZEN IN LANGUAGE SELECTION SCREEN
TRIED ALL SUGGESTED RESET / RESTORE OPTIONS. NO JOY
    Problem Solver:
  • 15 Answers
Try reformatting it once, see if that works. if not, the last option would be open it up, disconnect the battery and reconnect it.
Posted on Dec 21, 2007
Why my tablet wont let me select the next button....its frozen
The only thing I can suggest is to disconnect everything and remove the battery for a few minutes. Then, reinstall the battery, connect your cables and reboot, in the hope that everything will reset itself.
Jul 02, 2014 | ASUS Eee Pad TF101B1 Tablet
Tip
How to do Partial Reset for your HP AiO printer
(this includes the HP consumer printer only & does not apply for the commercial ones)
have you een changing with the settings till you found your self lost & can't operate your HP AiO?
you have the option to do a partial reset for your AiO printer which will restore it back to the factory defualt & give you the option to select the operating language & region.
in order to do that, follow these steps:
* unplug the electricity cable while the printer is ON (make sure that there're no jobs pending or working).
* press & hold "3 + #" and plug the cable back, keep holding the bottons till you see "PART RESET" on the screen.
* Select your language & press OK.
* Select your region & press OK.
on Mar 22, 2010 | Office Equipment & Supplies
Wont recognise cartridges
Try hard reset of printer electronics to restore factory defaults. Also reinstall the driver software and see if it now works fine. If still a no go try setting up printer with another computer. If same thing there then the printer definitely has a nasty issue. If so I do not think a repair would be cost effective.
Sep 23, 2017 | Lexmark Z735 InkJet Printer
Phone locked up
To Restore to factory settings
1. From the application menu, Select Settings
2. select SD Card & Phone Storage
3. Select Factory data reset
4. Select Reset phone
5. Enter your password if required, then Select Yes to confirm
To do Hard reset if your phone is frozen:
1. Turn the power off. If your Samsung Moment is frozen, pull the battery out and put it back again
2. Hold the Volume Down button, Call and End until "Samsung" appears on the screen along with a menu
3. Select Master reset device
4. When the phone is done erasing, choose the option to reboot
Once the Samsung Moment reboot it returns back to factory-fresh default state settings.
Feb 21, 2014 | Samsung Galaxy Reverb SPH-M950 Virgin...
Factory reset for Craig 7inch netbook CLP281x how to factory reset laptop restore
On your craig netbook can be resetted or restored to factory settings by following the below steps in order for you to perform the process correctly:
1. power down the device
2. turn back on the net book
3. press f2 at the boot menu
4. select the option to restore your device to factory settings.
Jun 11, 2013 | Computers & Internet
Wi fi not working
restore your iphone using itunes. If you do not want to restore i suggest you to reset the phone - without loosing data option. before doing these 2 i would suggest you to let me kno what kind of error or whats the exact scenario
Oct 14, 2012 | Apple I Phone 4s Verizon Clean Esn...
How do i disconnect and reset my 2gb micro sd sd-co2g japan memory card?
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
if still no joy
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps you
Apr 15, 2012 | Electronics - Others
My nokia 5800 won't show me when I get a new text on my homescreen
have you tried to restart your phone and then uninstall the program? if it still does not work suggest that You could try backing everything up and doing a master reset, but back everything up first (its so important I said it twice). to do master reset just dial *#7370# and accept. after the master reset you can restore your files by restoring it from the back up.
i hope it helps! =)
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Dec 13, 2010 | Nokia 5800 XpressMusic Smartphone
My Nokia 5800 doesn't display's the message i receive in homescreen neither rings... What i have to do to fix it?
i hope it helps! =)
Nov 27, 2010 | Nokia 5800 XpressMusic Smartphone
My nokia 5800 when i turn on bluetooth hen it shows unable to perform bluetooth operation.PLZ HELP ME
have you tried to restart your phone if it still does not work suggest that You could try backing everything up and doing a master reset, but back everything up first (its so important I said it twice). to do master reset just dial *#7370# and accept. after the master reset you can restore your files by restoring it from the back up.
i hope it helps! =)
Nov 02, 2010 | Nokia 5800 XpressMusic Smartphone
Apple iPod nano Logo
48 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
